Question about Panasonic Lumix DMC-LC33 Digital Camera
Memory card My memory card says it is now protected, How do I unprotect it so I can use it? Thanks Greg
  • 1 more comment
  • pud11 Dec 25, 2007
    Yes i have the same problem? Please help it is christmas day
    Thanks melissa
  • Anonymous Dec 26, 2007
    mine says card protected and will not let me do nothing but turn off and on
  • batman_bw_17 Jan 11, 2008
    I have the same problem, but the lock was not the solution. I have also tried multiple cards in my polaroid t737 and all say card protected on the screen when camera is powered on.
  • 150 Answers
There sould be a very tiny slide switch on the memory card itself. See the pic
Posted on Sep 17, 2007
  • Patrick McGee
    Patrick McGee Sep 17, 2007
    Off to the left is the slide switch.
    GooD Luck
That sure did the Trick ..Cheers
Posted on May 01, 2008
My card switch is in the unlocked position. And when the camera is turned on it says card protected, so i pop it in and out and that fixes it. Is there a more permanent fix that popping it in and out everytime?
Posted on Jan 03, 2008
Posted on Dec 25, 2007
Thanks, worked like a charm
Posted on Nov 08, 2007
THANKS!!!! PyroMan6x9x9!!!!!!!!!!
Posted on Oct 01, 2007
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
I put my memory card into my Kodak EasyShare C143 digital camera. I press the review button, but all that comes up is that the file is 'Unrecognised'. One out of the three pictures is unprotected, but the...
It sounds as if the card was not formatted for the camera before it was put to use. My suggestion is that you attempt to download the images that you do have to the computer, then format the memory card. Always format a new card and after each time you download pictures from the card to the computer.
Dec 28, 2010 | Cameras
The camera says that my Memory card is protected. How do I unprotect my pictures? Also how do I reset switch on memory card? Thanks
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If you had protected any pictures on the card, then while viewing that picture press the Menu button. Use up/down to select Unprotect.
Oct 13, 2010 | Kodak Easyshare C182 12MP Digital Camera
Most SD memory cards have a small slide switch on the edge off the card. This switch is used to write ptotect the data on the SD card - you can lock or unlock the SD card be sliding this switch.
Jun 18, 2010 | SanDisk 2GB microSD Memory Card
Hello! I have a problem with my cam. When I put the memorycard into the cam, it says - memory protect! What does it mean and what should I do? Thanks in advance!!
Actually your memory card is 'memory-protected' ! You cannot use it without making it 'unprotected'.
Try these steps to unprotect it :
1. Remove the memory card from the camera.
2. On the down-end (which faces outside when it's inside the camera) of the card, you will find a small sliding switch.
3. Move the switch to the opposite direction (left or right) of the present position.
4. Now, it is unprotected and you can use it!
please rate me if it! :)
Jan 08, 2010 | Fuji FinePix A800 Digital Camera
My nikon camera coolpix 1600 memory card is write protected. Plea
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Apr 28, 2009 | Nikon Coolpix S51c Digital Camera
My memory card is write Protected how slove this problem
You can see the write protected button on your memory card just move it slight to unprotect your memory card.
Rate my answer.
Jan 03, 2009 | iLO (2 GB) MP3 Player
Locked Card
Change the memory card lock switch to the normal setting84b4934.jpg3c6d94b.jpg
Good luck....
Nov 18, 2008 | Canon PowerShot S51S Digital Camera
How to unprotect the memory card
On most sd cards there is a physical (tiny) sliding switch on the memory card. Here is a picture of a standard SD card. On the left you can see the gray switch in the unlocked position. Hope that helps. -WN
Jul 27, 2008 | Nikon Coolpix 4600 Digital Camera
Memory card has a slider switch which prevents write access. Move switch to other position.
May 15, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix DMC-LC33 Digital Camera Logo
713 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
