Question about Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 CD/DVD Tray
I can print photos no problem, but when I try to print a CD/DVD it won't do it. The tray feeds in and then feeds straight out. The printer asks me to reload the tray and press the maintenance button, which I do, and it does the same again. There is nothing in the troubleshooting guide to cover this so any help would be appreciated.
  • 1 more comment
  • Anonymous Nov 04, 2007
    when trying to print a cd cover. it won't do it. disc do's not go in.
    printer tell's me to shut cd/dvd door
  • Ron Brown Jan 24, 2008
    When I align the arrows, per the manual's instructions, the printer ALWAYS pulls the tray in slightly and then immediately pushes it out and the red error light comes on. As instructed, I close the tray and click the Eject button that the programs presents me in my Windows XP Pro screen.
    The only times--and this has been a very precious few--I am successful in printing onto a CD occurs when I push the tray in more than I am supposed to do--as a result the arrows are not now aligned; and then I have to exert a little, but steady pressure on the tray as the printer starts to pull it in. Sometimes it will then go ahead and complete the printing process.
    But even then it does not properly align the image printed onto the CD. I have gone through the process in the printer's menu window to move the image, e.g., 4mm left. Whenever I succeed in getting it print again, I see no realignment of the printed image.
    I am extremely frustrated and I really want this printer to faithfully print properly aligned images onto my CDs without me having to hope and pray (and play with it) every time. I will be supremely grateful if you can help me make this thing work as it is supposed to do.
    I have owned the printer a few years but this is my first time trying to print onto CDs. I have wasted tons of hours within the past week or so trying to achieve this. Please help!
  • Anonymous Feb 22, 2009
    Same problem. I have to shut the printer off, than restart it and it works fine.
  • 21 Answers
The answer to this is to insert the cd tray then click to print then when its about to print put some light pressure with your fingers and you will see the tray will go in and it willl print just fine does it with mine all the time so thats what i do to rememedy the problem...good luck
Posted on Feb 28, 2009
  • 3 Answers
I have the same printers. On the cd tray there is some small thin protrusions that are supposed to be thin enough to be easily caught by the rollers. Sometimes these do not go in between the rollers for the tray to continue in. Check and see if they are dammaged. A possible solution (but not recommended if you are not familiar with working plastic), is to try to make the tips a bit thinner so they will be caught by the rollers. The rollers are spring loaded so they will grip the material. This may or may not be your problem. It is what I have found quite frequently.
Posted on Feb 23, 2009
  • maddundeefan Dec 02, 2010
    mine loads ok carries out the print but nothing on it any help would be great.
Solution: Bought a new feeder tray. Works a treat.
Posted on Nov 01, 2007
You need to push the tray in until it is held between the rollers.
Posted on Oct 31, 2007
Mine did the same, whilst they are very, very fussy the main problem is that you need a few inches of clear space at the rear of the printer when you print CD/DVD because the tray has to be able to pass out the back of the printer before being drawn back in.
Posted on Sep 30, 2007
SOURCE:
Epson Stylus Photo R300 Inkjet Printer When I try to print on a cd/dvd I line up the arrows hit print but it keeps telling me to close the cd/dvd tray, there is no way it will print with this tray.
The cd/dvd tray door has a small opening on right edge. Inside there is a slide switch. Use a toothpick to see if it is stuck. Check where it closes to the main body. A thin strip protrudes out to mate and close the plastic actuator of the switch. The door may not be closing well enough the actuate the switch. Make sure it is fully closed and retry to print. Also, there will be a small click as you raist the door before it snaps into place. If not, check to see if there may be some debris causing it to not actuate properly.
Good luck,
Feb 21, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson stylus photo R300 cd/dvd tray not set correctly
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
Nov 16, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson stylus r300
Hi Chillyslade,
Try this..
Close the CD/DVD guide, then press the font28.gif maintenance button.
If the CD/DVD tray is inserted, remove the CD/DVD tray, then close the CD/DVD guide
Hope this works, kindly let me know by providing your valuable rating.
Thanks,
Robosoft.
Jan 04, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson R300 CD/DVD Tray ERROR message with Leopard any Solutions?
One of the guys on this site said read the manual over and over again, and he was right.
You must go to system preferences and choose print and fax. Set the default media to A4. Then in the Print CD program when you hit print your will see fifth line down Epson Print CD on offer. Hit the arrows on the right and choose print settings from the drop down menu and then media type and choose CD / DVD. All should then work. It does on mine.
Regards and best wishes. David
Dec 30, 2007 | Epson Stylus Photo R300 InkJet Printer
Epsom Stylus Photo R300
Yes I had a similar problem and in fact returned my printer for a replacement. You need clearance as the CD tray emerges some 2.5 to 3 inches behind the printer. If the tray hits an obstacle it is unable to correctly line up for printing and the trat is rejected
Dec 24, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
802 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
