Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
Extracting photos from a video recorded with sony dv hc22e camcorder
I used my camcorder to record videos and take photos at the same time - now i would like to create a video to burn to cd but also print out the photos - the video comes up as an avi file and combined the video and pictures - is there any way to extract the photos for printing
  • 49 Answers
Yes, various softwares like the ones that usually come with the camera, or others like Pinnacle (cheap and functional) can let you see the video frame by frame and capture or save a frame separately as a photo - try right clicking on the frame you want. Of course programs like Adobe Premier are excellent for this too but very pricey. Unfortunately, if the snaps are part of the video, they will be low res and email quality only under normal circumstances. It may be printable up to 4x6 maximum usually (but a bit choppy). For the best results, switch the camera to photo mode and shoot to the memory card for the cameras best quality results. Or use a still camera. You can always do both or use the software to add photos to your video edits. Hope this helps...
Posted on Sep 19, 2007
SOURCE:
I have a dcr-sr200 and have 7 hrs worth of video to burn that took about five hours. But when I check it the time date stamp did not appear. I can seem to figure it out . please help
I understand that you have burned the videos to a disc using Computer and the burned videos does not have the date and time on it. In order to get date and time on videos taken using the Hard Disk Camcorder, the video should transfer using A/V interface with the DATA CODE option on the Camcorder enabled.
Once you enable DATA CODE, the date and time will be shown when playing videos in the Camcorder. You can view when you connect the Camcorder directly to a TV. While using the A/V interface with Computer to capture videos using an Analog Video Capture Software like Windows Movie Maker, you will get the videos in Computer with date and time displayed. You can burn those videos using a burning software.
If you're using stand alone DVD Recorder, you can enable the DATA CODE and use the A/V interface to connect the Camcorder to the DVD Recorder to get the date and time on videos.
Thanks for understanding. Please let me know for clarifications. You can also give more information about the recording method you're using to give more specific instructions.
Apr 30, 2011 | Cameras
How do I tranfer video from my camcorder to my computer?
Hello there...
There is another way to transfer video from you camcorder if you camcorder support USB streaming. I usually use this method with my Sony Camcorder because more simple and don't need additional hardware.
Steps:
1) Install you camcorder driver to your PC/laptop.
2) Connect your camcorder to PC/laptop.
3) Open Windows Movie Maker.
4) Create a new project and select source input device to your camcorder.
5) Start record on your Windows Movie Maker application and press play on your camcorder.
6) Wait until camcorder finish playing and press stop in your WMM.
7) Save the file as WMV (later you can convert to another format using any video converter or even burn to CD)
PS: you can even edit the movie frame or add some opening text or end credit.
Hope this helps.... :D
Mar 27, 2010 | Video Cameras
This camcorder does not record video; it won't format memory card
do you get any kind of error code?what type of memory stick are you using?how big is the ms capacity?may need to try using a diff ms or try using ms with diff devices.if diff ms works fine.may need to format ms using computer first (using card reader if available) and camcorder last.may need to reset camcorder (make sure cam is on when you press the reset button.hope this works.thanks :)
Mar 12, 2010 | Sony Handycam HDR-CX12 Flash Media...
How do I finalize the mini-disc in my Canon DC201 camcorder?
to finalize dvd you have to do it or on camcorder or DVD RECORDER. find someone that have and you will be able to do it. good luck
Sep 28, 2009 | Canon DC210 DVD Camcorder
I recorded my movies on the dw 100 but now i can't grt them to play on my dvd player
The DW-100 records discs based on the format they were originally recorded.
If your camera is recording HiDef videos than the discs this unit creates will be viewable on a Blu-ray disc player.
If your camera is recording in Standard Definition (ie. NOT HD) then I believe that the discs will work in regular or upconverting DVD players.
My Canon camcorder does not record in Standard Def so can't quite vouch for that last comment though.
Jan 06, 2009 | Canon DW 100 DVD-RW Burner
How can i change the format that my "magix Photostory CD & DVD" program burns my pictures/music to a DVD that WILL play on a home DVD player and not just a computer? I have a Windows XP
There are three ways to create a Video CD (VCD) that contains your photo stories:
You can obtain Microsoft Plus! Digital Media Edition and view the Photo Story 3-authored WMV file in Photo Story 2 by going to Play your story or create a video CD of your story and then create a VCD.using the Photo Story 2 Video CD-burning feature.
• You can obtain Microsoft Digital Image Suite 10 or above and view the Photo Story 3-authored WMV file in the Photo Story that comes with the Digital Image Library and save and burn to VCD.
• You can obtain VCD-authoring products that work with Photo Story files, such as MyDVD by Sonic Solutions or InstantCD\DVD by Pinnacle Systems. You can use these software to convert the Windows Media video (WMV) files into files that can be copied to a DVD and played in a DVD player.
Note: VCD and DVD-authoring software is not included with Photo Story 3.
Oct 14, 2008 | Computers & Internet
Downloading Video
In order to burn a DVD you need to use the 1394 interface. If you use the USB interface then you have the option to only burn VCD. However, i could not even burn the VCD using the USB interface. It refuses to recognize that there is a new CD-R in the PC.
Can anyone help please?
Feb 24, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Archiving Digital Camcorder Video - Ideal Formats
Let's try to bottomline this. If you want said DVD to play in most players, you'll be encoding the video according to standards. The current DVD is MPEG2. At the current time, most people just have DV camcorders so you don't see the generational loss as you move the video from DV to DVD. At least I don't.
Sep 13, 2005 | Sony DCR-HC15 Mini DV Digital Camcorder
I want some feedback for DVD Camcorders.
My non-authoritive answers are: 1. Can the DVD-R be played on the Camcorder without finalisation? I'll write no. This is based on one comment by an user plus numerous experiments with DVD+R, DVD+R/W and such formats. 2. Does the DVD-RW / DVD-RAM need a finalisation ? Can the DVD-RW / DVD-RAM be played back on the camcorder/DVD Players/Computers without finalisation ? Based on my experiments with DVD recording and the 3 DVD players I have in the lab, the answers are yes and no in that respective order. 3. Can the DVD-RAM be played in the camcorder and output recorded in a standard VCR Casette ? The media played in the camcorder but placing the media in the VCR doesn't work since it's a phyical media issue. 4. Can the DVD-RAM/DVD-RW be played in the camcorder and the output captured in a computer and then burnt back on the DVD-RAM/DVD-RW or Computer CD/VCD ? Sure, but my method skips the play and re-capture. The files on the media are just placed into the DVD creation software and a new DVD is recorded.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
97 people viewed this question
Top Sony Video Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
