Question about Uniden Lands Phones
Flashing LED light
I need to know how to get the flashing light to turn off
Hold down the button next to the flashing light for 5 seconds. It should stop flashing.
Posted on May 26, 2009
My Alba TV won't turn on and the light at the bottom is just flashing?
I the LED flashers when switched on it means there is an internal fault and it will be need of repair Do not take the back of unless you know what you are doing as the are very high voltages in side. If you are asking this question it would seem you do not know what the LED flashing means?
Oct 05, 2014 | Alba Televison & Video
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
Hyper flash with led light bulbs for turn signals
You need a special flasher available at Amazon. Looking up LED flasher then make of your truck
Jun 24, 2017 | Chevrolet 1500 Cars & Trucks
My android light keeps flashing (led light)
The flashing led light is part of most android phones. Different colors are associated with different apps. The flashing light is used to give a notification to the user. You should be able to go within the app settings and choose to turn off the flashing led light for specific apps. Hope this helps.
Apr 22, 2011 | HTC Desire Cell Phone
The green auto light keeps flashing on the head unit of my a/c and i can not turn the unit on. It has power, it does work, every now and then the green auto led stops flashing and i can use the unit with...
Need model and make of unit? Take off the bottom door of your furnace and there will be a label on the inside or the outside of the door it will tell you what the flashed mean.
Nov 25, 2010 | Heating & Cooling
TV only turns on for a few seconds then shuts off. the led light flashes red after is shuts off
How many times does the led flash ? Thats an error code. I can diagnose if I know the number of flashes.
Nov 27, 2009 | Sony KDS-R50XBR1 50" HDTV
Installing led 2 wire lights
I had the same problem with my 1997 marauder the only way i have found to make them work is to hook up the LED signal lights into the stock signal lights i know it sounds crazy but what i have figured out is that it uses the stock bulbs like a fuse. all you have to do is take the headlight out just like you did when you wired in the LED lights and wire in your stock bulbs along with the LED lights once you have done this put the stock bulbs in the headlight assembly and put the headlight back in this should fix your problem at least it worked for me let me know if it works for you as well good luck
Mar 12, 2009 | 1999 Suzuki VZ 800 Marauder
No picture
you have the ATC311 chassis. do this proceedure and you can track down where the problem is. let me know if you need more assistance. i can also post a link where you can get the training manual at a cheap cost emailed to you if you would like a copy.
5. Apply AC power and press power button.
6. If LED turns on and then off, disconnect J11501 (Audio CBA) and press power
button again. If power LED comes on and stays on suspect Audio CBA. If LED
still flashes or does not light go to step 7.
7. Disconnect J26903 (AV IN CBA) and press power button again. If power LED
comes on and stays on suspect AV IN CBA. If LED still flashes or does not
light go to next step.
8. Disconnect J19500 (Convergence CBA) and press power button again. If
power LED comes on and stays on troubleshoot the Convergence CBA. If
LED still flashes or does not light go to next step.
9. Disconnect J14801 (Deflection CBA) and press power button again. If power
LED comes on and stays on suspect Deflection CBA. If LED still flashes or
does not light suspect DM2 module.
Jun 08, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
All LED lights flashing
I read somewhere else over the net and the solution I found worked like a charm: just plug it back on and wait about 10-15 minutes.
Apr 12, 2008 | Brother HL 5250DN Laser Printer
Lands Phones Logo
775 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
