Question about Lexmark E238 Laser Printer
How do i fix a paper jam?
There is a piece of paper in the printer
    President:
  • 1,996 Answers
Unfortunately, Lexmark's site doesn't allow direct links to support pages, but if you go here and enter your model number, you'll have access to the instructions for clearing a paper jam.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 17, 2009
Fix paper jam 2 on a Samsung CLX-3170 printer
paper jam 2 is a jam in the fuser/exit area.
did the paper jam come out in one piece? if not reassemble the torn paper to see how much is still inside.
sometimes there will be a small fingernail size piece of paper holding open the fuser/exit sensor flag.
sometimes the sensor flag itself is dislodged and needs reassembly.
attached is video in how to dissassemble the printer if required
Sep 24, 2014 | Samsung Office Equipment & Supplies
Epson 837 printer error
OK, often when removing a paper jam this can happen:
1) - when pulling the jammed paper out you can leave behind a small piece or loosen up another small piece from a previous jam. This piece can then become the 'new' jam by clogging the jam sensor or switch. Use a small flashlight to look done the previous jammed area to see if this is the case.
2) - when pulling the jammed paper out you can 'mis align' or damage the jam sensor (or switch) so that it always registers a jam. this fix may require a technician or repair shop to fix.
Feb 04, 2014 | Epson Artisan 800 All-In-One InkJet...
There are pieces of paper jammed inside the printer. I cannot access them by raising the scanner. I could see a small piece but after the ink holder adjusted when I turned the machine back on, the small...
I have mine apart right now trying to fix it. I was able to get my paper jam fixed (had the same problem) by putting another piece of paper through when it tried to roll the jammed paper out.
Does that help?
Aug 13, 2011 | Epson Stylus NX400 InkJet Printer
How do I fix a paper jam? I have a piece of paper that went in slightly sideways, and now its jammed. It's almost halfway in, so I'm afraid to pull on it in case it rips and pieces are left. Is there way...
You won't be able to make the printer work backward and push the paper out. Start by powering OFF the printer (unplug it if necessary). Then look to open up the front/top/back as appropriate to clear the paper jam. Frequently, if you pull straight and carefully (slowly), the paper will come out in one piece and solve your problem. If any pieces are left inside, remove them all before attempting to power ON the printer. If in doubt as to clearing, read the user manual - troubleshooting section on clearing paper jams. Good Luck!
Aug 13, 2009 | Brother HL-2040 Laser Printer
Printer will not work after paper jam fixed
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 09, 2009 | Canon iP4500 Photo Printer
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
alternative :
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper jam
check paper jam error you need do:
1) between paper input tray and cartridge check any pieces paper
2) between cartridge and fuser area do same thing
3) check fuser and pressure roller(near fuser) any pieces of paper there
4) after fuser to output tray
all above step checking for avoid any pieces paper obstruct any sensor through all paper road, so that cause jam error
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 25, 2009 | Brother MFC 8500 All-In-One Laser Printer
Paper jam.
try this, its probably a small part of jammed paper inside or then theres a problem with the paper pickup, try cleaning it.
alternative :
Oct 26, 2008 | Lexmark X83 All-In-One InkJet Printer
How do I get fix a "carriage jam"?
I was able to run run a piece of photo paper through a couple of times and printer now seems to be working again. The theory was that running a heavy piece of paper through might help clear little piece of paper that was not visible. The photo paper is less likely to tear if it gets jammed too.
Apr 18, 2008 | HP Photosmart C7180 All-In-One InkJet...
Paper Jam
Probably some piece of paper stuck in the printer, try looking for small pieces of paper that might confuse the sensors.
May 19, 2006 | HP PSC 1610 All-In-One InkJet Printer
Lexmark E238 Laser Printer Logo
122 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
