Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
Belt seems to be slipping
My dad bought a new belt for a MTD white RB 550 tiller-rear tine.( he bought it new around 2000-2001) The old belt was damaged and slipping. He ordered the new one from Lowes so it should be the correct one--it is smaller than the old used one. The problem is it still seems to be slipping. It makes that screaching noise when it starts tilling. We tried to tighten the cable that goes to the idler pulley. but it either starts grinding gears or it wont come out of gear when you release the handle. (very dangerous - trust me!) we cant find anywhere else to tighten the belt. What do we need to do to fix this? Thanks for any help you can offer.
Good evening. I would suggest checking the tine bearings as well alignment. I had (have) a 2003 mtd rear tine which blew the entire bearing box for the second time. The times should have little to no flex when push or pulled. Fortunately, MTD came good for the first rebuild even though my warranty had expired...they covered the parts and labour was all mine. If the tines seem properly working, possibly try out this website to get the 100% correct belt....hope this helps.
http://www.milacalawn.com/parts.asp
Posted on Apr 18, 2009
Yardworks rear tine tiller Model# 217-430-500, need belt number for replacement
take the old belt with you to any small engine or lawn equipment repair shop they should be able to match up a fractional horse power belt that will fit.
Jul 07, 2014 | Mtd Garden
Drive belt is slipping when under load. How do you tighten the belt. thanks, Ted Troybilt Horse rear tine tiller
hi there, ive been doing a bit of head scratching over this one as i needed to check my facts. i think the belt has a automatic spring loaded adjuster so it sounds as if you need a new belt for it.
good luck
iain
Apr 30, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Need to obtain a new belt and pull rope for my Tiller
you can get a pull rope at wal-mart.measure the belt and any parts store or place that sells lawnmower belts should have one.if the rope broke close to the end knot just pull the end knot with some needle nose pliers.once you have all the old rope out lay the old rope pieces on the ground and cut the new rope to match it as far as length.turn the pulley that the pull rope goes in six turns counerclockwise.then turn the slot the knot was in to the hole the pullrope goes thru and fish it thru then pull it up and out with apaiar of needlnose have someone hold the pulley until you tie a small knot in the end of the pullrope the hold the pullrope and let it pull it in.you might have to cut some off at the handle if its still too long.to do this pull some rope out and tie a quick knot so the rope can't slip back if you let it go.
May 27, 2010 | Mtd Products Yard Machines 158CC Tiller
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
MTD series 410 rear tine tiller drive wheels slip
I have the same issue with one I am working on. It appears the keys in the drive shaft are not rotating far enough out on the drive gear side to fully engage in the gear. I have studied and studied this and so far I have been unable to determine why. If I find out I will let you know. I am also trying to figure out what is supposed to pull these keys out of the till engagement gear.
Mar 21, 2010 | Mtd Products Yard Machines 158CC Tiller
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Help, new craftsman rear tine tiller stopped tilling.
It sounds like the belt just stretched. Now you need to move the belt tensioner over to put more pressure on it.
Apr 25, 2009 | Craftsman 8.50 Torque Rating Rear Tine...
Tines wont turn
Without really knowing what is broken it will be tough to give a firm idea of the cost. However, you can head over to www.partstree.com. They have a great detailed parts break down and costs associated with it. Looked up your part numer and can find at this link: http://www.partstree.com/parts/?lc=mtd&mn=210-031-000+%281990%29
Apr 16, 2009 | Mtd Bronco Rear Tine Tiller
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
308 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
