The system starts to boot but does not recognize the hard drive(IDE). It recognizes the floppy and DVD player but will not read data from either
  • 4 Answers
Check your cables, the inside of the computer may be lose. also check for bent pins on your hard drive. make sure your computer is always spiffy and clean.
Posted on Apr 17, 2009
  • Derek Puczylowski Apr 17, 2009
L410
Step 1:
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. make sure there are no disks in cd floppy usb drives Test all power and data leads that attach to your hard drive IDE,SATA the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat ribbon 40 pin IDE it will be the fist to fail Make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs Data and Power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error. also make sure you have set it boot from you hard drive in BIOS Restart your computer and enter BIOS mode. On most computers this is done by pressing the Delete ot F2 key but will vary depending on your computers bios other keys Acer: - Ctrl+Alt+Esc , ALR PC: (F2) or (Ctrl)(Alt)Esc) , Award BIOS: (Del) or (Ctrl)(Alt)(Esc).
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on. Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it. Once you've selected your desired options, continue to boot.
Feb 27, 2013 | Acer Veriton Computers & Internet
Bootmgr is missing
Step 1:
Feb 15, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
Cd no boot record
Hope this helps.
Nov 19, 2012 | Computers & Internet
Trying to boot from windows CD and not working
If its the full windows xp cd by booting it from the cd drive it will erase everything and ask if you want to upgrade or advanced install I think. Your correct in choosing the atapi cd-rom as 1st boot device. The cd should be in the drive on startup. IDE is the type of hard disk drive. I'm guessing the FDD stands for floppy disk drive which you might not have that many but you have that many bay windows available.
Put disk in, shut down computer, Start computer and it should give you the xp disk contents. Be aware of data loss though.
Nov 14, 2009 | Microsoft Windows XP Home Edition
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Start by simplifying the configuration. Disconnect the second IDE cable from the motherboard and disconnect the power to the DVD drive. Disconnect the SATA device. On the #1 IDE cable, connect the master drive to the connection on the end of the cable. Connect the Slave drive to the middle connection on the cable. Start the computer and press the key indicated to enter setup. Verify that drives are properly indentified as master and slave. If they are, shutdown the computer. Now add the IDE DVD drive to the end connection on IDE cable #2. It should be set as a Master drive. Start the PC again and go into setupand verify that the DVD is IDE #2 Master. Shut down the PC. Add the SATA device and start eh PC again. Go into Setup to verify that all of the drives are properly identifed. Restart the computer and let it boot into Windows. Open Windows Explorer to view the drive settings. If the drives are all present, but the letters are not what you want, click on START and then right click on MY COMPUTER and then left click on MANAGE. Under Storage click on DISK MANAGEMEN. The drives will all be displayed with their assisgned letters. If you need to change a drive letter, right click on the drive you want to change and select 'Change drive letter . . .'. Change it to a hight letter in the alphabet, then change the dive you want in the original postion to the now vacant letter. Finally change the original drive to the first available letter. Example: C:=IDE M1 D: E:=IDE S1 Change D: to H: then E: to D: and finally H: to E: they drives would then be: C:=IDE M1 D:=IDE S1 E:=IDE M2(DVD). Restart the PC and the drive should come up as you want them to be labled.
Good luck and please let me know how it works ouot for you.
Feb 26, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
ABit-Th7 raid Drivers
This problem is very simple.... Using RAID in booting in cd/dvd cannot be done in this kind of processing. you have to change the setting of Hard Disk and CD/DVD to IDE in BIOS . To change the setting in the BIOS you need to press the Delete After you power on the computer.. In Main menu in the bios you will find the hard disk or cd/dvd settings to IDE, SATA, and RAID. change both hard disk and cd/dvd to IDE configuration. make sure the first boot in the Boot menu is the cd/dvd, where your windows cd installer is inserted. Save the settings by pressing F10 key in the keyboard.. I have the same problem as of you because i try it to change SATA, RAID but cannot boot to cd and cannot detect the hard disk when installing OS, but in IDE settings its okay.. and it works perfect.. after you installed the windows properly, you can change the Hard Disk or cd/dvd configuration to SATA or RAID. TY
HOPE I CAN HELP
Dec 08, 2008 | Abit KT7A-RAID Motherboard
Toshiba Tecra 8100 PC Notebook
if it can boot up windows, then the harddisk is not locked(anymore, after entering the correct password),
a slow performance of windows can be sped up by performing a harddisk defragmentation (open windows explorer, right-click onto harddisk, switch to properties,´then 'extras', perform a defragmentation for drive c:, give it time to finish)
to fix the arkward dvd/usb prob:
again open up win explorer and see if cd-rom drive is available, therefore recognized by windows at all.. if yes test-insert Original CD again, see if it can open it(does the CD/DVD-drive LED flash green several times and do you hear any noise from it?)
if not, shut down and enter BIOS while booting hitting either the Del,F1 or F2 button and look if under IDE devices the CD-is recognized by the laptop itself...
if not, set auto detecton for IDE- devices, go
through available menus until u find USB legacy support, enable as well, exit saving changes, reboot.
