Question about General Electric DHDSR46EGWW Dryer
I need to know how to take the back off to get at the belt and bearing
  • 718 Answers
DHDSR46EGWW Dryer
Go to;
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5240324
Click on the diagrams in the left-hand side. This will show how the cabinet comes apart. You can print these out. The Cabinet diagram will show how to disassemble the cabinet and the Backsplash, blower & motor diagram will show the belt location.
Posted on Apr 17, 2009
  • 77 Answers
Thier should be 5/16 screws all around the backing. First unplug it. You'll also have to remove the vent. But i am curious to know which bearing it is. good luck.
The timing belt slip off need to set timing belt back on
no timing belt I know of can you see it has slipped off most likely serpentine belt and they can be a bear cat too
Mar 10, 2015 | Cars & Trucks
How to put the belt on
You need to remove the drum in order to replace the belt so that you can inspect and grease the rear bearing. Once the belt is around the drum and you know the glides and rear bearing is in order you make sure the belt is not twisted. You move the idler to the right and run the belt over the top of it and under the motor pulley.
How to get into the machine:
Note: westinghouse frigidaire gibson and kelvanator dryers are all basically the same.
Jul 21, 2012 | Frigidaire Dryers
Whats the torque on the rear spin bearing on the outer hub on a whirlpool duet sport ht, model number WFW8500SR00, THANKS SO MUCH
i assume the bearing is connected to a belt drive. if so its more important to get the tension on the belt first , to prevent unesssecary wear on bearings,and i believe it would be the same tension that you would have on the alternator belt of a car.
May 23, 2012 | Whirlpool WFW8500SR
My chevy 2000 malibu is shredding through its serpintine belt ive replaced the tension pulley and the power steering pulley and bought and replaced a belt what else can be wrong one of the pulleys i think...
Yes that is very likely it. Since you changed the belt, you should know - Is it the tensioner pulley ? Otherwise it is probably the water pump. The problem is the bearings.. If the bearings are locking up, the resistance will shred the belt quickly.. the part needs to be replaced is the bearings. Waterpump bearings are built in to pump. Change whole thing. (may need to transfer the pulley)
Sep 02, 2011 | 2000 Chevrolet Malibu
Have a bosch tumble dryer need to know how to fit the belt that holds the drum
Remove the top cover by removing the screws at the back of the machine and sliding the cover off forwards. Now you need to obtain access to the complete circumference of the drum to fit the belt. Depending on your machine you can either remove the front of the dryer, or release the rear bearing support so that you can slide the new belt over the drum and under the bearing retainer, which may entail removing the back cover as well. The belt then just slips over the motor pulley and you need to check on the belt tension, usually done by adjusting the motor or the tensioner.
Apr 13, 2011 | Dryers
Belt came off
before you attempt to reinstall check the tensioner for this belt. There is a reason for the belt to come off
The pulley where the belt slips onto may have a flat spot on it or a worn bearing
May 09, 2010 | GE DCVH515GF Gas Dryer
Clutch function provided by idler wheel tensioning
is this a troy bilt and have you just replaced the front drive belt if so if the belt is a pix belt then you need to take it back you need a belt that is oem onley i know this for a fact i have tore up some ones hood if you havent done any of this then ck the pulley were the front and back belt goes on thats called a varspeed pulley i have had them lock up some times thay go out or the bearings on them go out and you can bearings them let me know if you need any thing mowershop@live.com ill help you
Mar 06, 2010 | Garden
DRUM NOT SPINNPNG CAN HEAR MOTOR RUNNING
Hi
You need to pull the machine out from the wall and remove the back panel. This will give you access to the belt drives. It sounds as if the belt has either snapped or slipped off the pulleys. Be aware you may also have a bearing problem on the motor which has caused the belt to come off in the first place.
Hope this helps.
Jul 12, 2009 | Washing Machines
Dryer bearing
you need to oinstall the bearing little ball and bearing first then install the drum and belt the last thing is to rinstall the 3 screws inside the back of the drum to the bearing this is the easy way rather than tryingto get the bearing in the scoket while on the drum
May 14, 2008 | Frigidaire GLER341A Electric Dryer
General Electric DHDSR46EGWW Dryer Logo
246 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Donni Steen
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
