Question about Kenmore 22422 Top Load Washer
Cant remove agitator. Fabric softener cap is off but i do not see a screw or bolt to remove the assembly. agitator is only weakly working
I cant remove the agitator. I have the fabric softener cup removed and i can see the splines but they only grab going one way. i cant figure out how to take it apart because there is no screw holding the whole thing in place.
  • dianapierce Apr 18, 2009
    Thanks for the suggestion no1helper but there was no bolt to remove. I ended up using a 1/2" driver with a long extension (no socket) which fit perfectly in the square area above it. I just turned it counterclockwise a few times and the whole thing came out. The dogs were worn down and i ran out and got new ones for $9. Now it agitates perfectly!
  • 77 Answers
There should be a 7/16 bolt in the bottom of the cup once you have taken the cup out. Its kinda deep you would need a longer extension. Also this agitator bolt usually has a gasket material attached to it and it may be covered by another cap.
Posted on Apr 17, 2009
I have read the instructions for removing the agitator, but my machine does not seem to allow me to get to a bolt or nut. I have removed the cap from the agitator, but the barrier cap and seals do not...
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets your needs, ..Thank you.
Jul 17, 2011 | Kenmore 22422 Top Load Washer
HOW DO i REMOVE THE AGITATOR FROM maYTAG WASHER MODEL # MAV6457AWW
Gently remove the fabric softener cup off of the top of the agitator
Using a ratchet, an extension and socket; then remove the retaining bolt under the fabric softener cup.
The agitator will lift off after the bolt is removed.
Installation is:
Drop the agitator in place. Install bolt.... tighten bolt with ratchet, extension and socket. Install the fabric softener cup.
Fabric softener cup is item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170378&diagram_id=28464917#d28464917
The bolt you need to remove is item 4 of the above link.
Thanks for choosing FixYa,
Kelly
Feb 05, 2011 | Maytag MAV6457 Top Load Washer
Diplomat ADP 8322 - 11 Flashes. Will not go beyond the Rinse cycle.
There's never a good time for the washer to stop working correctly. If a washing machine's agitator isn't working properly, your clothes won't come clean.
The back-and-forth movement of the agitator is a main function in the cleaning process of your laundry.
If your agitator isn't working, it could be the agitator itself or broken splines in the assembly beneath the agitator. Either one is a relatively easy and inexpensive repair that you should be able to do yourself.
Instructions and material needed :Socket wrench,Rope,Broom,Replacement parts
  1. Inspect the agitator for breaks. If the agitator is broken or cracked, you'll need to replace it. A broken agitator won't operate correctly, if at all. If the agitator looks fine but isn't moving, you'll need to inspect the plastic splines in the agitator assembly located underneath the agitator.
  2. Remove the agitator from the washing machine by first removing the fabric softener dispenser cap on top of it. This cap should either pull or screw off. It it's difficult to remove, you might have to pry it off.
  3. Unscrew the bolt beneath the softener cap with a socket wrench. Once you've removed the screw, try lifting the agitator out of the washer. If it doesn't easily lift out, loop a rope underneath one side of the agitator and over a broom handle. Continue looping the rope under the other side of the agitator and back over the broom. Using caution not to hit yourself in the head, pull up on the broom until the agitator comes loose.
  4. Replace the broken agitator with a new one. Snap the new one in place and secure the bolt underneath the fabric softener cap. Place the cap back on the agitator and you're ready to start washing.
    Check the plastic splines in the assembly directly underneath the agitator, if the agitator itself isn't broken. If the plastic splines are broken or worn down, this will keep the agitator from properly moving. In fact, it might not move at all. Replace the spline assembly with a new one and reassemble the agitator by reversing your steps to remove it.
Good luck and thanks for using fixya.
Dec 24, 2010 | Dishwashers
How do i remove the agitater to clean under it
Hi. The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly, which is removable as well. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to preform a combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle or something of this nature against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Apr 23, 2010 | Frigidaire Washing Machines
Want to remove agitater, there is a loud scraping noise during spin
Nov 07, 2009 | Maytag Washing Machines
I can't get top part off the agitator
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
If you have a 2 part agitator assembly (Fabric softener dispenser, top agitator and main agitator)
First, push down on the ring around the bottom of the fabric softener dispenser and lift it off the agitator.
Pry the top cap (a short screwdriver into the slots in the cap works) of the top agitator.
Looking into the center of the top agitator, you'll see a plastic piece with a 1/2" square hole. Using a 1/2" socket set extension, unscrew the piece carefully. You might have to hold the bottom agitator in place while you do this.
