Question about KitchenAid KGSC308LSS Gas Kitchen Range
Inside oven door glass broken Can I replace broken inner oven glass myself? I broke it today and need some help.
  • 77 Answers
I would guess that you could not. It is a safety glass and has a special gasket material. Although you may be able to buy the door as cheap or cheaper than just the glass plus the install. Hope this helps. Have a great day.
Posted on Apr 17, 2009
The handle on my maytag microwave oven broke off at the bottom. How do I replace ? Model MMV5165BA
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
This is not difficult. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
Replacement parts can be found at any of the following sites:
appliancepartspros.com
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
I hope this helps you.
Aug 12, 2009 | Maytag Appliances Over-the-Range Microwave...
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
How do I remove the glass on the inside of the oven door to clean between the two pieces of glass
We just replaced the inner glass last night. The door needs to be removed, then take the screws out that holds the inside panel on. I suggest writing notes of the steps that you take when you remove the panel and glass. Our model had three pieces of glass. Be careful replacing the door, we knocked the lock loose which in turn knocked the sensor for the light to come on. We had to take that part of the oven apart also to fix it. Hope this helps. I may not have done this if it wasn't for the broken glass.
Dec 30, 2008 | Whirlpool RBS305PDS Electric Single Oven
Neff H7871 inner glass broken
Hi, I am having a same problem I have managed to order theglass from:-
http://www.4neff.co.uk/cgi-bin/product.pl?PID=876912&query=Neff%20H7871N1GB%2f01&model=H7871N1GB&path=127858
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, thedoor should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slipin hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner doorbehind it.
5. Remove the 16 screws holding the inner glass with a special star type screwdriver bit no T30.
6. Once you done that the glass housing holding the inner glass can becarefully prised free and taken off the inner door assembly.
7. Once you done that remove and inner glass, and be careful to leave the glassseal intact, clean around the frame housing and the seal then replace the newinner glass and reverse the process.
PS. Be careful of the inner door once you've removed the outer door, asthe hinges holding the inner door tend to shut quickly as there is less weighton the hinges.
It will do the job if you follow these instructions. AL (srahbah@hotmail.com)
Dec 05, 2008 | Neff H7871 Convection/Microwave Oven
RBS305PDS Broken Glass on Oven Door
inner door glass part number 4449259.. youll need to remoe the door from the unit and lay it on the table, thats the hardest part, theres a few different ways the door releases, so refer to your manual if available, then its just a matter of removing the screws form the door until you get to the broken panel, might thake a little time but as long as your patient no need to call service man. probly save $150
Nov 23, 2008 | Whirlpool RBS305PDS Electric Single Oven
How can I remove oven door so that I can replace the broken glass
I just took my oven door off and took it apart to clean the glass inside. I don't have a maytag but they probably all work alike. Just open the door like you are going to broil something and just lift it up. It should slide right off. Shouldn't have to unscrew anything. Hope this helps. Arlene
Nov 15, 2008 | Kenmore 33169 Gas Single Oven
I have a Kitchenaide Gas Range. KGST307 Inside glass on the oven door broke.. need to replace. is it easy to do? going to order glass online.. I did call some local repair people.. looking at a $200.00 to $250.00 bill to fix... NOWAY............ I can buy the glass and do it myself... Need some help if it can be done..... Any Help is COOL!! Thanks TED... 425-549-0150 WA. 98014
Aug 19, 2008 | KitchenAid KGST307 Gas Kitchen Range
Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
Nov 20, 2007 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid KGSC308LSS Gas Kitchen Range Logo
474 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
