Question about D-Link AirPlus G DWL-G710 Wireless Range Extender
Why can't I access the Url http://192.168.0.30
  • 560 Answers
Check your IP address and see if the computer you are using is on the same subnet. your IP must be 192.168.0.xx where xx is any number. if you get a different IP address, use a static IP address between 192.168.0.31 to 192.168.0.40
how to check IP:
click Start - Control Panel - Network Connections - right click Local Area Connections - click Status - Details.
how to use static IP:
click Start - Control Panel - Network Connections - right click Local Area Connections - click Status - Properties - TCP/IP - choose Static - use any IP address in the range above.
click apply and try to access your repeater again. I am assuming that you have given the correct IP of your repeater.
Posted on Apr 25, 2009
2 Suggested Answers
halbrook
  • 560 Answers
SOURCE: Cannot access the URL addres http://192.168.0.30 (page cannot be displayed) any suggestions?
check your IP address and see if the computer you are using is on the same subnet. your IP must be 192.168.0.xx where xx is any number. if you get a different IP address, use a static IP address between 192.168.0.31 to 192.168.0.40
how to check IP:
Why can i not access facebook.com without it saying Invalid URL The requested URL "/avgfree", is invalid. Reference #9.3e556acb.1361849525.8191612
Run your anti-virus to make sure that there is no virus in your computer.
Have you type facebook.com correctly in the address box in your web browser?
David
Feb 26, 2013 | Acer Computers & Internet
I have application error 302
Introduction
Your Web server thinks that your URL has been temporarily redirected to another URL. The client system is expected to immediately retry the alternate URL.
302 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle when it communicates with your Web server:
  • Obtain an IP address from the IP name of your site (your site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from your Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code that it recognises as '302'.
Resolving 302 errors - general
The 302 response from your Web server should always include an alternative URL to which redirection should occur. If it does, a Web browser will immediately retry the alternative URL. So you never actually see a 302 error in a Web browser, unless perhaps you have a corrupt redirection chain e.g. URL A redirects to URL B which in turn redirects back to URL A. If your client is not a Web browser, it should behave in the same way as a Web browser i.e. immediately retry the alternative URL.
If the Web server does not return an alternative URL with the 302 response, then either the Web server sofware itself is defective or your Webmaster has not set up the URL redirection correctly.
Resolving 302 errors - CheckUpDown
Redirection of URLs may occur for low-level URLs (specific URLs within your Web site such as www.isp.com/products/index.html) when you reorganise your web site, but is relatively uncommon for the top-level URLs (such as www.isp.com) which most CheckUpDown users ask us to check. So this error should be fairly infrequent.
The 302 response from your Web server should always include an alternative URL to which redirection should occur. If it does, CheckUpDown automatically tries the alternative URL. This in turn may possibly lead to another redirection which CheckUpDown then tries. This continues for a maximum of 5 redirections. As soon as 5 redirections have occurred, CheckUpDown gives up and reports the 302 error for your account. So you should only ever see the 302 error if 1) your Web server gives no alternative URL on the 302 response or 2) the number of redirections exceeds 5. This second condition should be fairly unlikely - and may indicate a recursive pattern e.g. URL A redirects to URL B which in turn redirects back to URL A.
You first need to check that the IP name we use to check for your account is accurate. If you or your ISP have configured something so that any access using this name should now be redirected to another name, then you need to update your CheckUpDown account to start using the new name.
If you believe that the IP name we use is exact (should not be redirected), please try accessing the current URL using a Web browser. Note carefully which URL actually gets displayed, because your browser may silently switch to a substitute URL if it receives an 302 message from your Web server. If you see any evidence of a new URL, try accessing that directly from your browser. If this works (you see your Web site as expected), then this new URL is what you may need to update on your CheckUpDwon account. If this is a temporary redirection, then you may also need to reinstate the original IP name at a later date when the redirection is no longer effective.
If none of the above help, we can analyse the underlying HTTP data streams we receive from your Web server. These can provide additional information about the new URL(s) which your Web server thinks we should be accessing. Before doing this, we prefer you to identify any deliberate changes on your side, liaising with your ISP if needs be.
302 errors should occur infrequently, because top-level URLs do not change often. If they do change, then this is typically because a redirection URL is being suggested. This pervasive change is unlikely to occur by accident, so most often we can resolve this error by updating our system records for your account following a deliberate change of URL on your part, whether this change is temporary or permanent.
Aug 02, 2009 | Dell Pentium 4, 2.26 GHz (1W391)
Need to disable the access of the address bar in IE
hi,
You can use frames to keep your URL fixed while still allowing navigation without revealing the actual URL.
Example: http://www.rgagnon.com/jsdetails/js-0099.html
Alternatively, As your real intention is to prevent users from modifying the URL, consider implementing URL rewriting to scramble the URL so that the actual file path is not obvious. URL rewriting is the process of intercepting an incoming Web request and automatically redirecting it to a different URL.
Check these links for more info on URL rewriting:
http://msdn2.microsoft.com/en-us/library/ms972974.aspx
http://www.aspnetworld.com/articles/2004011901.aspx
Apr 27, 2009 | Microsoft Windows 95 + Internet Explorer...
What is the difference between URL address and link?
URL stands for Universal Resource Locator. The terms web address or link are refer to a URL. A URL consists of several parts including the protocol to use (http://, ftp://, etc), the server (normally set to default to 'www' if nothing is specified), the domain (i.e., fixya.com), the port to use (optional), the location of the resource, the resource itself, and optional parameters to be passed to the resource.
Apr 12, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
D-Link AirPlus G DWL-G710 Wireless Range Extender Logo
466 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
