It sounds that the problem to your TV is with its DVD loading tray. A pure mechanical fault indeed. Not loads the disc properly to its seating. A motor fault, or a gear wheel fault, or a leaf switch fault could be. Anyway, you have to take the DVD mechanism out from the TV, to get the actual problem could be resolved. Really this is a semi skilled work. It will be best to contact any service technician in this case.
SOURCE: Need code for technika tv
i have bought a one for all tv controller and it doesn't have the code for a technika tv
SOURCE: technika tt-16 universal remote control codes for a beko tv
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
SOURCE: technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
SOURCE: technika tv cant get universal control to work
1 turn on the tv
2 press the code button on the universal
3 then press and hold the power button until the tv turns off, and that's it
