Question about Canon PowerShot A95 Digital Camera
Orientation sensor got stuck
A95 has orientation sensor. In my camera it got stuck. If I slap it several times it detects correct orientation and got stuck again.
  • 217 Answers
Re: Orientation sensor got stuck
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Posted on Sep 30, 2007
0 characters
3 Points
Make photos show with correct orientation on digital photo frame
Your camera may be having more options of orientation or keystone or resize etc, if it is set to such options the picture results as you said, please try to re set your camera to factory default. then you try the photos effect.
Jan 31, 2016 | Digital Cameras
Oh you make laugh the photo is camera problem
Not sure which camera or model you have but try searching the menu to find 'Rotate' and enable the function. This should display and download the image at the correct orientation.
Oct 01, 2015 | Digital Cameras
Why does my digital picture frame rotate some pictures?
The picture orientation can be set manually.
You can download a manual here:
Check chapter "Changing your frame orientation".
May 07, 2014 | Kodak Easyshare M820 Digital Photo Frame...
Bought a new JazzJDC Digital camera and new alkaline batteries but the camera won't turn on. It is not clear how to install the batteries in the manual and I have tried several different ways. The...
The battery installation orientation usually can be found inside the bottom of the battery compartment. Often there is spring contact at the negative end.
Jan 17, 2014 | Digital Cameras
Micro sd card wont read
Check the SD card to see if the 'lock' is engaged. If so unlock and you'll be able to read. Other than that the other possibility is that your card isn't installed correctly. Remove it and check the pin orientation to be sure that it's installed correctly
Sep 23, 2010 | Kodak Zx1 Digital Camera
Cannot insert the memory card - push in, won't seat, springy feel
Make sure that you insert the SD card in the correct orientation. If not, it will not lock into place. The SD card is push in to insert and push again to eject.
There is a small diagram showing the correct way to insert the card just below the left hand side of the slot.
Nov 03, 2008 | Canon PowerShot A720 IS Digital Camera
My camera wont turn on nor will it connect to the computer
It IS the batteries. The batteries the camera is shipped with only lasted long enuff to use the camera one time, no download. Changing them out to the lithium AA's solved my problem even though the batteries it was shipped with tested good. Kodak might save it's customers a lot of headaches if they ship with lithiums to begin with.
Feb 05, 2008 | Kodak EasyShare C513 Digital Camera
Kodak easyshare c433
No way- if you have had it to bits - buy the next camera.
Jul 25, 2007 | Kodak EasyShare C433 Digital Camera
Canon PowerShot A95 Digital Camera Logo
77 people viewed this question
Top Canon Digital Cameras Experts
Are you a Canon Digital Camera Expert? Answer questions, earn points and help others
