Question about Sony Playstation 3 (PS3) Console
My PS3 will not output video.
I will plug the AV head into the AV port into the PS3. It works fine when I use it with my PS2 so I know it is not the cable. I have also used a different AV cable that works and the PS3 screen still is not coming up. My PS2, XBOX 360, and Gamecube all show up perfectly on the TV.
  • 371 Answers
You have gone through all the steps of the process of elimination that I would have suggested, and everything
has been eliminated as the cause of the problem except for the video card in your PS3.
Have it serviced while you still can without cost to you, if possible.
Posted on Apr 17, 2009
Will the RCA and av cables from a ps2 work for a
Yes they will. also the component output cable (optional from sony) will work on both systems
Apr 04, 2011 | Sony Playstation 3 (PS3) Console
I have a ps3 60gb capatible for the ps2 I have it hooked up to the TV but its not showing anything on the TV I have the High Def connectors for the TV
It is a known problem with some high def connectors not working properly. The following should be checked before concluding there is a problem
1. Ensure you have your TV tuned to the right output station for as your ps3 is connected.(for example you cannot have your ps3 connected to the second set of av ports on your tv and your tv is on av1, it has to be on av2)
2. Cross-check the functionality of your ps3 using the default av cables that come with it so as to know if your cable or console is faulty.
3. Ensure that you high-def cables are properly connected.
If all the above prove abortive, you have to see a repairer to check-up your ps3 or tv
Dec 25, 2010 | Sony PlayStation® 3 (60 GB) Console
Fixed ps3 ylod but now no picture and sound. what could this be? and how could i fix it?
If your tv output it av (red white and yellow cables and av connection), then make sure you push the cables in properly. If that doesn't work then if you have a ps2, use that av cable and switch it with your ps3 one (theyre both the same). And if your output is hdmi, than either the cable is faulty, the tv or the ps3. And for av connection if none of those options worked then its probably your ps3.
Dec 18, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont show on my tv anymore. what do i do?
not to worry it is very simple
1. if u are using hdmi port and it is connected to hdmi in your tv
setting might have been changed
1. take out ur nomal av output wire which is given by sony , plug it on to a normal tv (rgb) now u can see the display (if not try mannual swithch off the ps3 and on for 3 to 4 times) u will get the display
2. now go to settings (video settings) there is a option called video output u can change it to AUTOMATIC
3.NOW COME OUT of it and switch off
4. now pug into ur hdmi port it will work
Mar 15, 2010 | Sony Playstation 3 (PS3) Console
Av cable displays no video but only sound
Use your ps3 warranty and get Sony to replace that one with a new one.
Aug 06, 2009 | Sony Playstation 3 (PS3) Console
PS3 No signal to the TV
To solve this, when the ps3 is in standby (solid red light), just hold the power button. It should beep on, then beep again in about 5 seconds. This will automatically search for the optimal audio video output. if if beeps on then turns off, just try again, it takes 1 or 2 tries sometimes. the reason this is happening is because your ps3 is set to one AV output, ex. composite(red yellow white), HDMI, and then you changed the cable to a different one. another way to fix it is plug both cables, HDMI and composite, into the tv and ps3, then go to settings and change the output to the desired one.
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is busted, need help.
if someone else has been messing with the ps3 they may have accidently changed your output from hi def to the old ps2 output. try putting your old ps2 av lead into the ps3 and conect it to the tv if the output has been changed its just a matter of changin it back i had this problem so now i dont let anyone play it i hope this can help mate
Apr 13, 2009 | Sony Playstation 3 (PS3) Console
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Bad AV Multiout on a Japanese PS3
Copied from another forum: "On the PS3 from Standby (red light on) depress the power button till you hear two beeps. That will reset the resolution and you should get a picture." MANY THANKS to the original poster!
Dec 14, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
82 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
