Question about Compaq Presario 700 470024-192 Notebook
Quick Restore I did a Quick Restore with the 3 disks provided that took approximately 20 minutes. When it ended I removed the last disk and pressed enter to reboot. Directions state that after installation is complete you can install programs. My laptop has been running for better than 2 hours now and nothing has happened. Claire
  • 2 more comments
  • clg721 Apr 18, 2009
    I removed the battery as you suggested. Restarted the laptop without a CD and had an opening screen with the stats of the laptop. At the bottom it said: ERROR: Resource conflict - PCI on Motherboard BUS:00, Device: 09, Function: 00.
    Also a box with F1-Boot and one with F10-Computer Setup. I did F1. Got the Windows XP screen, then a blue screen with "Please wait while Windows prepares to start". This was after doing another Recovery. Now I have a black screen with the cursor in the middle and nothing happening.
    How long should it take after running the Recovery disks to restart correctly if that error message means nothing?
    Claire
    I've done verything you have suggested and nothing seems to be working. I had that ERROR before I did the Recovery and the laptop was working but extremely slow.
    I have been trying to resolve this problem fro at least 3 days now and I think I will take it in for repairs. Hopefully it can be repaired.
    Thank you for your assistance.
    Claire
  • clg721 Apr 19, 2009
    Thank you. Tapping the F8 key did give me the option to boot in the safe mode as well as others.
    I did that and I don't get past the Windows XP opening screen.
    You are more than likely right about the motherboard problem. I will take it in for a check up and if they find that is the problem I will just forget about repairs. Too expensive.
    Thanks again.
    Claire
    It was helpful but didn't work.
    Brigadier General:
  • 5,158 Answers
Tap the F8 key as you reboot... hopefully you will get the option to boot to safe mode.... let me know if it will boot to safe mode.... i does sound like you have a component that has failed on the motherboard tho
Posted on Apr 18, 2009
  • Roberta Smith
    Roberta Smith Apr 19, 2009
    please rate my solution and suggestion... thanks
  • Compaq Master
  • 19,396 Answers
Hi Claire.
Try removing the laptop battery, removing CD from the inside, and restarting the laptop with no disk inside.
If it restarts correctly, then you should have the Windows screen and everything working.
If the laptop does not start , then you will need to start the recovery procedure again.
Insert the disk 1 from the recovery CD set inside the laptop and chose to do a full recovery (this will delete old data) or a partial recovery. If you have no data to save , complete recovery is better.
If you do all the above and still no luck, then one of the recovery CD gets stuck, in that case give me a more detailed description (error messages etc.) of what happens when the recovery does not complete..
  • Ginko
    Ginko Apr 18, 2009
    Hi ,
    Try first unplugging power and removing battery again to reset the laptop (I forgot to tell you to remove battery as well on my last comment).
    The : "ERROR: Resource conflict - PCI on Motherboard BUS:00, Device: 09, Function: 00." is an hardware error, and you do not fix this kind of problem with a recovery disk.
    Try first Go in to the BIOS Setup by pressing button (I think F2 on your model) on startup and choose the option to set things to the Default then Save and Exit.
    If that fixes it but it comes back when you remove power from the PC you may need a new CMOS battery.
    If that does not fix the problem, then you have a faulty device inside the laptop. Device 09 is audio chipset, built in on motherboard, but this can also mean a faulty RAM module.
My lenovo t400 has a black screen with a lock symbol on the top left corner. I'm not an administrator, so it might make it a little more difficult... any idea how to fix it?
I understand that you can't access your lenovo because it's locked. Since you can't access it anymore, we should reset it to default settings so that your laptop's system will be refreshed.
The process of resetting a laptop to factory settings wipes off the contents of the computer's hard drive. This is ideal for those who wish to delete personal information before selling their laptops and those who need to eliminate some computer problems. Some manufacturers save the system restore files on a small partition on the hard drive, while others provide disks containing these files. Regardless of the method you use, the system restore process could last from 45 minutes to an hour.
