SOURCE: GE WASHER WON'T GO THROUGH THE DRAIN CYCLE AFTER WASH CYCLE
Most likley it's the drain pump! check the wiing and pump
SOURCE: Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
SOURCE: Whirlpool duet washer has stopped and the LED indicator says sud
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
SOURCE: wash cycle stuck
You can attempt to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main computer for the washer. Sometimes resetting it is all that is required to correct momentary program glitches. If the problem reoccurs following a CCU reset, then you have a legitimate problem. Let me know if you still experience problems. I hope this helps you.
SOURCE: F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
If you think the wash load is in a spin cycle of the wash cycle or rinse cycle place the machine in Spin Only cycle and see if it will complete.
Waht are your DIY skills? Do you want to try the repair/fix?.............Rich
