Question about Sony KP-53S65 53" Rear Projection Television
Floor model someone move regulator ic from power supply,i whould like imformation of ic number
    President:
  • 3,130 Answers
If the IC your talking about has a designation number of IC601, the number is MX0841AB-F. Common regulator IC. Sony says that IC is no longer avaialable. You may get lucky and take out the entire G board and have ptscorp.com, or Tristate.com repair the board for you. Good Luck
Posted on Sep 18, 2007
Hi! i have sanyo televesion, model ts21sf1k. the problem is no power. i replace the power ic regulator STR w6753. but still no power. no voltage out in power supply.
SMPS circuit is not functioning. Check and replace all the associated component to STR. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 24, 2015 | Sanyo Televison & Video
Hello i need schematic diagram for power supply Model MEGMEET - ML686 . that power supply used for LCD TV .it's bad Brand and nobody care in service center. hope somebody help
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Check the present power supply [SMPS]; and find out the number of switching regulator IC used. Surf the site with that IC number. You will get similar circuit for SMPS there.
May 04, 2015 | Televison & Video
What is tcl 21e20 regulator ic number
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 30, 2014 | Televison & Video
What is the number of str ic,regulator power supply a 14 inches sharp tv. model primo sharp tv 14 inches
Try the site linked here. It has schematics of power supply section to many popular brand TVs. http://electronicshelponline.blogspot.com/ Hopes it will help you to check out the number of the STR.
Dec 18, 2013 | Televison & Video
Power supply problam solution
What is the number of regulator IC uses with the power supply to this set? If you wish to get details about how to troubleshoot SMPS power supplies, check this link. There is a recent post about it. Check it.
Mar 21, 2013 | Sharp Televison & Video
Have Ge model 52GW945 tv, it went blank no picture, nothing, I checked fuse its ok what next
Check the swithed mode power supply section. Some sets uses Ics for control the power regulation, while others uses transistors as oscillators and choppers. If the power to the oscillator section of the SMPS is absent, the supply system won't wake up. So many reasons are there. You just check the resistor, usually connected from main DC rectified supply, to energise the oscillator section of the SMPS. In most sets it may be two resistors in serial, usually 270k 1W*2. If any one of this get opened, the power supply will not start up. Check it first and preceed. If the set uses Ic as regulator controller, check the positive supply voltage at the respective pin of the Ic.
Oct 15, 2010 | GE Televison & Video
Sometimes when I turn on the tv it doesn't come on
This is a power supply problem, it is the regulator ic's on this board, and a couple of caps that need changed. Sony has used this power supply over many models and the exact component location nubers will change across the diffrent models, but you are looking for two ic's next to to white fuses. ic number is mcz3001
Sep 01, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv won't turn on
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part number AA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
Jul 22, 2007 | Samsung HCM4215W 42" Rear Projection...
Toshiba
No im sorry to say, not in the standby mode but in the shutdown mode. this could be from several things. like a bad regulator IC in the main supply, or a set of bad capacitors between the main power supply and the sweep power supply, or maybe a shorted audio output IC oer a shorted convergence IC or could even be because fluid leaked down onto the Printed circuit board, from the CRTs. If your not a tech Please call one as it not a place for someone to be tinkering around with! Please dont forget to rate this.
Oct 15, 2006 | Toshiba 57H83 57" Rear Projection HDTV
Tv struck by lightning
This set is pretty common for the regulator IC to go bad. Its inside on the power supply Printed circuit boad assy. It will start with STR#### and have 4 digits after the STR####, depending on the model of the set. Good Luck
Jun 03, 2006 | Toshiba 51H93 51" Rear Projection HDTV
Sony KP-53S65 53" Rear Projection Television Logo
79 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
