Networking hi sir i want to know how to cable the network in LAN. then i don't no difference between color of that wires please guide me detail
  • Anonymous Apr 10, 2008
    nesesito draivers de la cam usap aw-1130
  • rofimor May 18, 2008
    I need a user manual to conect 2 pc to internet using encore ENH905-NWY, can you help me?
Wich hub highst ferfoms plz give me answer
Posted on May 07, 2008
    Novelist:
    Scholar:
  • 70 Answers
Only pins 1,2,3 & 6 are used in today's local area networks. Pins 1 and 2 are one pair and 3 and 6 are the other (receive/transmit). Depending on the standard used (Telephone/Electronics Industry Association TIA/EIA) 568A or B, pin 1 may be green/white (white with a green stripe) or orange/white (white with an orange stripe). Pin 2 will be the opposing pair color...green with green/white or orange with orange/white. Pair 3/6 will be the opposite pair...green or orange. While typical network wiring (PC to router or switch) is pin 1 to 1 and 2 to 2, etc. (straight through), crossed-over (pin 1 to 3 and 2 to 6) is still used in older networks where you are connecting switch to switch or router to router and the device doesn't contain an auto-sensing polarity capability. Today's network device ports are usually intelligent enough to detect and correct this situation. These are the basics. You shouldn't build your own cables with solid conductor cable unless they are not going to be moved. Typical home-made cables will become flakey the moment they are moved because of the cables.
Posted on Nov 26, 2007
  • 82 Answers
This is stright cable.It is used to hub/sw to computer. Orange of white-orange-green of white-blue- blue of white-green- brown of white-brown. This is cross cable.it is use to connect device to device only one sided and one sided stright cable green of white-green-orange of white-blue-blue of white-orange-brown of white-brown remember this jack plain part should be up side when you create a jack.
Posted on Sep 21, 2007
If u want to create network either in your home or in your office. any were there is a standard given by IEEE. if u want to connect difference devices like your computer and switch/hub. u go to straight cable. colour combination is wihte orange-orange-white green-blue-white blue-green-white brown-brown. and crimp it properly. if u want to connect same devices like computer to computer or switch/hub to switch/hub u go to cross over cable. one side u crimp as mentioned above but on the other end u connect as given below color code that is : white green-green-white orange-blue-white blue-orange-white brown-brown. good luck. purushotam
    Problem Solver:
  • 13 Answers
Blue is standard and yellow is usually a cross over cable. You only need straight thru cables..not crossover. The cable from the modem if you have high speed goes to th einput port on the router and then a cable goes from the router to as many computers you nee. provided there is enough ports
Posted on Sep 19, 2007
    Scholar:
  • 132 Answers
This site will give you directions on how to make a CAT5 cable. http://www.computerhope.com/issues/ch000639.htm
Posted on Sep 18, 2007
SOURCE:
I dont understant about Ethernetpedia app some people says that its an informative app for those person which want to know about networking cables?
In layman's terms Ethernetpedia is a user manual/step by step guide for fixing the network cables
The Ethernetpedia application is about helping customers to understand the in depth of networking cables that are used to connect one network device to other network devices to share printer, scanner etc. Different types of network cables are used depending on the network's topology, protocol ,size and structure. The comparison sheet option is included for the enhancement of a customer for the proper knowledge of the cables. This application includes the product information of major cables like Cat5e , Cat6e etc .Easy to use diagram, straight and crossed cables as the installation guide provides you the easy solution for the installation of cables. The application is available in English at the moment will be updated in different languages afterwards.
Dec 06, 2014 | Microsoft Computers & Internet
Sir i lost my wireless network name and my wireless network password
to get back you wireless information,first you have to connect you laptop hard wired to the router using the ethernet cable, then open a browser and access the firmware of the router,usually for dlink routers,the default gateway to access the router is(10.0.0.1),but if you don't know the default gateway, you can go to the network connection by typing (ncpa.cpl) in the run box or the start search from the start menu. look for "LAN or Highspeed Internet or Local Area connection" then right click on it and select status. Note:make sure that the laptop is propperly connected via network cable.
you will have the "status" page.
for winXP: click on support tab and look for the "default gateway"
for win vista and win7: click on "details" button and look for "ipv4 default gateway"
The "default gateway" number including "dot" needs to be typed in the address bar of your browser.
The router then will ask you to enter the username and password,which is located in the back on side of the router. After you got to the router page, on the left pannel,click on "wireless settings" there you will see you wireless information.
Sep 22, 2011 | D-Link DIR-615 Wireless Router
I hav a Dell inspiron 15 laptop and i have taken wired internet connection. but somehow my lancard has stop working and i am not able to access internet. can you please tell me some alternative to lan...
you can do a quick troubleshooting on the laptop.
1. used another network cable and check that no pins are broken on the laptop.
2. go to device manager and remove the network adapter and reinstall it.
if this don't work. if you have a wireless router, you can connect to the internet over the wireless network adapter on the laptop.
good luck!!
Aug 31, 2011 | Dell Ethernet Card Network Adapter
I bought a nintendo wii,and I don't know if I need a wii LAN adapter to get internet and I have a wired network,but my friend told me she has internet and her network is wired and she doesn't have...
The only network adapter integrated into the Wii is wireless, you will need a network adapter to use a wired network.
Please see the official site for more details: http://www.nintendo.com/consumer/systems/wii/en_na/acc/wiiLAN.jsp
Thanks, and as always a vote/feedback is appreciated. =)
May 30, 2011 | Nintendo Wii Console
Sir can i connect two pcs one desktop and other laptop for sharing files bw the two and playing games bw them
There are a couple of ways you can network two computers together.