1.
Back up your files. Save important documents, pictures and music to removable storage media, such as a flash drive or a CD.
2. Place your recovery disk into the disk drive and restart your laptop. This will launch a program to guide you through the system recovery process. Follow the directions onscreen to restore the laptop to factory settings.
3. Access the system recover files stored on the hard drive. Restart your computer. Watch the black screen for instructions on which function key to press to access the computer management module. The function key used varies by manufacturer, but the keys commonly used are F2, F8, F10 and F11. Select the option to reset the computer from the list of options in the management module. Follow the directions to begin the process.
4. Wait for the computer to complete the process. This could last up to an hour. The program may prompt you to restart the computer at the end of the process. If you reset the laptop with system restore disks, make sure you remove the disks from the disk drive before you restart the system.
I hope you find it very helpful. Thank you.
Aug 11, 2011 | IBM Lenovo ThinkPad T400 7417 Notebook
Tip
How to reset different models/version of San Disk players
Hi,<br /><br />Learn how to reset the your various San Disk models;<br /><br />Resetting a Sansa Fuze+, Clip+, c200, e200, or e200R player:<br /><br />1. Press and hold the Power/Menu button for approximately 20 seconds.<br />2. Release the Power/Menu button.<br />3. Press the Power/Menu button again to turn on the player.<br /><br /><br />Resetting a Sansa View, Fuze, or Clip player:<br /><br />1. Slide and hold the Power switch up for approximately 20 seconds.<br />2. Release the Power switch.<br />3. To turn the player on, slide the Power switch up then release instantly.<br /><br />Resetting a Sansa Express player:<br /><br />NOTE: The device can be either ON of OFF.<br /><br />1. Press-and-hold the Volume Up (+) and Select buttons simultaneously for approximately 20 seconds.<br />2. Release the buttons.<br /><br />Good luck.<br /><br />
on Nov 24, 2010 | Audio Players & Recorders
Keeps disk checking and cant get into anything . Runs disk checker and then nothing. Goes to blue scrren. Bought new one yesterday 1545 model in red , Would like to get old one working for grandson.
From you're description it sounds like the hard disk drive is defective. Suggest you replace it with a new drive, choose from the list provided; http://www.google.com/products?hl=en&q=Dell+Inspiron+1520+new+hard+disk+drive&um=1&ie=UTF-8&ei=QertS-P-NYP48AaSy8z9Cg&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CDEQrQQwAA
There is another option. Restore a DELL Inspiron 1525 laptop to factory settings.
You have to do it BEFORE Windows loads...
1. Reboot, and press Ctrl + F11 at the Dell logo.
2. The Dell PC Restore by Symantec screen will come up.
3. Select "Restore" or use the Tab key to highlight it and press Enter.
4. if you wish to continue, click "Confirm", or use the Tab key to highlight it and press Enter.
5. When the utility is finished, click "Finish", or use the Tab key to highlight it and press Enter.
***This will erase all your unsaved data!***
Use you're recover CD to reinstall Windows.
Mike
May 14, 2010 | Dell Inspiron 1520 Motherboard
Will not re-boot
Hello #1: Use a Windows startup diskOne of the first things you should reach for when troubleshooting a Windows XP boot problem is a Windows startup disk. This floppy disk can come in handy if the problem is being caused when either the startup record for the active partition or the files that the operating system uses to start Windows have become corrupted.
To create a Windows startup disk, insert a floppy disk into the drive of a similarly configured, working Windows XP system, launch My Computer, right-click the floppy disk icon, and select the Format command from the context menu. When you see the Format dialog box, leave all the default settings as they are and click the Start button. Once the format operation is complete, close the Format dialog box to return to My Computer, double-click the drive C icon to access the root directory, and copy the following three files to the floppy disk:
  • Boot.ini
  • NTLDR
  • Ntdetect.com
After you create the Windows startup disk, insert it into the floppy drive on the afflicted system and press [Ctrl][Alt][Delete] to reboot the computer. When you boot from the Windows startup disk, the computer will bypass the active partition and boot files on the hard disk and attempt to start Windows XP normally.
