Question about LG LRBN20510WW Bottom Freezer Refrigerator
Reverse open I have a bottom freezer LG model number LRBN20512ww and would like to reverse open it. I can see with the doors can be reverse but do I reverse the fridge handle?
aborcass
  • 2651 Answers
SOURCE: Loose handle on fridge freezer door.
that handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
Posted on Mar 12, 2008
SOURCE: Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Posted on Nov 15, 2008
jyackle5
  • 8197 Answers
SOURCE: Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Posted on Dec 17, 2008
stradeteox
  • 88 Answers
SOURCE: freezer working fine but fridge isn't
Either the damper that the air flows up through is closed or the return air flow vents are blocked with clear ice.
Do you feel the air come out all the way at the top of the duct assembly when the freezer door is opened (but it then stops when the door is closed)?
If so, then it sounds like your return air flow vents are clogged. These are located to the left and right of the duct assembly in the rear/bottom of the refrigerator section. Sometimes you may have to slowly pour hot water into these vents to get the clear ice to thaw. The water should go down into the freezer section behind the evaporator and then out the drain in the back.
If you do not get the air to flow out the top of the duct assembly then the damper is staying shut. This could be either a bad damper in the duct assembly or the main board my not be sending voltage to the damper. Hope this helps.
Posted on Jan 08, 2009
david04928
  • 102 Answers
SOURCE: Build up of ice on bottom of LG fridge freezer
Is it supposed to be self defrost? If so then either underneath the freezer needs to be cleaned. coils if dirty will cause freezer not to work well. I that doesn't help you might have a freon leak which would make it under charged and would ice up like that.
Posted on Mar 15, 2009
I have an LG front loader washer Model VM4270HVA and I want to know if I can reverse the door to swing open to the right as opposed to the left?
Some washing machines are available with the reversible doors, but only a few of them do (and they are expensive). Most times, you would have to order the machine with the specific door opening. You can probably check with LG support for a definite answer.
Jul 13, 2017 | LG Washing Machines
I removed the freezer door and now I cannot reattach it.
Generally you just reverse the removal process. Place hole in door bottom over lower door hinge pin and place door in closed position. Insert top hinge in top hole---align hinge screw holes with holes in fridge cabinet and insert screws. Not sure what is giving you the problem. If you need more help post back brand and full model number so I can look it up.
Apr 21, 2015 | Refrigerators
Reverse doors freezer hinge
What is the model number of your unit?
Nov 28, 2012 | Refrigerators
I have a lg frige model #lrbn20512ww. it quit cooling both upper and lower yesterday. are there any known problem with the compressor or could it be somthing else. the compresor runs for about min the...
unplug the ref remove the back panel place a fan behind the ref to cool the compressor when you can place your hand on the compressor then you can clean the condenser coil and plug it back up make sure the condenser fan motor is running
Nov 18, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
How do i reverse the refrigerator door of an amana arb2217csl
you canot reverse the handles on this model. There are no predrilled holes or covering plugs on the opposite side. The model number ends in an "l" signifying left hinges. The companion model ends in an "r" with hinges on the right. These fridges were designed so you could purchase them as a pair seting them side by side.
Oct 09, 2010 | Amana ARB2217CSL Bottom Freezer...
Sears Craftman Garage door opener model # 41a3493-1. Does it have auto reverse?
That isn't the model number you give it is the part number for the logic board. The model number is on the opposite end of the motor unit and starts with 139. If you are asking if the opener should reverse when it hits an obstacle the answer is yes. If it doesn't it is not adjusted correctly or is faulty.
Dec 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
LRBN20512WW, the unit won't go into defrost, I manually defrosted it like the previous tech did. I ohmed out the heater but where is the timer and how do you start it?
May be the glass heater for defrost not function cause by thermal fuse broken, or may be the defrost timer damage. The timer location usually at the back of reff on the bottom side, over or near the compressor unit.
Aug 12, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Can you get icemaker for model lrbn20512ww and does it come
yes you can call appliance parts store give the model# off appliance
Apr 07, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Jun 25, 2008 | Kenmore 64702 Top Freezer Refrigerator
Fridg not cold
your story is very odd but likely nobody is messing with the door switch hwen you moved , or the wires could have shorted out. normally, the door switch, when you open a door would switch on a cabinet light and turn off the blower. in your case, its the reverse, as you open a door, the blower runs and if you close the door, the blower stops. im not sure if you can figure out which pair is the normally close and which one is the normally open on the door switch in order to swap them or you may rplace the door switch.
Feb 05, 2008 | Refrigerators
LG LRBN20510WW Bottom Freezer Refrigerator Logo
96 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
