Question about Canon GL2 Mini DV Digital Camcorder
Camcorder won't start
I was using the camera when for some unknown reason it shut down. Now, it won't startup or even eject a tape. I have taken the battery out and tried plugging it in. Nothing has changed. Any thoughts would be appreciated. Thanks
  • 64 Answers
On that model theres a ferrite core on the bottom that if it comes loose from dropping or over time it will hit the main pcb and break it theres six small screws holding the bottom cover on and towards the front there is what looks like two magnets with a flex goin through them that is the ferrite core there should be two pieces of white tape that looks like a plus sign over the ferrite core if its moving freely then it more then likely hit the main pcb and caused it to break and cause the camera to have no power
Posted on Nov 17, 2007
There is a standby lock switch that is easily filpped by mistake. This will shut your cam down quick, just flip it back to standby. Denis @ ByrdsEye Video www.byrdsvideo.com
Posted on Sep 19, 2007
    Champion:
  • 217 Answers
You need pro fix, sorry.. [:0(
Posted on Sep 18, 2007
SOURCE:
Unit will not stay on. Turn power on unit with no tape. After several seconds cycles off. I am using the aux. to monitor a cctv camera.
VCR's with faulty mechanisms will power down to prevent tape damage. Checking inside might reveal damage to the tape mechanism. Even if the mechanism isn't damaged the VCR has a device called the mode switch. These tell the electronics what position the mechanism is in. If that goes faulty the electronics can think that mechanism is in say playback mode, even when it's in eject mode. So when it detects no tape tries to stop and eject the tape. Since it can't carry out this it shuts the entire video down to be on the safe side and prevent further damage.
Mar 15, 2015 | Emerson EWV404 VCR
Shuts off when eject button hit.
does it open when you when you connect it direct to the wall scoket.
Jun 04, 2008 | Quasar VM-L153 VHS-C Camcorder
My VHS tape is stuck and won't eject or plsy
The transport mechanism ff/rewinds and drives the tape back into the cassette when eject is used.
Most likely a bad belt or the drive idler wheel (rubber or geared). Unit would have to be taken apart to "see" what is not happening.
Oct 22, 2012 | Televison & Video
Jammed by putting tape in upside down
Take off the battery on the camcorder. Insert the battery and at the SAME time, push the power and the eject to see if this resets the camcorder so it will eject. If this does not work, I'm afraid the unit will need to be taken apart and removed manual. Good Luck
Jun 25, 2007 | Sony Handycam CCD-TRV37 Camcorder
Cassette jammed after camera dropped
I think your ejecter motor is not working.temporarily open with any tool.
Dec 10, 2008 | Sony Handycam CCD-TRV107E Camcorder
Unknown sign
Most likely the lithium Ion battery has been discharged. Leave it plugged in for 24 hours without turning it on and it should charge the battery.
Sep 11, 2008 | Sony Handycam CCD-TRV68 Camcorder
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Canon GL2 Mini DV Digital Camcorder Logo
96 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
