Pc cant boot
Hello please my pc just cant boot from the hard disk, even though the hard disk can boot when inserted into another pc.i tried installing a fresh copy of windows but when it reached a point where it was supposed to boot from the disk, it stopped with the message- ;disk error;. Ihave checked all the cable connections. please help me out.
    Sergeant:
  • 452 Answers
Check the jumper settings, for this take out the hard drive and check the small jumper should be attached to master point. your cd rom should be on the slave the same way...reconnect the hard drive and restart ..after restarting goto bios . advanced configuration> boot options>first boot device> select hard disk and save exit. restart the pc
Posted on Oct 17, 2007
    Sergeant:
    Champion:
  • 293 Answers
Is the BIOS settings ok? Try changing the Molex power Connector or Change the power Supplies. Hope this helps
Posted on Sep 17, 2007
SOURCE:
My toshiba laptop c580 was messing up so I tryed to refomat it but it was unsucsessful now when I try to boot it it's says no bootable device please insert bootable disc and press any key .. Is this...
Even though the reformat failed, the hard drive was still partially formatted, erasing the operating system (Windows 8). When you format a disk, you are effectively erasing the disk for use by certain software. At this point you will have to reinstall an operating system. To do this you will need to boot from operating system installation disc.
Here is a guide on how to reinstall Windows 8 yourself:
http://windows.microsoft.com/en-gb/windows-8/clean-install
If you feel uncomfortable performing the installation yourself, I would recommend taking the laptop (and install disc, if you have one) to a computer repair technician. If you don't have an installation disc, your repair technician can acquire a copy for you, though this should cost extra.
Sep 03, 2014 | Computers & Internet
Hello my laptop wont open,it brings numbers that ask me to insert a boot disc,i dont have any ,what shall i do to start to start my windows.
Hi "Wambuilyds"
It show no hard disk is detected in your laptop, please check your BIOS to know the Hard disk is detected, also try to re connect your hard disk.. if the problem exists buy new Hard disk and install windows again,, Thank you
Aug 27, 2011 | Toshiba Satellite Pro L300 Notebook
My desktop compaq presario s4300nx starts up , i can accses set up with f1 but cant start recovery with F10 however the F10 button works in setup, no good to me, ...i have recovery disks the pc just...
you will need a Windows boot disk / Windows install disk / WinXP disk to reboot the PC and install / or repair your OS
rescue disk will not boot your PC
to enable that you need to enter the BIOS, press F1, F2 or Del to enter BIOS , then you need to look for the BOOT seq in BIOS, change that to CD DVD drive as the 1st boot device, Save and Exit and insert the boot CD and restart
this should give you the solution
Dec 16, 2010 | HP Compaq Presario S4300NX (DF216A#ABA) PC...
I have sony vaio laptop whice model is vgn fw 140e. i try to install win xp but i can't install it. can u solve my problem please.
hello, you have to check your BIOS setting if the HARD DRIVE is not above the CD OR DVD ROM, if it is then you must change the settings and allow the CD OR DVD ROM to be above the hard drive,then insert your window xp formatting CD.this time you should be able to install window xp.
Nov 18, 2010 | Sony VAIO VGN-FW140E/H Laptop
Reinstalling
Hard drive has bad sectors on it which is why its giving you that message even though you can go thru the restore. Normally going thru the system cd and then the recovery cd should bring you into windows with the device drivers installed.
Dec 10, 2009 | Acer Aspire 5520-5156 Laptop
Boot problem
Hard disk may be defective, it working intermittently. You can try by replacing a new hard disk.
May 20, 2009 | Dell Dimension 4600 PC Desktop
Disk boot failure, insert system disk and press enter
The drive should be set with jumpers or cable select to be primary master. Some pc & drive combinations don't like cable select, others insist on it. Try both, one at a time.
Jul 15, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
Harddrive
Get into boot setup and change the 1st boot device as hard disk
Dec 30, 2007 | Computers & Internet
Disk boot failure
After making 100% sure you have no diskette or CD in any drives the conclusion may well be that the disk is ruined. You ay try to boot from a diskette or CD and see if you can access the disk then. (see www.ultimatebootcd.com for instructions to make a boot CD) "The ultimate boot CD" has a few tools that might help you out. Since you can't boot you must make it on a different computer, though. You may also try to insert the disk in a diffe rent computer to see if it can be booted there. Also make sure all cables are properly connected.
Apr 03, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
Computers & Internet Logo
214 people viewed this question
Ekse
Alun Cox
