Question about Dell Inspiron 6400 Notebook
Static crackling sound continuosly
As soon as i turn it on it has a static sound of interference and it doesn;t stop. Ran the f 12 key and nothing showed up as a problem
any ideas?
  • 1 more comment
  • mcruz28pr Apr 30, 2009
    Static Cracklieng sound
  • NIPSZX May 13, 2009
    AUDIO VIDEO IS HORRIBLE CRACKLING AND PAUSING CONTINUOUSLY.
  • archana dutta
    archana dutta May 11, 2010
    is display on screen or not
Crackling subs
After crackling sound they stop and the light on overoald
Dec 29, 2013 | Legacy 12 500 watt l series woofers,...
Subwoofer making static noise
first of all,do u have the strip wire in the red which is the hot side of the sub,next if that doesn't fix it u need to change ur spark plugs they will interfere when the engine is running,so call ur local auto parts dealer and ask for spark plugs that don't interfere with the radio.Hope this helps
Apr 03, 2013 | Power Acoustik Car Audio & Video
Microsoft lifechat lx-3000 headset crackle noises
Go to Control Panel>Large Icon View>Sound>Playback Tab>Right Click The Headset Icon>Properties>Advanced Tab>Change the Default format from CD quality to DVD quality and voila. :D
Feb 01, 2012 | Microsoft LifeChatâ„¢ LX-3000 Headset
I had major static sounds from my yamaha stagepas 500. I plugged in an acoustic guitar into the mixer while running a keyboard and 2 vocal mics. I started getting crackling sounds. I changed the patch...
Chances are there is nothing wrong with the mixer. IF you accidentally turned on Phantom power, that would cause the problem. Phantom is ONLY used with condenser mics and a few DI boxes. Turning it on can create noise unless balanced lines are used everywhere.
Jun 29, 2011 | Yamaha EMX512SC Powered Mixer 500 Watts...
Cd plays when bike is on ,but when you start the motor it doesn't play . and when your riding down the rode the speakers crackle , but doesn't do it when your standing still . whats wrong .the speakers are...
When starting the bike, the starter relay pulls in to divert power to the starter solenoid. To insure that the solenoid gets all the power it needs, the accessories on the bike are turned off momentarily. Once the bike is running, they come back on. The "crackle" sounds like it might be interference from something on the bike, nothing wrong with the speakers or it would make the sound all the time. It's probably pickiing up the impulses generated by the speedometer or something when when the bike is moving but is not doing anything when you're standing still. A dealer may can find it or you can disconnect various accessories and take a ride down the road to see if the interference stops. Once you determine what is causeing the interference, then you'll have to figure out how to stop the interference from affecting your speakers.
Good Luck
Steve
Aug 11, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Static in my panasonic telephones
A possible cause for the static in your cordless phones could be dimmer switches around the area of your phone that causes static. Turn the switches completely off (not just turned down) and see if the static leaves. You can replace the dimmers with regular switches if that clears your static. If it does not, another trace for interference: you will have to take a portable radio and turn it to AM 550 mHz and tune it to the loudest crackling noise. Carry the radio around looking for the loudest static interference. Could be a loose connection in a receptacle or panel box. Any small malfunction can cause static on wireless devices.
Nov 21, 2008 | Panasonic KX-TG1033S Cordless Phone
No clean air smell/crackling & static
To stop the crackling sound, you need to remove all of the dust particles from the wire in the back. Sometimes when the unit is extremely dirty you can see sparks emanating from the wire, this is what causes the crackling sound. The unit has a built in cleaner you can lift up and down to perform this task, located on the top, but this doesn't work extremely well.
I usually take a can of compressed air and blow as much of the dust I can off the wire and all surrounding internal areas as I can. This along with a thorough cleaning of the blades should eliminate the crackling noise. Of course, make sure the device is unplugged before performing any cleaning.
Not sure about the smell though. Mine has started to smell a little strange and I haven't figured out how to fix that problem.
Oct 01, 2008 | Ionic Pro TURBO Air Purifier
Sound interference
As you there seems to be interference via sound as the picture is fine. the interference is a crackling noise& tv is old 1 CHECK SPEAKER 2 so in that case tunning in sound section is disturb get it tnnned. 3 any components in sound section has done defective(SIF)SECTION. 1 CHECK SPEAKER not matching or paper torn or paper cone hard.
Sep 17, 2007 | Televison & Video
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
Dell Inspiron 6400 Notebook Logo
341 people viewed this question
Alun Cox
