Rank: Guru
Rating: 86%, 378 votes
door seal replacement can be done with a little skill and a bit of common sense, 1st thing to do is buy a replacement quoting make model etc, then you will see how the seal is shaped to fit,
unplug the machine and work from the front,
open the door and remove the thin wire clamp from round the edge of the door seal, remove from the lip of the cabinet and that will enable you to see inside the casing, there is a wire spring or an adjuster on the drum end of the door seal, remove that and the seal will pull off with a gentle pull, refit as removed, take note how you removed wire etc,
check for leaks and state of fit before leaving machine unattended and running
difficult job hard to describe in writing, but not too hard with a little thought
Comments:
Sep 18, 2007
- please rate me when done, thank you
