Question about Insignia Kix MP3 Player
Why can't I sync onto my mp3 player???
I keep getting an error message from windows media player when I try to sync... WHy???
    Problem Solver:
  • 14 Answers
Well Basically you need to try and Refresh it if that does not work try formating it.
Posted on Apr 17, 2009
Philips GoGear HDD6330 MP3 Player will not sync music files onto it? How do I fix that and has deleted all previous ones! Please help>
This could be the player's connection mode in combination with your synchronization software. If you are using Windows Media Player or Philips Songbird to sync, the player will need to be set for MTP connection mode. Most other software that works with regular flash drives will need the player set for MSC connection mode. Whatever you are using, simply try the other mode.
To change the connection mode, select "PC connection preference" in the Settings menu of the player.
If you found this information helpful, please indicate as such.
Apr 12, 2010 | Philips GoGear HDD6330 MP3 Player
I have not been able to copy CD's onto the MP3 player. I keep getting a formatting error when trying to convert even though I am using WMA and have tried MP3.
mdcope2 - delete the msuic files that you already ripped from CD off the GoGear. If you Rip a song in WMA, and then re-rip it in Mp3 format, when you go to sync the mp3 file, the GoGear will basically ignore the new file, because it thinks that the file is already on the GoGear since it has almost the same name. Once you have deleted the affected songs, re-Rip the songs in Mp3 format using Windows Media Player. This time, when you go to sync the songs, it will work.
Guest - to load video files onto the GoGear, you have to convert and sync them through the Philips Media Converter - no other method will work.
-Tha Mp3 Doctor
Mar 02, 2009 | Philips GOGEAR SA6045 MP3 Player
How Do I Put Songs On My MP3 Player
You go to your files, then open in another window your MP3 player's folder (Go to My Computer -> removable drive), then drag the mp3s that you want
Feb 14, 2009 | Dell DJ MP3 Player
Syncing with Windows Media Player
Place the music files that you want to transfer into the My Music folder of your computer - Windows will re-read them, and then you can synchronize to your device. Also, make sure the hold/lock switch is not engaged on the mp3 player - it probably isn't, but just check.
-Tha Mp3 Doctor
Dec 25, 2008 | GPX MW-238B MP3 Player
My Phillips Go Gear 8GB MP3 player wont sync music
Windows Media Player 11 ruins this player. Uninstall Windows Media Player 11, and roll back to Windows Media Player 10. Then use version 10 to sync songs to your device.
Sep 11, 2008 | Philips GoGear HDD1830 MP3 Player
Error Message when Sync-ing to Philips sa3125/02
your player does not support any protected files, Protected files transferred to the player will be skipped without playing.
whats the error you get?
Dec 07, 2007 | Philips SA3125\02 MP3 Player
YP-U2JXB & YP-U2JZW Won't sync...Help!
Error C00D1236 virtually always indicates one of two things:
1) The device is trying to sync hidden files--are there any?
2) There is licensed media that is being synced, and the license is either corrupt or has expired. If you have any licensed media, then try going back to where you purchased it (in an iTunes-like music management program? In WMP?) and refresh/renew the license.
The bad news is that until C00D1236 is resolved, you can't sync your device. frown.gif
You can bypass syncing, and directly transfer files, In my computer, the mp3 plaer will be shown as a drive.
Now if one of the two solutions above is not feasible for u, try this:
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
CLICK Here to Download : Firmware Update
This error is common with Windows Media Player
Here is the instruction:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Nov 22, 2007 | Samsung YP-U2X Digital Media Player
Cannot Load Songs onto iRiver H320 Player
1. if your player is not working properly just reset it by using paper clip on the hole and press down the player will turn off then try again
Oct 17, 2007 | iRiver H320 MP3 Player
Open Questions:
Insignia Kix MP3 Player Logo
80 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
