Question about Bosch 23 in. SHU33A Built-In Dishwasher
Bosch Dishwasher Side Hose
I purchased a "Display" model, Bosch Model SHU 33A dishwasher. They said nothing was missing. Dishwasher has been hooked up and runs, but there is a side hose on the right side of the machine that I don't know what it is for or what it is supposed to be hooked up to. There is nothing in the install guide or manual about it nor a picture of it. Can anyone tell me what it is for and what is it suppose to be hooked up to?
The hose on the right is a breather and should not be connected.
Posted on Jan 04, 2008
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?
Welcome to FixYa.
I think can answer your question..."How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?"
Follow these steps...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
**SHU 9910-9920 Delicate/Econo** should be yours
SHU 8800/8810 Quick Wash
SHV 6800 Delay Start Hours
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
• If the display blinks with a "0", you will hear
no signal (indicates OFF).
• If the display blinks with a "1", you will hear a
LOW volume signal.
• If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
• If the machine beeps, then the Cycle
Completion Signal has been enabled.
• When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Oct 07, 2010 | Bosch SHU9915UC Dishwasher
Bosch has discontinued making the front flip tine insert for the bottom rack. I have two broken in my Bosch dishwasher. Can I substitute another manufacturer's part?
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Sep 07, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
My Bosch dishwasher stays running in the wash cycle, will not shut down or dry and sanitize the dishes.Checking the fault codes both the power scrub and the reg wash lights flash. Model SHU33A02UC
Thanks!
Aug 10, 2010 | Bosch 24 in. SHX33A02 / SHX33A06...
I own a bosch dishwasher model SHU33AO6UC and the problem is that water comes at the bottom although the machine is off
Thanks!
Aug 04, 2010 | Dishwashers
Bosch dishwasher noisy vibration
Thanks!
Jun 06, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Our Bosch SHU 4300 dishwasher does not drain fully
There is a recall on the control board of many of these models, butyour problem is likely not related. A sticking impeller indicates that the pump may be failing, but you are welcome to try my guide to help. It is here. Thanks!
Jun 15, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU 4000 series dishwasher; Water keeps on filling
The inlet valve will be at the dishwasher end of the (hot) water inlet line. On this dishwasher I ~believe~ the inlet valve is near the rear of the unit. That means that you will need to pull the dishwasher out to get to it. Remove power from the dishwasher as soon as you can before messing with the unit.
Just past the connection of the supply hose and the connection on the dishwasher, there will be the valve (a solenoid valve with two wires coming out of it.) That is the little beast that has most likely failed.
Good Luck!
Jan 14, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 23 in. SHU33A Built-In Dishwasher Logo
478 people viewed this question
Top Bosch Dishwashers Experts
shaun taylor
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