Again enter BIOS then change
BOOT DEVICE order sothat CD-drive is 1st,
any 3.5'' floppy drive second and harddisk 2nd or 3rd, exit saving changes again.
reboot and let windows come up again. check for cd/dvd-drive again(see procedure as described above), check if windows does recognize your usb-device(mp3 player) now.
if that does not work and during booting you get message'bad CMOS checksum error' you will have replace the CMOS button-battery on
the mainboard, for it may have gone flat...
this means disassembling the laptop
if that is the case, see a technician to work for you or come again with another query.
hope i could be of help
Oct 20, 2008 | Toshiba Tecra 8100 Notebook
New ECS G31T-M won't recognize IDE devices
Locate the boot options in your BIOS and set it to boot from the Hard Drive
Oct 13, 2008 | EliteGroup ECS G31T-M Motherboard - Quad...
Hard Drive Installation
Hi emceedrive, I gather you are using ATA/PATA IDE hard disk drives? Each hard disk drive has a large white sticker on it. Listed there are pin settings to set the IDE to Master or slave & Master with a slave. (We want to leave you're drive with windows on it alone). Not changing its jumper or not adding a jumper for now. We are not hooking up you're second drive just yet either.
Oh, please you're not an idiot either.
Unplug the power cable from the PC & open you're case.
Please open you're ASUS P4P800 SE manual to section 2.2.3 Motherboard layout. We want to connect the data cable to SEC_IDE1 first because once PRI_IDE1 is connected you will not be able to connect SEC_IDE1's data cable up to the DVD drive bay.
So grab a data cable for you DVD drive. It may have three connectors on it. Plug the connector that is the furthest from the other 2 connectors on the cable into the motherboard slot named SEC_IDE2. The data cable only goes in one way. Run the remainder of the cable up to the DVD player but do not connect it to the player yet. It is ok to fold the data cable which will help in routing it upwards to the DVD bay. Than connect the data cable to you're primary master IDE drive. (The one with windows already installed on it). The data cable should look just like the DVD data cable. Again you want to connect the furthest connector on the data cable into the MB slot named PRI_IDE1.
For now it’s best not to install the drive into the drive bay. Stand it up next to your case or lay it down flat with a sheet of paper under it. Connect the power cable to the drive. Plug in the PC's power cord & power up the PC & start pressing the delete key every two seconds until the bios main menu loads. You should see the Primary Hard disk drive listed at the main menu. Now go to the title Boot in the bios. Open boot order. The boot order of the devices should be as follows.
Boot device 1. (Floppy Disk Drive)
Boot device 2. (DVD Disk Drive) [None shown it’s not connected to the system].
Boot device 3. (Model number of your Primary IDE Master HDD).
Once this is set, save the bios & exit. The system should auto restart & windows should load. Let windows finish loading. Than shut down windows normally.
Unplug the PC's power cord. Since you had to remove a DVD drive you'll need to set the remaining DVD player's jumper on the drive to a Master & connect the data cable & power cord to it. (You may have to remove the DVD to see where the Master pins are located. It will be marked on the DVD player near the pins).
Now take you're new drive, do not insert it into the drive bay. Look at you're Master drive's white label. Set the jumper on the master drive first. It should be set as a Master drive with a slave.
Connect a jumper for this.
Go to you're new drive. Again look at its white label. Set this drive's jumper as a Slave drive. The Master drive should be connected to the end of the data cable. The new slave drive should be connected to the next in line connector.
Once all data cables & power cables are connected plug in the PC's power cord & boot the system, again pressing the delete key every two seconds until the boot main menu loads. Now you should see the Primary IDE Master drive & you're new Primary IDE Slave drive listed. You should also see the DVD as the Secondary IDE Master. Go to the title "Boot" again. Set the boot order as mentioned above. Save & exit the bios. Windows should load as it did before. Once windows has finished loading open windows Explorer & see if you're new slave drive is listed.
Shut down the system & unplug the power cord. Unplug the slave drive & mount it into its drive bay. Take a black marker & mark the side of the drive as slave. Disconnect the Master drive & connect it into its drive bay. Reconnect the data cables & power cables. Check all connectors before closing the case up. Re-connect the PC's power cord & boot the system. Everything should be fine. If you have a problem getting the data cable connected to the slave drive because its closer to the DVD drive as opposed to the Primary IDE Master drive you can make the slave drive a Secondary IDE Master (Change its jumper setting according to the drive’s label for Master with a slave) & connect the DVD player as a Secondary IDE Slave. (Change its jumper to slave). Change the Primary IDE Master drive’s jumper as a Master with no slave, single drive. That all.
Good luck emceedrive!
Take your time. Any troubles please post here.
You should be fine though.
Mike
Aug 11, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
