Question about Oster 4134 / 4126 Classic Beehive Work Top Blender
How do I replace the fuse on my Oster Blender?
After a brief spark from plugging in my Oster beehive blender, It stopped working. Because there was no smell, I assumed the motor did not burn out and perhaps it is just the fuse. I took the bottom off of the blender and found the fuse burned out. I would like to replace the fuse but I do not know how to replace it. I can easily remove one end of the fuse assembly, but the other is attached to this piece which contains several other wires, and I do not know how to disassemble it properly.
  • 3 more comments
  • lele44 Oct 07, 2007
    I was able to isolate the wire from which the fuse wire was attached. I purchased a new fuse and installed it. My blender works perfectly now. That $10 (fuse + s & h) fix saved me from purchasing a new blender!
  • lele44 Jan 28, 2008
    Here's the website I used. I think it arrived in 7-10 days.
    http://www.abtecparts.com/sunbeam_blende...
  • miche11e Jun 21, 2008
    Please advise where the fuse is. If so, what tool(s) are required? The screws that hold the base are recessed within the rubber feet and look like little bolts. Is there a special tool to remove them? BTW my model is 4094 and has only been used a couple of dozen times. An ice cube became lodged in the blade during the first second of operation, the motor stopped and will not restart. There was no smell of burning or sparks.
  • Bobcv Aug 24, 2008
    I need a fuse assembly for an Oster 4256. It is slightly doffertnt from the one shown in the above link...the end with the connector has a long metal tab that slides into another connection. Anyone know where I can get one? Thanks
  • Bobcv Sep 13, 2008
    Miche11e - The fuse is most likely in the base of the blender. I removed the base of my blender with a medium cross point screw driver. Jam in into the middle of the rubber foot and turn counter clockwise.
    New Friend:
Just wanted to FYI the link to abtec parts above for the fuse. I ordered one from them, use the blender once, and the fuse blew out again.
Posted on May 21, 2010
I just had the same problem too and ordered the fuse online with the link above. Thanks lele44!
The four feet on the bottom are easily removed with a 1/4" socket slipped inside the each rubber foot fitting.
I'm glad I found you. I saw some downright horrible reviews of my local Oster appliance service center here:
http://www.insiderpages.com/b/3723327730
Rob
Posted on Jul 27, 2008
  • irha Nov 15, 2010
    I have a 2-speed 500w professional series blender that looks like this:http://www.amazon.com/Oster-BPCT02-BA0-0...
    Unfortunately, though the fuse assembly looks like the one linked by OP, one side of it is fastened into the motor coil, so it is not easily replaceable. I will try just cutting it off and reseal it with a new fuse.
  • billtrankle
    billtrankle Feb 13, 2013
    Radio Shack was able to supply an in-line fuse holder (for ease of any future blown fuses), the 8A/205V slow blow fuse, a bag of micro crimps and some heat shrink to make everything look pretty. Stripping the short end of the wire from the old fuse to the motor was the only tricky part, aside from that a 30 min. project. Margaritas anybody?
    New Friend:
No solution yet - still need help.
What is the link for ordering the fuse? I need ASAP. Made the mistake of putting power bar in the bottom with the ice, made short humm noise, then nothing. No smell, just no power, assume it's the fuse.
Please send link and any further help is also very appreciated.
thanks.
Posted on Nov 17, 2013
  • 5 more comments
  • Catherine W Nov 17, 2013
    no solution yet - still need help.
    thanks.
    thanks.
  • Catherine W Dec 04, 2013
    Please tell us where to buy the fuse. There is no link above, as stated in the posting up further.
  • Catherine W Dec 07, 2013
    http://abtecparts.com/sunbeam_blender_mi... Would someone please weigh in on if the available fuse will work on our blender? Or is it the one shown as no longer available? Any tips on where to find one? Thanks.
  • Jeremy Shafer
    Jeremy Shafer Dec 26, 2013
    I got the same fuse that was in there to begin with (ordered it online) and it blew out again immediately when I turned on the blender. I'm about throw out blender if I don't find any other fixes fast.
