My brand new Roadmate 1212 won't power up or stay on when it is not plugged into a power source even though battery life shows full. Sent it back to Magellan after 2 phone calls and a description of the problem. Got it back from them today with the helpful note of 'Using - NFF - No Fault Found'. Aaaghh!
Comments:
May 21, 2009
- Update on my Roadmate 1212 not staying on when not plugged in. Spoke with customer service, who told me the problem was with the battery and to return it. I did so, and they sent me a refurbished model (the serial number is different). It STILL doesn't work! I am beyond frustrated.
-   My brand new Roadmate 1212 won't power up or stay on when it is not plugged into a power source even though battery life shows full.-   lesh906
Apr 29, 2009
-   same problem as others, Magellan Roadmate 1212 won't saty on when unplugged.
-   Guest
Apr 29, 2009
-   Same problem. Works fine when plugged in and battery shows full, but won't run at all if unplugged. Very irritating.-   Guest
Apr 27, 2009
-   Battery shows full charge when running on AC adapter, but will not run unplugged. I plugged it in overnight into a powered 12 V car outlet and still no luck.-   Guest
Man, I DO commiserate with you on that one, but did you specify to them that the battery should be checked? as that is probably your problem, now that I know the unit has been checked and the worst possible outcome from your buying an extra battery is that you will HAVE AN EXTRA BATTERY for those times when you need total portability.
So, make sure you try a brand new battery and if that solves your problem, then buy several.
My Magellan Roadmate 1212 won't turn on. I don't have the AC charger, but the car charger is...
(More)
My Magellan Roadmate 1212 won't turn on. I don't have the AC charger, but the car charger is working fine. Help!
My Magellan Roadmate 1212 is always stuck on the last location that it is guided to. When I enter in...
(More)
My Magellan Roadmate 1212 is always stuck on the last location that it is guided to. When I enter in a new destination the Magellan Roadmate takes no less than 20 minutes to come up with directions.
I believe it has gone flat and now when I turn it on only the reset screen appears no other key is...
(More)
I believe it has gone flat and now when I turn it on only the reset screen appears no other key is functional
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