The top agitator pulls up.
You'll see a bolt and screw holding the bottom agitator on. Carefully unbolt this one and the entire bottom agitator will pull up.
Sep 27, 2009 | Washing Machines
How do you remove agitator off of a GE Prodigy
Jul 17, 2009 | GE Profile WPRE6100G Top Load Washer
One part of agitator moves the other part doesnt.
Two-Piece Agitator: Bottom Works, Top Does Not - Whirlpool brands
Some Whirlpool brands washing machines employ a two piece agitator. The bottom is call the agitator and the top is usually referred to a 'Mover'. A multi-piece cam and bearing assembly connects the two and allows the top portion to index.
If the bearing or cams become stripped or damaged, the mover will often not work. Fortunately, Whirlpool produces a cost effective agitator repair kit that replaces all of the critical components in this cam assembly. There are three different repair kits. They differ in the height of the cam.
Agitator Removal Instructions:
Remove Dispenser or Cap:
Some models of washing machines utilize a fabric softener dispenser that resides on top of the agitator. This dispenser simply snaps onto the top of the agitator. Other styles utilize a decorative cap. To remove the dispenser, simply grab it and firmly pull up. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (mover). Use a twisting or prying action to pop the cap off of the agitator.
Remove Internal Debris Cap:
Inside the agitator you will see a cap with a raised handle, much like that of your automobile. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring.
Remove Agitator Stud:
When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt (agitator stud).
Remove the Upper Agitator (Mover):
With the bolt removed you should be able to remove the upper half of the agitator (mover) by simply pulling up. Sometimes pulling up will actually remove the whole agitator assembly. If this happens, place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator.
Remove the Cam and Clutch Dogs:
When you remove the upper agitator (mover) it contains the cam and clutch dogs. Tun the assembly upside down. The cam and dogs should then come out.
-- Stop Here if Replacing Cam Kit --
Remove O-ring:
The lower agitator remains on the transmission shaft. On the top of the agitator, there is an o-ring. Remove this o-ring.
Pull the Lower Agitator:
All that remains is the lower agitator. This can be removed by simply pulling straight up on the agitator.
Agitator Installation Instructions:
Set Lower Agitator:
Slide the lower agitator onto the transmission shaft. Rotate the lower agitator until the splines in the shaft match those in the agitator. Once aligned press the agitator down. Install the o-ring into the top of the lower agitator.
-- Start Here if Replacing Cam Kit --
Assemble Cam and Dogs:
Turn the cam upside down. Place the small round ear of the dog into the corresponding slot on the cam. Repeat this for each of the four cams.
Install Cam and Dogs into Upper Agitator:
Invert the Upper Agitator (mover) and slide the cam/dog assembly inside. The cam should be pushed into the mover until it shoulders. Then rotate the whole assembly upright.
Install the Upper Agitator (Mover) on the Lower Agitator:
The lower agitator has two tabs that stick up that are 180 degrees apart. These tabs fit into two slots on the bottom of the cam. Align the matching tabs and slots and place the Upper Agitator (mover) and cam assembly onto the lower agitator. Push down until the cam snaps onto the Lower Agitator. If the dogs fall out during this step it is necessary to return to the 'Assemble Cam and Dogs' section above and start over.
Install the Agitator Stud:
Place the bolt (agitator stud) into the hole in the bottom center of the cam. Use a socket kit or nut driver to tighten the bolt .
Install Internal Debris Cap:
Install the o-ring into the groove on the OD of the debris cap. With the o-ring in place, push the cap into the Upper Agitator (mover). It is important that the cap is pushed past the ports in the Upper Agitator (mover) so that the wash water can enter and exit as designed.
Install the Dispenser or Cap:
The final step is to replace the top cap. Both the cap and the dispenser simply snap into place. Just make sure they are installed as far down a they will go and are firmly in place.
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How do you remove the agitator on a Maytag Dependable Care Washer?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
I hope this helps you.
PS If the problem is due to the build up of fabric softener, soak in some hot water to loosen it up. Fabric softener is essentially a form of liquid wax and it is common for it to accumulate and clog the dispenser in this manner. Periodic cleaning is recommended.
Aug 09, 2008 | Maytag Dependable Clean Top Load Washer,...
GE agitator does work
Dec 20, 2007 | GE WBSR3140DW Top Load Washer
Kenmore 22422 Top Load Washer Logo
242 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