#2: Use Last Known Good ConfigurationYou can also try to boot the operating system with the Last Known Good Configuration feature. This feature will allow you to undo any changes that caused problems in the CurrentControlSet registry key, which defines hardware and driver settings. The Last Known Good Configuration feature replaces the contents of the CurrentControlSet registry key with a backup copy that was last used to successfully start up the operating system.
To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last Known Good Configuration feature. In other words, if it fails to revive your Windows XP on the first attempt, the backup copy is also corrupt.
#3: Use System RestoreAnother tool that might be helpful when Windows XP won't boot is System Restore. System Restore runs in the background as a service and continually monitors system-critical components for changes. When it detects an impending change, System Restore immediately makes backup copies, called restore points, of these critical components before the change occurs. In addition, System Restore is configured by default to create restore points every 24 hours.
To use System Restore, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Now, select the Safe Mode item from the menu and press [Enter].
Once Windows XP boots into Safe mode, click the Start button, access the All Programs | Accessories | System Tools menu, and select System Restore. Because you're running in Safe mode, the only option on the opening screen of the System Restore wizard is Restore My Computer To An Earlier Time, and it's selected by default, so just click Next. Then, follow along with the wizard to select a restore point and begin the restoration procedure.
#4: Use Recovery ConsoleWhen a Windows XP boot problem is severe, you'll need to use a more drastic approach. The Windows XP CD is bootable and will provide you with access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROM drive on the problem system and press [Ctrl][Alt][Delete] to reboot the computer. Once the system begins booting from the CD, simply follow the prompts that will allow the loading of the basic files needed to run Setup. When you see the Welcome To Setup screen, shown inFigure A, press R to start the Recovery Console.
Please let me know if you have any further questions or concerns.
Thanks.
Apr 30, 2010 | HP Pavilion dv1000 Notebook
Have gateway md7818u notebook that locked up, my son accidently used the recovery disks from our gateway desk top to recover, now when I load the actual laptop recovery disks, it acts like it's loading...
0x00000070 error means that Windows start up failed in an early stage.
If you are unable successfully boot into Windows because of the this error, Windows has an option to reload registry information from the last successful boot. To revert to the last successful boot:
  1. Reboot the computer.
  2. Near the end of the BIOS messages or graphic, but well before anything appears from Windows, press the F8 key. You may only have a few seconds to get the right spot to press F8 before it attempts to go into Windows. If the BIOS complains about a pressed key or asks you to go into BIOS setup, you've pressed F8 too soon (Don't go into BIOS setup).
  3. When successful, you should see a back screen with white text "Windows Advanced Options". Use the up or down arrow keys to highlight Last Known Good Configuration and press Enter.
  4. If this does not work you may have already reformatted the original disk partition. If that is the case you will have to re-install windows from scratch.
Dec 10, 2009 | Gateway M-7818u 15.4" Notebook PC - Avalon...
Failed to overwrite all data bizhub 250
the overwrite data function is supposed to take about 35 hours but the ones that i have done took about 20 hours and ounce the process is started you should never interupt it this function overwrites all the data on the hard drive HD-504 you could try formatting the hard drive first then overwrite again
1touch the utility/counter button then details
2 press stop,0,0,stop,01
3 enter 00000000 touch end
4 touch tech rep mode
5 touch function
6 touch hard disk format
7 touch yes
8 touch enter when the message the hard disk format completed.result:ng appears touch ok
9 touch hard disk format
10 touch yes
11 touch enter this starts the formatting procedure
12 when the message "the hard disk format completed. result:OK appears touch OK
13 press the reset key
14 touch exit on the tech rep screen
if the format fails replace the hard drive the format process takes about 30 minutes if you need further instructions on how to replace the hard drive post it
Dec 04, 2009 | Konica Minolta Office Equipment & Supplies
I did a system restore from the disks. Everything
you will need to reload the window NTLoader is not reading your masterboot record. reinstall windows again make sure the disk is clean .
