Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi VS-45607 Manufactured in 2001. Set will have a picture for about 20 seconds, then it will discolor and shut off.
  • Tzman303 Sep 18, 2007
    Thanks!!! The code sequence is 2 - 2.
Also 22 is low voltage protect, could be convergence amps. check solder connection in this area, if non then may need replacing. the big STK's
Posted on Sep 20, 2007
    Genius:
  • 1,153 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source)When you find the numbers, let me know.
Posted on Sep 17, 2007
  • Lashawn Robinson Sep 19, 2007
    CHECK C2V29 22 UFD @ 16 V OFF PIN 29 OF IC2V00 ON THE SIGNAL PCB
Is this Tv HD? Molel # VS-45607 Mitsubishi
I am sorry to say that your set is not compatable with HD.
Although you should still get a good picture.
I hope that this helps.
asnowman
Jul 22, 2010 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 turns off immediately when I try to power up
STK ICS replace Both of them STK393-570 big black ICs will have STK on them Call mats for parts 1-800-628-1118
Dec 20, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vs-45607
Good Day, chefkenny;
This the fix ya you are looking for;
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Aug 07, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
This should resolve your TV"s condition.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
TV keeps shutting off
Push the menu and inputs buttons on the set in both together and hold for 8 seconds this should make the led flash a two digit code. Let me know what happens after doing this test.
Apr 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 Picture flickers and dims
It could be a bad solder connection that opens up as the set warms up. It could also be caused by a couple of bad capacitors, C2p05 (100uf/16v) Located By Ic2p01 and check C2c52 (10uf/50v) Located near Q2c51. A technican will be able to fix it for about what you paid for it I suppose.
Jan 24, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 picture goes out intermittently
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Dec 13, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