Each computer must have a network card installed together with the LAN card drivers. The two computers needs to be connected to a network hub and these computers need to be set up on the same workgroup name.
Using a network hub will allow more the two computers to be connected to a network and the number of computers that can be installed on this network depends upon the number of available ports on the network hub.
You can use a Crossover LAN cable to connect the two computers together and you won't need a network hub.
To information and how to setup a home network, please click on this link -
Home Network Guide, routers, print servers etc.
http://sites.google.com/site/networkguidedemo/home
Jun 20, 2010 | Computers & Internet
Up wirelessly with my home network.My printer is showing as offline on my computer, how can i get it back online. I have it set
The BRAdmin Professional utility for Windows® is designed to manage your Brother network connected devices such as network-ready Multifunction devices and /or network-ready printers in a Local Area Network (LAN) environment. For more information on BRAdmin Professional, visit us at http://solutions.brother.com.
Installing the BRAdmin Professional configuration utility
1 Put the supplied CD-ROM into your CD-ROM drive. The opening screen will appear automatically. Follow the on-screen instructions.
2 Click Install Other Drivers or Utilities on the menu screen.
3 Click BRAdmin Professional and follow the on-screen instructions.
Setting your IP address, Subnet Mask and Gateway using BRAdmin Professional
2 Click Devices, then Search Active Devices. BRAdmin searches for new devices automatically.
3 Double-click the new device.
4 Enter the IP Address, Subnet Mask and Gateway, and then click OK.
5 The address information will be saved to the machine.
You can use the BRAdmin Professional utility to set a password. (See the Network User’s Guide on the CD-ROM.)
Start BRAdmin Professional, and choose TCP/IP.
Note
49
For Network Users
BRAdmin Light configuration utility (For Mac OS® X users)
The Brother BRAdmin Light software is a JavaTM application that is designed for the Apple Mac OS® X environment. It supports some of the features of the Windows BRAdmin Professional software. For example, using the BRAdmin Light software, you can change some network settings on Brother’s network ready printers and multifunction devices. The BRAdmin Light software will be installed automatically when you install the MFL-Pro Suite. Please refer to installing the driver and software in this Quick Setup Guide if you have not yet installed the MFL-Pro Suite. For more information on BRAdmin Light, visit us at http://solutions.brother.com.
Setting your IP address, Subnet Mask and Gateway using BRAdmin Light
If you have a DHCP/BOOTP/RARP server in your network, you don’t have to do the following operation. The print server will automatically obtain its own IP address. Make sure that version 1.4.1_07 or later of JavaTM client software is installed on your computer.
1 Double-click the Macintosh HD icon on your desktop.
2 Choose Library, Printers, Brother and then Utilities.
3 Double-click the BRAdmin Light.jar file. Run the BRAdmin Light software. BRAdmin Light searches for new devices automatically.
4 Double-click the new device.
5 Enter the IP Address, Subnet Mask and Gateway, and then click OK.
6 The address information will be saved to the machine.
Note
50
For Network Users
How to set the machine’s network settings to wireless
Restoring the network settings to factory default
LAN or wired LAN
To connect your Brother machine to a wireless or wired network you must configure the machine from the machine’s control panel for the network type you are using.
For wireless LAN On your machine, press Menu. Press a or b to choose LAN and press OK. Press a or b to choose Network I/F and press OK. Press a or b to choose WLAN and press OK. The wired network interface will become inactive with this setting. Press Stop/Exit.
It will take about a minute for the LAN menu on the LCD to become available again.
For wired LAN On your machine, press Menu. Press a or b to choose LAN and press OK. Press a or b to choose Network I/F and press OK. Press a or b to choose Wired LAN and press OK. The wireless network interface will become inactive with this setting. Press Stop/Exit.
To restore all network settings of the internal Print/Scan server to factory default, please follow the steps below.
1 Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
2 Press Menu. 3 Press a or b to choose LAN.
Press OK. 4 Press a or b to choose Factory Reset.
Press OK. 5 Press 1 to select Yes. 6 Press 1 to select Reboot.
7 The machine will restart, re-connect cables once this is complete.
Apr 29, 2010 | Brother MFC-665CW All-In-One InkJet...
Second computer connected to this model gives message "Network cable unplugged" when it is not! network connection intermittent. What can we do please?
Hi Jackie!
It sounds like a communication problem between the router and the computer. Try the following solutions to solve this:
1.Connect the LAN cable to other free LAN port in the router.
2. Try using a different LAN cable.
3. a. Open Device Manager
b. Go to Network adapters. Click on the "+" sign next to it.
c. Double-click on your network adapter.
d. On Advanced tab, look for Speed/duplex settings (or Media Type)
and change it's value to Full autonegotiation (or AutoSelect).
e. Click OK on all windows.
f. Close the Device Manager and restart your computer.
4. Reinstall or update your network adapter device drivers.
A "workaround" solution - use a wireless network adapter to connect wirelessly to the router.
Hope I helped,
Pelu.
Mar 16, 2010 | Belkin F5D7630uk4A Wireless Router
D-link des-1016d driver
This is a simple network switch and it doesn't require any drivers. You just connect all the computers & other network devices to it using twisted pair LAN cables and that's it.
Dec 13, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
I need to hook up and start using a wireless router, can i get some help starting?
hi licking;
what type of wireless router are you using? a linksys? or a dlink?
do you have color coded cables?
try this:
from your modem(the box given to you by your isp), connect a cable from your modem LAN port to the WAN port of your wireless router.
If your going to connect a pc wired to your wireless router, you can connect a cable from your wireless router LAN port to your lan card of your PC.
give more details and ill be happy to help you. :)
Jun 19, 2008 | Computers & Internet
Computers & Internet Logo
663 people viewed this question
Ekse
Alun Cox
