As I try to convert my IOMEGA hard drive from FAT32 to NTFS, using Windows XP's CONVERT command, it discovers a drty bit on the drive. However, when I test it with CHKDSK, Windows finds no problems at all. How should I proceed? Thanks. Julian
  • greenvb Apr 20, 2009
    Hi Charlie,
    I am happy to report that after renaming my external drive to Z:, I succeeded in using Convert to format it in NTFS. I also had no trouble in copying files from my C: drive to it afterwards.
    I did find an old copy of Norton Ghost in the house and attempt to put it to work in re-formatting my external drive. But I gave it up when I found it time-consuming to learn to use. Thanks again for your thoughtfulness.
    Julian
  • 62 Answers
Does anyone you know have a copy of any sort of disk management tool such as acronis disk director or norton ghost?
If yes, you can copy all the info that you still want to keep with the disk management software, and then do a total wipe and format.
MS convert will not do a complete job under normal circumstances (at least in my experience), so you are better off using a third party software suite.
Posted on Apr 17, 2009
  • charles raynor Apr 20, 2009
    Thank you for letting me know.
    If you need any further assistance, please let me know.
    Also could you be so kind as to rate the assistance given?
How do i remove parameters from a kanguru 4 g usb flash drive?
Which format fat32 or ntfs make sure its fat32 Indeed, FAT32 only supports files up to 4 GB. I ran into the same problem when copying an ~4.5 GB file to an 8 GB flash drive. There is a quicker solution that doesn't require you to reformat or lose data on the drive, using the command-line "convert" command. Suppose the flash drive is mounted to g:\. Open up a command window (start menu -> run -> cmd), and type: convert G: /FS:NTFS. Personally, I don't need the "security descriptors" on the flash drive file system, so I use the variant: convert G: /FS:NTFS /NoSecurity. The conversion should be very quick, and of course it has the benefit of not needing to move any files off the flash drive (since you don't need to reformat it). Hope this helps.
Dec 18, 2012 | Kanguru 4GB FlashBlu II USB 2.0 Flash...
Tip
Convert FAT or FAT32 File system into NTFS
You can increase the performance of your computer using NTFS (New Technology File System) hard drive volume with windows XP, because this advance file system provides some extra features, for example security, reliability, file encryption and Compression features.
But if you are still using old file systems like FAT or FAT32, you can covert it into NTFS with a simple command. The interesting thing is that you can convert your hard drive volumes file system without losing data on the drive. Follow the giving steps to convert FAT or FAT32 partition to NTFS:
  • First go to Start button then click on Run option.
  • Now type here “CMD” and press Ok to open command prompt.
  • At the command prompt type convert drive letter name: /fs:ntfs
  • For example if you want to convert drive E to NTFS then the command will be “convert e: /fs:ntfs”.
  • Now restart your computer and enjoy NTFS features, but keep in mind you cannot covert back it to FAT or FAT32 again.
on Jan 29, 2010 | Computers & Internet
Yyyyyyyyyyy usb dive problem of pen drive
You need to o this anyway so try this and see if you can see your files. your file names in the pen drive may be to long or have characters in them that fat32 cannot see.
Windows XP:
Your computer needs to be NTFS to see the large hdd, and to use files larger than 4 gig. If you computer is Fat32, then it will not see a large external or internal drive when the files in a folder on that drive add up to more than 4gb.
The drive needs to be NTFS because when you start adding files to it, eventually it will freeze.
Fat32 to NTFS
you can change the file system with out losing the data
To Check your hard drive, flash drive or external hard drive do this. They ALL need to be NTFS to handle today's large size file addressing..
Open my computer, right click the drive >properties. In the pop up it will say FAT or NTFS in the file system. If its FAT you need to change it to NTFS to handle large files and drive sizes.
Do it in this order:
1, Open my computer> right click the drive >properties >tools >check now >tick both boxes to clear the disk of any errors, then:
2. defrag the drive (tools)
3. Enter the convert command like this:
say the usb drive is F:
Click Start > Run > "convert F: /fs:ntfs /v /nosecurity /x" without the quotes.
same for your C drive. (paste above convert command and change the drive letter)
I have done this a lot and never lost any data. Just don't interfere or take risks. The biggest risk is a power failure while its doing it. It doesn't take long. If you find it doesn't do the conversion, then run Chkdisk to fix errors then try again.
You can read about it in XP help files.
Click start >help and support >type format in the search - look in the overview.
May 17, 2011 | Computers & Internet
The parameter is incorrect
which format fat32 or ntfs
make sure its fat32
hope this helps
Mar 03, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
I AM UNABLE TO SAVE LARGE FILE IN MY TRANSCEND HDD. IGET THE MESSAGE THAT THE FILE IS TOO LARGE. THE FILE I AM TRYING TO SAVE IS MOVIE FILE.
