Question about Avanquest System Suite 8: Windows
Avanquest fix-it 8 will not update keep getting error 61449
  • Anonymous Mar 30, 2014
    can't update the software. System says I am not connected to the internet when I am. Fix-it 12
DISPOSITIVE SOUND
Posted on Apr 17, 2009
I just bought Avanquest Fix-It Utilities brand new from Wal-Mart and I have installed it and when I try to activate it using an email address it keeps saying that it cannot connect to the server. I have...
Version 8 or 8.2 .......???
Its an old version contact the seller and ask for a refund or help
or download version 8 and install it
http://www.esoft.me/dl.php?file=Avanquest System Suite 8 Professional 8.0.2.2.zip&host=zip
or just use something else
There are lots of freeware alternatives on the internet
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
Delete some stubborn files
http://www.malwarebytes.org/fileassassin.php
http://advanced-systemcare.soft32.com/ One-Click Free System tool
Aug 05, 2013 | Avanquest Fix-It Utilities 8 Professional:...
I purchased a copy of fix-it 10 professional and have not been able to get my computer to download the program. It keeps telling me that I have to locate fix-it 8, remove it before I can download the...
Boot in safe mode, search the entire hard disk for Avanquest or Fix-it files and folders and manually delete them. Then boot normally and remove the Fix-it 8 entry from the Add/Remove Programs list using this
http://www.gaijin.at/en/dluic.php
Finally run a good registry cleaner likeĀ
http://www.eusing.com/free_registry_cleaner/registry_cleaner.htm
After that you will be able to install your new program.
Sep 02, 2010 | Avanquest Fix-It Utilities 10...
I have removed Avanquest, but the Fix-It Utilities 'reminder' pop-up continues to interrupt what I am doing, urging me to update. How can I get rid of this or at least, stop it from popping up several...
If you're running anything older than Windows 7,go to Start,Run,type in msconfig,a couple seconds later a box will pop up with several tabs one of which is Startup.Open the startup tab and look down the list of checked boxes for anything having to do with Avanquest,Fix-it,or anything else that you know was part of that program,and uncheck the box or boxes.Click apply,and then you have the option to restart your machine right then,or restart later.That's your choice,but if it's really annoying to have the pop-up I'd restart now.
The onle difference with Windows 7 is that when you open Start you're already active in the "action" box,there's no Run box.
Let me know what happens,I'll keep trying if that doesn't work.
Good or bad,please rate my post?
Thanks
Bob
Aug 11, 2010 | Avanquest Fix-It Utilities 8 Professional:...
I FLUBED THE UPDATE DOWBLOAD TO FIX-IT 9 PRO TO
If you check the website at Avanquest they are aware of this problem and are providing a new Key to affected persons online. go to
http://www.avanquestusa.com/support-aq/RegisterForFixIt10SN.aspx
good luck
Dec 21, 2009 | Avanquest System Suite 8: Windows
Can't run easy update due to firewall - how do i fix this?
just disable the firewall first, but don't let the other security tools down
May 26, 2009 | Avanquest System Suite 8: Windows
Hello... My Windows XP has the following registry failure (c:0000218) I've attempted to boot up my Avanquest Systems Suite 8 Rescue disk, but it has failed. I can't get into safe mode, etc. Thanks, Paul
Sorry to hear about your trouble. From the error you stated, it seems your SR got corrupted (common with norton/symantec products). The best bet is to try System Restore from Safe Mode.
As for your second problem, here is an alternate way to access Safe Mode (I am assuming you can get into Normal Mode):
  1. Go to START, then RUN
  2. type "msconfig" and hit enter
  3. the system configuration window will appear
  4. among the several tabs across the top, one of them will say "boot.ini", click this tab
  5. there will be a box that you can check next to Safe Mode.
  6. Click Apply, then OK
  7. Restart
  8. Keep in mind that your computer will automaticall go in to safe mode until you uncheck this box.
Good luck and keep us updated!
TJ
Nov 30, 2008 | Avanquest System Suite 8: Windows
Open Questions:
Avanquest System Suite 8: Windows Logo
149 people viewed this question
Top Avanquest Computers & Internet Experts
Alun Cox
Chris Larocque
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
