Question about Car Audio & Video
I have a lazar amp and
My plus an neg. speaker wires touched shorting the amp out now wont work just red light stays on is it blown up now?
    Scholar:
  • 82 Answers
Yes
Posted on Apr 30, 2009
My red light wont cut off
are they subs or door speakers? if they are subs, then speakers ohm load is too low for the amp. If they are speakers then again the ohm load is too low or one the speakers are blown are shorting out against the door. sometimes when mouting speakers in the door, the terminals are accidentally touching some metal inside the door.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Oct 27, 2014 | Sony Xplod 1200W Car Amplifiers
Red light on on amp
take speaker wires off amp if the lit is green then speaker are hooked up wrong or blown.
Mar 29, 2014 | Pioneer GM-5200T Car Audio Amplifier
My 4 channel amp keeps going into protect mode when i power on,its not a imminet light,but it blinks once then dies out,plz help
Remove all speaker inputs and outs and just have your 12volt battery, ground and radio remote connected and power up the amp. If it turns red instantly, then the amp is shorted/blown. If it stays green, then install your speaker inputs and outs one at a time. make sure your amp is on while your doing this. if the amp goes into protect mode, take note of which wire it was for it's most likely shorted. Fix that shorted wire and the unit should stay on.
Apr 13, 2010 | Car Audio & Video
I turn on my stereo and the receiver says protect why
your speaker wires are touching if the plus or minus or (red and black wires) are touching it can blow the amp this is a protection. Check all the speaker wires on the back and makes sure they are not touching.
Jan 15, 2010 | Sony STR-DE185 Receiver
Unit only stays on for 4 seconds then turns itself off.
This is a short or unstable ohm load. Remove all speaker wire connections to see if the amp will stay on.
If the problem goes away when disconnecting the speaker wires try this:
1) Check volume level on zone one and zone 2 if connected. If it is too high the amp will go into protect mode and shut off exactly as you described.
2) Make sure no wires are touching any other wire or the metal surface of the amp. This will cause a short and send the amp into protect mode.
Nov 21, 2009 | Denon AVR-1705 Receiver
Can't get my amp to work right
Recheck each and every wire connected to the amp. If everything is wired correctly, then you either have a shorted speaker, or a shorted pair of speaker wires, or one of the speaker wires is touching another grounded location, or the amp is blown.
That's about as far as you can take it, unfortunately.
Double and triple check all you wiring. EVERY wire! Don't assume anything about any single wire.
Nov 16, 2009 | Power Acoustik PS2-820 Car Audio Amplifier
Amp is going out.
Have you tried replacing all of your fuses? If that does'nt work check your ground........ I would check all your connections also could be a connection shorting out causing your red light to come on.
May 10, 2009 | Car Audio & Video
Neg and a pos on each side of car speakers
Depends on your amp. If they are dual 4 and your amp is 1 ohm stable and you have 2 subs, wire red to red and then red to plus on the amp. If your amp isnt 1 ohm stable wire ch1 red to + on amp, ch1 black to ch2 red, then ch 2 black to - on amp. If this sounds like french to you, go to a stereo shop in your area and pay them to hook up your stuff. It will be a lot cheaper than buying a new amp and subs.
Dec 18, 2008 | Digital Audio DA8012 12" Subwoofer Car...
When i turn on the cd player the sound from the components vuts off but the sound coming through the subwoofer stays on??
The Sub gets it's output from the pre-amp circuit, whereas the components get their output from the main amp circuit in the unit.
Sounds like it could be a short in the speaker wiring or a blown speaker. Check all wiring to the speakers.
Check all speaker wires from the unit to the speakers.
First check that each pair of speaker terminals at the speaker end is not touching. Or, a wire fell of 1 terminal to rest on another.
Best way to check if it's a blown speaker or a wiring short, is to disconnect all speaker connections ( at the speaker end ) making sure the disconnected wires don't touch each other or any metal in the car. press the reset on the unit and power up. If the unit powers up ok, then its a blown speaker.
Otherwise it's a short in the wiring.
If it's a blown speaker, you can connect 1 speaker at a time and the blown 1 will send the unit into protect mode again.
If it's the wiring, disconnect the unit from the wiring and use and ohm meter to check each pair of cables. A reading suggests a short.
If you don't have an ohm meter a battery and bulb will do. This method usually works on a short.
If you have no joy with either method, take each speaker wire in turn and check with a source of earth (anything metal connected directly to the body of the car, cigar lighter main body when pulled slightly out is good)
Regards
Philip
Jul 20, 2008 | Car Audio & Video
Concept CC-2502 Car Audio Amplifier
The amps are probably going into protection mode. The wires are most likely not hooked up correctly. Make sure you have a good ground, good power source, and the remote wire is run correctly. Also make sure the speaker output wires aren't touching each other, and you have the correct ohm load for the amp. What kind of speakers/subs are hooked up and how are they wired?
Sep 20, 2007 | Concept CC-2502 Car Audio Amplifier
Car Audio & Video Logo
83 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