Nov 17, 2009 | Acer Aspire 3100-1405 Notebook
Does any one have gateway GT5220 Installation disk ?
Create an ASR Floppy Disk loadTOCNode(2, 'summary'); The following steps can create an ASR floppy disk from an ASR backup operation: 1. Format a 1.44 megabyte (MB) floppy disk and insert the disk into the floppy disk drive of the computer. 2. In System Tools, start the Backup program. When the Backup and Restore Wizard is displayed, click Next. 3. Click Restore Files and Settings, and then click Next. 4. In the What to Restore dialog box, select the media that contains the ASR backup. Ensure that the media is inserted. 5. Expand the Automated System Recovery Backup Set that corresponds to the ASR floppy disk that you want to create. 6. Expand the second instance of the drive letter that contains the system files. Expand the Windows_folder/Repair folder. 7. Click the following files from this repair folder: Asr.sif and Asrpnp.sif, and then click Next. 8. At the Completing Backup or Restore Wizard screen, click Advanced. 9. At the Where to Restore screen, set the Restore Files to: dialog box to Single Folder, and then set the Folder Name dialog box to the root of your floppy drive, for example, "A:\". 10. Click Next. The other options in this wizard are optional and do not affect the transfer of files to the floppy disk. When the wizard is finished, the files are copied to the location that you had previously specified. The ASR floppy disk is ready for use in the event of an ASR restore operation.
NOTE: The Asr.sif and Asrpnp.sif files must reside on the root of the floppy disk drive to be used during a ASR restore operation. Starting the Windows Recovery Console loadTOCNode(2, 'moreinformation'); To start the Windows Recovery Console, use one of the following methods: • Use the Windows Setup floppy disks or the Windows CD-ROM to start your computer. At the "Welcome to Setup" screen, press F10 or press 'R" to repair. After you start the Windows Recovery Console, you receive the following message: Microsoft Windows(R) Recovery Console
The Recovery Console provides system repair and recovery functionality.
Type EXIT to exit the Recovery Console and restart the computer.
1: C:\WINDOWS
Which Windows Installation would you like to log on to
(To cancel, press ENTER)? After you enter the number for the appropriate Windows installation, Windows will then prompt you to enter the Administrator account password.
Note If you use an incorrect password three times, the Windows Recovery Console closes. Also, if the Security Accounts Manager (SAM) database is missing or damaged, you cannot use the Windows Recovery Console because you cannot have correct authentication. After you enter your password and the Windows Recovery Console starts, type exit to restart the computer.
When you use Windows XP Professional, you can set group policies to enable automatic administrative logon.
Use the Winnt32.exe utility with the /cmdcons option to add the Windows Recovery Console to the Windows Startup folder. This procedure requires approximately 7 megabytes (MB) of hard disk space on the system partition to hold the Cmdcons folder and files.
Aug 02, 2008 | Gateway GT5220 PC Desktop
Computer problem, help.
This generally indicates a hard drive crash/failure, in which the hard drive will need to be replaced. Rare, but occasionally you will get this error from an operating system glitch. Before you run out and buy a new hard drive, try reloading the operating system. If you have any problems during or after the install, then the hard drive is shot.
Jul 01, 2008 | Sony VAIO FRV25 Notebook
Acer 1690
They may be correct, although you can try pressing F8 on boot up and and enter safe mode. When in the menu choose 'Last Known Good configuration' and press enter, allow a reboot and hopefully you get into windows. It may also be the boot.ini which is damaged at tells the harddrive where windows is, but you will need your Windows disc to repair the system.
Apr 09, 2007 | Acer Notebook
Compaq Presario 700 470024-192 Notebook Logo
55 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
