Question about Xerox DocuColor 12 Color Copier
What types of damage can be incurred in moving this type of copier
We need to move a Xerox Docucolor 12 five blocks from our old office to our new office. Xerox wants to charge us $1,000 to move. What can get damaged on the inside from moving the copier that would justify the $1,000.00.
  • 469 Answers
There are components that can be damaged.
The customer is usually offered a you move we move price.
If you place a service call to tear down the machine, the tech should come in and prep and wrap the machine for the move.
Once it is at the new location and you are ready for it call for the tech to come in and reassemble.
the should take no more than 1 to 1 1/2 hours on each end.
As long as your mover is OK with moving the machine this is the most cost effective way to move it.
I usually recommend you place both the tear down and the set up service calls at the same time. this should reduce down time as your call set up call will already be in the system.
Hope this is of some help
Ed
Posted on Apr 17, 2009
Xerox docucolor 2045
Try cleaning the paper dust off the pickup roller.
Nov 09, 2017 | Xerox DocuColor 12 Color Copier
Hi Dear Can use xerox DC12 with MAC OS without
There are some Mac OS drivers.I think your printer is not compatible with Mac.
The level of functionality and compatibility with the new Mac OS X 10.6 drivers are identified in the following document.
> For a list of Xerox equipment compatible with Mac OS X 10.6, click here.
DocuColor 12 Copier/Printer
Dec 14, 2010 | Xerox DocuColor 12 Printer
Can xerox dc 12 print without any rip? if yes, how
no. you need some type of rip for it. the dc12 has no internal memory or network capability on its own
Jul 23, 2009 | Xerox DocuColor 12 Printer
Offset catch tray failure docucolor 2045
there must be a fault with the tray or wiring. There is nothing else that can cause this fault
Feb 14, 2009 | Xerox DocuColor 12 Color Copier
Xerox Docucolor 12 printer display panel not working properly
open display pannel
and check for dust of any damage of wire
Dec 08, 2008 | Xerox DocuColor 12 Printer
Xerox docucolor 12 copy/print printing all black
If you moved the printer, make sure the conections from the printer to the Fiery are secure. If loose the prints will be black but when copying will be fine.
Jul 19, 2008 | Xerox DocuColor 12 Printer
Xerox DC12 System Fault 6-355
06 codes refer to exposure lamp problems..(or scan) check lamp coming on, scan carriage position etc, don't have the code list, so carefully move the scan carriage up and down, make sure it moves OK
Jun 05, 2008 | Xerox DocuColor 12 Color Copier
Cmyk dots on the print
There are several causes of those.
So go to Xerox.com
Click "support and drives"
then in the product name box, Type DC12
Then any line click support
IN the search box type "spots" and read the relevant solution.
May 05, 2008 | Xerox DocuColor 12 Printer
Docucolor-12 10-389 CODE
That is a fuser jam indication.
  1. Clear the Paper Jam and Obstructions in the Machine
  2. Make Sure the Paper is the Correct Size, Type, Weight, and Orientation
  3. Make Sure the Paper Supply Setting Matches the Type of Paper Loaded in the Paper Tray
  4. Load the Paper Trays Correctly
  5. Fan the Paper, Turn the Paper Over and Reload the Tray
If the above are all correct, you may just have a small piece of paper stuck on a sensor. Just has to be a small piece of paper directly on one of those. Also see if a sensor flag is dislodged. A sensor may be bad but not likely
Mar 11, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Color Copier Logo
88 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
