The company I work for has an old RICOH Copier that has an error message, ''Close the Finisher Door''. I've tried to open and close all the doors, checked for jammed paper, but nothing. Any suggestions?
  • 469 Answers
These type of machines have actuators and micro switches, make sure none of the actuators are bent and not making contact with the switches, The actuator may be a pin or bolt that come in contact with the door switch.
Hope this is of some help.
Ed
Posted on Apr 17, 2009
How do I clear error message that says to close the finisher output guide?
The finisher output guide is usually a small plastic piece about as long as the paper feed that can be opened to see the rollers, make sure that is put back down before you print.
Aug 27, 2014 | Canon iR 2016i Black and White Copier
My Ricoh aficio 450 copier shows a error that says: close door for relay. I have closed all the covers and doors and still get the same error message.
The relay door is the door on the lower right side, below the duplex unit. Check this door -- it may not be closed all the way, or the actuator (the piece of plastic that sticks off the door and is the part that blocks the sensor) may be broken. If neither of these is the case, the sensor may be bad.
Mar 30, 2011 | Ricoh Aficio 450 Copier
Second hand Ricoh FT7950. Paper wont feed from
Going strictly from memory as this is an older model.
With the machine sitting ready to make a copy open the finisher door and close it . Are there any signs of life ie rollers spin tray moves stpler homes up?
IF yes I would look at the finisher entrance sensor as these get pretty dirty ith paper dust(or could be out of alinment from moving.
IF No then I would look at the finisher connector inspect for any damage .
Hope this gets you in the right area
Apr 03, 2010 | Ricoh FT7950 Copier
I have a Ricoh Aficio 1035 stapler problem.
if you press the finishing button on the display does it so stapler function there ? or try taking the staple cartridge out and then close the door on the finisher and see if it says out of staples. if it does it knows it has a stapler unit.
Jan 20, 2010 | Ricoh Aficio 1035 Copier
Finisher door closure switch/sensor not working.
Have you tried to turn the copier OFF and unplug the finisher and turn the copier back ON with out the finisher pluged IN. If it works just don't use the finisher. I believe that model is rather old and you may have a problem finding parts for it, there are a lot of different reasons for the door not being showed closed. Good Luck
Apr 05, 2009 | Office Equipment & Supplies
Showin cover open but doesnt indicate plus sc code 670
I looked up the error code in the manuals for the 450 and 450e,I tried sc 670, 607, 706 and 760 NONE or those codes exist in either one of my manuals! Sorry. Wish I could help
Apr 03, 2009 | Ricoh Aficio 450 Copier
Toshiba e 350 "close finisher door"
Finisher door is the sorter. there is a switch or door in the sorter not closed (or triggered)
Aug 12, 2008 | Toshiba e-Studio 350 Copier
Canon iR8500 with Error E000583-0001
Hello Jeremy,
This error code has to do with your finisher. The auxillary tray is not finding its home position or does not leave the home position within the alotted time. Check for binds. I have limited exposure to the K4/3 finisher but try this. Turn the copier off, and open one of the finisher doors. Now turn the copier back on with the finisher door open so it cannot initialize. Once the copier is basically ready except the finisher door is open, close the finisher door and observe all the **** (and theres alot) initialize. This may help determine the problem. I hope this helps...........................SPINAL
Mar 12, 2008 | Canon imageRUNNER 8500 Copier
51 people viewed this question
k24674
jasbo
jasbo
