I need a manual for a tyan tiger i7501b s2729g2 motherboard.
  • andrew_kerbe Apr 18, 2009
    I already looked at that, but its wasnt the right board. For one, the board I have holds 12G RAM, that will take only 8G, and my board has 2 64 bit pci slots, and no 32 bit slots. I really need a manual for a board that is close enough that the pin outs are likely to be the same.
  • 148 Answers
(http://www.tyan.com/manuals/m_s2723_102.pdf)
This is the manual for Tiger i7501 (S2723), since your motherboard is from the same family, their manuals are common. Hope this helps.
Posted on Apr 17, 2009
  • Erinc INCI
    Erinc INCI Apr 18, 2009
    I'm sorry, but Tyan's official website holds that manual, does a manual came out from the box you bought the board with? Because if board's manufacturer did not prepared a manual for that specific board, there's no chance we can find it. (You can send an email to Tyan asking for the manual) Only way is that you can clarify your question like which specific pinouts you need for what reason and maybe we can help on that issue.
In need of a wiring diagram or schematic for this motherboard
Yes! I'm back and the reason why is because I HAVE ALREADY GIVEN YOU THE SOLUTION TO THIS PROBLEM...
It's fairly easy to connect hardware and cables to a motherboard most pins are labeled and most connectors don't fit where they don't belong. I do it all the time at work and home. In the last solution, I gave you a link to Tyan's Web site where you can find a manual that will give you the specs, a guide and much more.
Maybe I should have explained how to use that link in deeper detail...when you click that link it will bring up a page providing you with a color image of the board along with specs. If you want the manual which gives you the CONNECTOR PIN ASSIGNMENTS AS WELL AS DETAILED INSTRUCTIONS ON HOW TO INSTALL THE BOARD, then you MUST click the image at the top of the page that looks like an open book (it will take you to the manuals). There are 2 PAGES OF MANUALS FOR TYAN BOARDS. YOUR BOARD IS LISTED ON PAGE 2.
If you follow this link again, you will see exactly what I'm explaining. http://www.tyan.com/archive/products/html/tiger133.html After you get to the Web page, click the icon that looks like an open book (when you place your pointer over this icon the book goes away and it says MANUALS). Now click it. On the next page, you will see MANUALS/ADDENDA and, just next to this is another one that says page 2, now click it.
On page 2, scroll down the list until you see Tiger 133 [Addendum]. Click the name of your board and the next thing that will come up is the EXACT manual that you're in need of. I promise!
Here is a link to the manual itself...take a look. You can also click the link in the paragraph above to go directly to the installation guide.
ftp://ftp.tyan.com/manuals/m_s1834_120.pdf
Now you should be able to get this bad boy running!!
I know that this will solve your issue as I followed these links both times to make sure the information I provided was accurate. This user guide tells you everything you need to install the board...even gives you explanations of the beep codes (which is very handy to know after installing a new board).
After you click that link and it takes you to what your looking for, can you please be kind enough to rate this solution accordingly.
Thanks!!
Apr 01, 2009 | Tyan Tiger 133 S1834 Motherboard
Need a schematic for this motherboard tyan tiger 133 (1834)
I found the information that you are looking for and you will find it here: http://www.tyan.com/archive/products/html/tiger133.html. This page on Tyan's Web site will provide you with a color image of the mother board (with slots labeled) along with the specs for the board. I hope this is exactly what you need.
Thanks for using Fixya and please rate my solution.
IT_GURL :)
Mar 27, 2009 | Tyan Tiger 133 S1834 Motherboard
I have the same Tyan Tiger 230 (s2507) motherboard
(I did write alot about your problem but im not sure if it sent so i will sum it up)i have the same motherboard only time i get that error is with a video card greater then 512mb, clockspeed of over 400, also could be the drivers for ur video card as well as the motherboard. (i dont no much about computers so thats the best i can give you, sorry) Hope that helps and good luck. i also run wow on this motherboard and i could play it at about 50fps at max graphics so it works pretty good for a cheepy
Nov 03, 2008 | Tyan Tiger 230 S2507D Motherboard
Tyan tiger mpx (S2466N-4M) weird boot problem
probably the board is bad or the board is grounded out on the chassis edge somewhere or possibly the mounting screws...
recommendation.. pull the system out of the chassis
test the power and board on a sheet of cardboard...
also try one stick of memory only and set the options for full ecc scrubbing on to test the memory correctly
Aug 26, 2008 | Tyan Tiger MPX S2466N-4M Motherboard
Manual to tyan s239001
Try This link to Tyan Archive Files.
http://www.tyan.com/archive/support/html/manuals.html
I think your board will be here.
Trinity KT Manual under Socket 462/A ( AMD Athlon/MP/Duron )
Mike @ Compurepair.
Mar 12, 2008 | Tyan Thunder n6650W Motherboard
I want to get a layout diagram of the tyan s2507 motherboard
The manual for that motherboard is located here -
ftp://ftp.tyan.com/manuals/m_s2507S_100.pdf
You will need Reader installed in order to open the PDF document. If you don't have Reader, get it free from http://www.adobe.com
Oct 29, 2007 | Tyan Trinity 450 (S2507S) Motherboard
Computers & Internet Logo
155 people viewed this question
David Payne
David Payne
