Question about Craftsman 20 Hp 42" Deck Lawn Tractor
When my 20hp Craftsman lawn tractor cranks it does not quit pumping gas in to the carburator, and floods it out - what do I need to look for??????
  • 35 Answers
Sounds like you have a Float in the Carb has a hole in it or it is getting stuck open there is a needle valve that it pushes on when the bowl is full and it sounds like its not or something is stopping it,, did it have gas in it all winter? ,, I would buy a Carb kit for that model and change out all the parts that come in the kit and clean the carb
Posted on Apr 17, 2009
Craftsman 20hp lawn tractor blades won't engage
check to make sure your cable is in tact its called a pto clutch cable about 20 buck on ebay it may be broke inside
Sep 26, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
My 2001 craftsman, 20hp lawn mower will not start for flooding the cylinders, what could cause it from putting too much fuel in there
with the newer fuel that we have the needle valves in the carb don't seat anymore replace the needle and seat change the oil if possible add a shut off valve inline to the carb and close it when not in use
Jun 24, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
B&S 20hp craftsman 46" dls3500
When you cleaned the carb did you clean out the metering jet with a needle and blow out. It only takes a tiny spec of dirt to raise hell with these small carbs.
May 29, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
I HAVE A 2005 CRAFTSMAN LT1000 LAWN TRACTOR THAT IS ALLOWING GAS TO GO TO THE SPARK PLUG. I DRAINED THE GAS AND UNSCREWED THE SPARK PLUG AND THE TRACTOR CRANKS. I REPLACED THE SPARK PLUG AND THE TRACTOR...
It sounds like the carby is flooding badly. Check that the float needle in the carby is sealing properly. You need to remove the float bowl on the bottom of the carby and hold the float up with your finger and check that the fuel stops flowing out when you do this. Regards Phil
Apr 14, 2011 | Craftsman Garden
Lawnmower sat up for a season would not crank replaced sparkplugs air filter fuel filter hose fuel pump is pumping gas to carburator but still will not start unless you pour some gas into the carburator or...
If it will start when you pour gas then its a fuel problem on some of these they have a screw at the bottom of the carb remove that and see if you have bad fuel. If that does not work then remove the carb and service it may just be a stuck float or something
Aug 09, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Have gas in oil - will not start
Gas in oil is usually a symptom of flooding, caused by a stuck needle valve or damaged float in the carburetor. But 65 hours is awfully "young" for this problem.
Jul 16, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
Carburator floods
Possibly the needle valve in the carb. fuel bowl.
Jun 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
LT 1000 flooding gas out muffler and stalls, then pours in carb.
Check your oil. Does it smell like gas? If so, don't run it even if you could. You will fry your engine. The float needle and seat in the carb are leaking. In other words, the float needle is not shutting off the gas when the bowl is full. You need to have them replaced.
Jun 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
2007 craftsman 20HP flooding
Do you get a strong smell of gas. Check your oil and smell it to see if gas has gotten into the crankcase. It all is well there it sounds like you need to gap the valves.
May 24, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
251 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