Make sure that the Transcend HDD is formatted using NTFS and not FAT32. FAT32 has a 4G file size limit, and NTFS does not.
Make sure also that you backup any data on the Transcend drive before formatting.
If the Transcend drive is using FAT32, you might also be able to just go to command prompt, and type in:
CONVERT volume( the drive letter of your Transcend drive) /FS:NTFS
You can also get additional help using the CONVERT command by going to a command prompt and typing in:
CONVERT /?
Feb 25, 2011 | Transcend Computers & Internet
If you are running your computer under ntfs should your external harddrive be formatted the same instead of fats32. If it does can I move my back up from the external hard drive and move it back after...
The external hard drive can remain formatted as FAT32. NTFS and FAT32 are the file systems used by the individual disk drives, and do not effect the data being read or written (i.e., you can transfer data between the two with no worries about compatibility). There ARE differences, however, and many would suggest using NTFS to avoid some limitations with FAT32. For example, FAT32 drives have problems with individual files over 4GB. Formatting in NTFS is definitely recommended for people storing large files like video and other media files.
Yes, you can move any data you have off of your external hard drive (to your system hard drive or another external you use temporarily), format your external hard drive with NTFS, and then transfer your backups and other data back to your newly formatted external drive.
You can also convert the drive to NTFS; but I recommend backing up the data first anyway in case of (rare) problem during conversion. Here is a link that has directions for both scenarios (scroll down for conversion info) for Windows XP. http://www.microsoft.com/windowsxp/using/setup/tips/advanced/ntfs.mspx
The process to convert is similar for Vista and 7; here are the instructions from MS: http://windows.microsoft.com/en-US/windows-vista/Convert-a-hard-disk-or-partition-to-NTFS-format
Feb 02, 2011 | Western Digital My Book Essential Edition...
Can not get hard drive to convert from fat32 to ntfs
Convert FAT32 to NTFS In Windows XP:
  • Click Start -> Run
  • Enter "cmd" into the text field labeled "Open".
  • Click OK button
  • If you want to convert drive D (D:), enter the command "vol d:" in the command window, to find the volume label for the D: partition
  • Then enter the command "convert d: /fs:ntfs" to convert the D: partition from FAT32 to NTFS
  • When prompted, enter the volume label for the partition
Convert FAT32 to NTFS In Windows Vista and 7:
  • Click Start sphere.
  • In the Start Menu search box, simply enter "cmd" and hit enter.
  • If you want to convert drive D (D:), enter the command "convert d: /fs:ntfs" to convert the D: partition from FAT32 to NTFS that way can be confusing so an easier way is to download a free software heres the link http://www.partition-tool.com/personal.htm
Oct 20, 2010 | Maxtor Hard Drive
How can I format my newly bought Seagate 250 GB External Portable Drive into FAT32 system. Are most dvd players now with usb support for divx cannot access external drives that are in NTFS format such as...
You can specify the format type on the option page for format before you press the format button when displaying the drives in "My Computer"
Additionally, you can CONVERT an existing FAT or FAT32 partition to NTFS. Follow the steps below for Windows XP:
  1. Click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  2. At the command prompt, type the following, where drive letter is the drive that you want to convert: convert drive letter: /fs:ntfs For example, type the following command to convert drive E to NTFS: convert e: /fs:ntfsNote If the operating system is on the drive that you are converting, you will be prompted to schedule the task when you restart the computer because the conversion cannot be completed while the operating system is running. When you are prompted, click YES.
  3. When you receive the following message at the command prompt, type the volume label of the drive that you are converting, and then press ENTER: The type of the file system is FAT.
    Enter the current volume label for drive drive letter
  4. When the conversion to NTFS is complete, you receive the following message at the command prompt:Conversion complete
  5. Quit the command prompt.
Sep 21, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I need to change from a FAT to a NTFS to operate on my windows XP
I'm assuming that you are trying to convert an existing hard drive from FAT32 to NTFS...
Is that the question?
If so, boot computer.
click on Start...Run... type in "cmd" and press <enter>
A command prompt will appear (aka "console" or "DOS box")
at the C:\blah\blah prompt, type in
"convert C: /FS:NTFS" and press enter. (substitute the drive letter of the drive to convert for "C:" in the preceeding example)
If you are prompted that the drive is locked and do you wish to mark the drive for conversion at next boot time, answer YES.
Reboot.
Voila!
Mar 06, 2009 | Western Digital My Book Essential 1TB...
Vaio vgn-fs415m
Just go to the Command Prompt and execute the command: C:\> CONVERT C: /fs:ntfs Where C: is a name of the drive you want to convert. After machine re-boot conversion process will start and you'll have your FAT32 converted to NTFS without of data loss.
Nov 10, 2007 | Microsoft Windows XP Home Edition
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