  • Catherine W Jan 02, 2014
    Jeremy, please send me a link for where you got the fuse? I still can not get the correct one, and hope mine doesn't blow out again like yours did. I can not despite much searching find the proper fuse online, and can not get the links for the right one to work - says no longer available. thanks.
  • Michael Rembert Jan 21, 2019
    What link can i order a fuse from
Rob
I have the same problem. Where did you buy the fuse from?
Posted on Jan 26, 2008
I'm currently dealing with the same problem. You'll notice that where the wire from the fuse goes into the switch,there's a bit of space. If you push the end of a tiny screwdriver in next to the wire, it should move the brass piece that holds the wire in place slightly and release the wire.
Posted on Oct 06, 2007
SOURCE:
Where can I get a replacement fuse for my Oster precise blend 12?
Hello, Frances -
Your question landed in the Fixya.com category of Furniture. I re-categorized your question to the Oster Blenders category.
I found the following information regarding Oster blender built in fuses:
(Quote)
The built in fuse protection has kicked in. To turn the blender back on, first turn the control knob to "Off" and unplug the unit from the wall. Then remove the jar from the base and free the blade of any obstructions. Next, press the external resettable fuse button on the bottom of the base. Wait 30-45 minutes for the unit to cool.
(End quote)
Source:
https://www.oster.com/service-and-support/product-support/product-faqs/blenders/oster-versa/blenders-oster-versa-faq.html?faq=blenders-oster-versa-faq-Q-A-4
Question: My blender shut off during use. What happened?
If you try that possible solution and the blender still does not start, then . . .this is the link to the Oster Contact Us page:
https://www.oster.com/customerservicecontact?cid=contactus
At the very bottom of the page you will find toll free Customer Service phone numbers.
Or . . .
Fill in the form there, asking about the availability of a replacement fuse for your model of Oster blender, so that you can send an email message.
Best wishes.
Sep 26, 2018 | Oster Blenders
Oster makes a high-itch whining sound
Sounds like the bearing for the blade on the bottom of the pitcher may be in need of replacement.
Aug 13, 2017 | Oster 4094 Designer Classic Beehive Work...
My blender died last night. I flipped the switch and the blade did not move. It was trying....but eventually stopped trying. Now nothing happens when I flip the switch. I have been using it daily for over...
:( my condolences to the blender family.Unplug it its life support and accept your loss. Gently wrap the cord around it and lay its body softly in the trash can. At least you know it tried to the very end. As you walk the isles of walmart, I feel you will find another to take its place.Good luck.
Jul 08, 2009 | Oster 4124 Beehive Work Top Blender
Oseterizer 2spd Blender | Proper order of hardware related to fan
You should have four parts:
Shiny washer
Fan
Black spring-washer
Bolt
They assemble onto the driveshaft in that order.
Mar 01, 2009 | Oster 4134 / 4126 Classic Beehive Work Top...
My rarely used Sunbeam Blender Model #4181 stopped working
It sounds like one of a number of things...
* The contacts in the switches fried
* The motor itself fried
* The controller section fried
If you saw smoke, something fried... probably cheaper to simply replace the unit. Even if it still worked, it's a 120V electric appliance used with liquids, and I wouldn't trust it... I'd hate to hear that your blender started a kitchen fire.
Mar 22, 2008 | Oster 4134 / 4126 Classic Beehive Work Top...
Help with a Dismantled Osterizer Classic Blender
With the unit upside-down and the bottom off the wires on the right side of the switch go like this:
yellow on top
black on middle
red on the bottom
No wire connects to the 4th connection point (top left side).
R.
Aug 17, 2007 | Oster 4134 / 4126 Classic Beehive Work Top...
Oster 4134 / 4126 Classic Beehive Work Top Blender Logo
6,739 people viewed this question
Top Oster Blenders Experts
Bruce Showalter
Craig Butler
Craig Butler
Ruth summersides
Are you an Oster Blender Expert? Answer questions, earn points and help others
