Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water collects in bottom of refrigerator and gets in bins
I have a top freezer Whirlpool refrigerator with the ice-maker removed. Water collects in the bottom of the refigerator and gets into the crisper an other bin when it does its automatic defrost. The drip pan under the refrigerator is dry.
  • IbBuzz Apr 20, 2009
    Water builds up on the glass shelves, collects in the bins and the fridge is leaking onto the floor .
  • 121 Answers
There is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Posted on Apr 17, 2009
Whirlpool refrigerator #ER2CHMXPL02 I think I have two separate problems. 1st one is a water leak that fills the bottom bins daily! The freezer does not seem to be defrosting, everything in there looks...
Could be that the freezer is too full with foodstuff and there is no air circulation, therefor, some places in the freezer build ice. The defroster is working and melting the ice that drips to the bottom bins.
I suggest you remove everything from the freezer. unplug the frigde. Let all ice build ups melt. Remove ice from the foodstuff and put back in. Make sure that vents in the freezer and fridge are not blocked.
Oct 18, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool Refridgerator Model ET18GKXGWO 1 Water collects inside Main Compartment what can I do?
Remove bottom and rear panel icemaker if so equipped there is a drain hole on the right-hand side next to the Styrofoam vents for the airflow that was blocked with ice
Feb 09, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator is producing water which seems to drip down from the top rear center of refrigerator which is below the freezer. The amount is 1 or 2 cups per day and it collects below the bins at bottom of...
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
May 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water accumalating in the bottom of the fridge.
A common problem. All modern refrigerators have an automatic deicer. The heater kicks in, then MELTS the ice in build up in the freezer for a short period before freezing again. This water drains either in the fridge or out the back to the catch tray. Simply pull out the bottom drawers and clean the clogged drain hold where the water can drain and evaporate in the catch tray as it is designed to.
Mar 14, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Whirlpool refrigerator leaking from top of unit
Listened to other posts and figured drain plug was clogged. It was with ice. Removed bottom pan and back panel of freezer, removed ice on bottom, put hot water in drain to thaw ice until it flowed into pan underneath fridge. Thanks for the ideas.
Jun 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
WATER AND ICE INSIDE MY FRIG
Most likely whats happening is you have a frozen drain for the defrost cycle. here are step by step instrutions for repair
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
These are general instrutions for most top freezer refrigs. but if you need more specific directions dont hesitate to ask Thanks Peyton
Mar 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
426 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
