Question about Lexmark X1270 All-In-One InkJet Printer
My computer cant install printer as it says my printer spooler not working and i havn't got a valid port /driver..please help
  • Gerald Russell
    Gerald Russell May 11, 2010
    what OS are you working with?
Try this:
Open "control panel"
click on "administrative tools" (you might have to switch to "classic view" if it's not already set)
Click on "services"
Scroll down to "print spooler"
Double click on it
Under "startup type"...select "Automatic" (if it's not already.
Then under "Service status" Click "start" if it's not already started. If it is started, click "stop" then start it again.
Click "apply"
Close dialog boxes and try installing your printer again.
Please let me know if this helps :)
Posted on Apr 17, 2009
How can I get my spooler to work again?
please follow the below steps
Operation could not be completed. The print spooler service is not running.
1. Press Window key + R to open the Run dialog Start and type services.msc and click OK.
2. Double-click the Printer Spooler service, and then change the startup type to Automatic. This sets the Spooler service to start automatically when you restart the computer. Click OK.
3. Restart the computer and try to install the printer again.
If that doesn't work, the problem could be related to corrupted printer drivers that are installed on the computer.
Try uninstalling all printer software from the computer reboot and make afresh installaiotn of the drivers. This also include PDF writer or faxing software as well.
Oct 14, 2010 | Computers & Internet
Hi there. I have a HP LaserJet P1006 printer and a laptop with Windows 7. The print jobs get stuck in the que and I cant delete it. I installed the cd software many times, and I have installed the software...
you are installing the drivers may be not correct. u remove the printer driver and install the proper driver again otherwise it may be spooler problem then u have to reinstall the os and configure printer dirver
Apr 07, 2017 | HP LASERJET P1006 Printer
Driver for Windows7 X5495
First, download and install the Driver for Windows 7 from the following link:
http://www.siliconguide.com/drivers/download/1157/
Once the Driver is installed, please install the Printer Software using the Discs provided with the Printer, then check if the Printer is listed in the Control Panel > Hardware and Sound > Devices and Printer. If the Device is detected, right click on the Printer device and select the option "Set as default device".
Also, ensure that the Print Spooler service is running in the Computer.
1.Click "start button"-->"Run",Type "services.msc" and click OK.
2.Find the "Printer Spooler service" in the windows, Double-click it.Then change its startup type to Automatic.
3.Delete contents of the C:\Windows\System32\spool\printers folder.
4.Restart your computer and install printer again.
Or you can open command prompt and type in windwos 7
The Code:
net stop spooler
del /Q /F /S "%systemroot%\System32\Spool\Printers\*.*"
net start spooler
Jul 26, 2010 | Lexmark X5495 Printer
Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Oct 26, 2008 | HP LaserJet 1018 Printer
HP photosmart all-in-one 4100 series
The issue is with the print spooler. If the operating system is XP then click on start >> run >> type services.msc >> the services window opens, now locate the print spooler and right click on it and select stop(if it is started) then again right click on it and then click on start. Now the spooler service will start, then try installing the all-in-one software.
Aug 02, 2008 | HP OfficeJet 4255 All-In-One InkJet...
1020 Spooler SubSytem
ok, so for this, always had an issue with this one,
so, what i did is started the spooler, the way to do this is you have to go into control panel>>>admin. tools>>> services>>>printer spooler>>> and then you have a blue icon on your left where you have to click on the button that says start the spooler, now i recommend you minimize this window,
next step is that you add the printer through the add a printer wizard in most cases the printer should already have the basic driver installed into the computer. and way to add it to to start the add a wizard, click on add a port make sure the box where it reads plug in play is unchecked, so the only icon you have checked is the local port, next you choose the port that is usb001 from here you choose hp>>> then laserjet 1020, let the printer driver install and finally your done.
Jul 09, 2008 | HP LaserJet 1020 Printer
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
Print Spooler Problem
Try this:
Start the computer in safe mode then delete all the files and the folders in the following two folders: • C:\Windows\System32\Spool\Printers
• C:\Windows\System32\Spool\Drivers\w32x86
Start Registry Editor. To do this, click Start, click Run, type regedit in the Open box, and then click OK
Locate and expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86
View the list of subkeys. There should only be the following subkeys: • Drivers
• Print Processors
delete any other in this list
Locate and then expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors
View the list of subkeys. There should only be the following subkeys for the default print monitors: • BJ Language Monitor
• Local Port
• PJL Language Monitor
• Standard TCP/IP Port
• USB Monitor
delete any other in this list then restart your computer.
Good Luck
May 24, 2008 | HP PhotoSmart C4180 All-in-One Color...
My print jobs hang up in the queue
Test pages are printer generated not from the computer. Have you checked Microsoft help on this? make sure you are on line. Go to My Computer /Help, then when the help pages comes up Type in print spooler See what you get Rephrase the question if the answer you seek is being missed.
Jun 21, 2007 | Dell Inkjet 720 Printer
"Error 1068 Could not start the Printer Spooler on local Computer"
http://www.usa.canon.com/consumer/controller?act=DownloadDetailAct&fcategoryid=357&modelid=10238 Above is the Canon site with the newest drivers available. Download them and install them. First "delete" the printer from print properties. Unplug the printer from the wall for a few minutes and shutdown the computer. Plug the printer in and reboot the machine. Install the new drivers. You are in a loop. definition of LOOP: see LOOP. Let me know what happens. Good Luck, Tim
Feb 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Lexmark X1270 All-In-One InkJet Printer Logo
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
