U can download here intel d845gvsr motherboard drivers
just put your any download driver query here and search u will find best links for drivers downloading
for refine your search use drop down section
Witch chipset do u have on you'r motherboard???
Link to audio driver go to step 3 and download only. This is HP's Realtech Audio Controller software for intel Board chipset
I want to re intall for the audio
U can go here for downloading driver http://www.bestonlinetools.org/top-29-places-to-download-drivers/
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
66
,my comp is intel and i dnt hve a motherboard installer..can u help me so dat my pc will regain his sound....plsssssssssssssss
Hablas español
Go to http://www.mercury-pc.com and download the drivers for your Mobo in the support section.
I need mercury motherboard installation softwire
Hey, You need driver
8738_WDM__0639XP.
God luck
Slavco
Www.driverstock.com
select ur mb and you'll get what you need...
SOURCE: motherboard installer
You can find drivers for your motherboard (Mainboard) here http://www.mercury-pc.com/downloads.php
Latest drivers can be found here just select your operating system from the drop down list.
you can download it to the web.. what motherboard you have? example ASUS. www.asus.com.... then go to the support and download.. ^^ cheers
I can't find an Audio Driver for this motherboard
i want to have a motherboard installer because my audio was not functioning
drivers for audio
drivers for screen resolution
need an audio driver for this motherboard
no audio
no audio for the intel d915gag onboard soundcard my chipset is intel grantsdale- G i915g/gl/gv
i lost my motherboard drive's cd. Now i want to install audio for that i need audio driver
the message "can't load ASCDDMI.dll" appears everytime i want to run the set-up pf my motherboard driver
some file has corrupted of my samsung motherboard i want to install it again please help me
Я хочу обновить драйверы материнской платы SL-85DR-C, поскольку она служит на моем компьютере добрых лет 5 и наверное устарела. Но я не знаю как это сделать. Не знаю также платная это процедура или бесплатная.
А если платная то мне интересно за что и сколько я должен платить. Прошу отвечать по-русски, поскольку с английским у меня проблемы.
Я хочу обновить драйверы материнской платы SL-85DR-C, поскольку она служит на моем компьютере добрых лет 5 и наверное устарела. Но я не знаю как это сделать и какие шаги я должен предпринять? Не знаю также платная это процедура или бесплатная?
А если платная то мне интересно за что и сколько я должен платить? Прошу отвечать по-русски, поскольку с английским у меня проблемы.
I reinstalled operating system for windows XP service pack two bu the audio device is not working and yet I don,t have the driver on a CD and I cant find it anywhrer. How can I download this High Definition Audio Drivers?
Denis Okello
Lira Uganda
SOUND CARD DRIVER
no audio
I have the same problem, please help me
audio pdrivers nt installed
thx
no audio
i believe i have a ddr400 motherboard and i need to download a driver for the audio
i want download the driver of the motherboard because my audio devise was not functioning
soltek SL-85DRV4C
i need a audio driver for xp intel 845glly motherboard
matherboard Software 945 GCT M2
my net connect (driver ) not working
After reinstalling Windows XP on my machine the audio devices stopped functioning. I have 845 motherboard. My machine configuration is as follows:
P4, 1.7 GHz, 384 MB RAM,
Windows XP professinal.
Kindly help me out with a solution.
Biostar P4M800-M7A Motherboard
i am trying to install audio driver of D945GCCR every time it fails to install n sometime hang also
my device fails no sound
teri maa ki chut
need motherboard, graphics and audio drivers
where ??
i need the motherboard driver
Tenho uma placa ASUS e nã£o consigo instalar os drivers de audio que consegui baixar, atã© os que baixei no site da ASUS o tipo: ps4800d-x
[email protected]
[email protected]
yes
Soltek SL-85DRC Motherboard
audio driver
i loss my drivers
i wan't drivers for motherboard alive-sata2-glan ddr2 800
Need audio driver files for GA-VM900M Mother board
i lose my compaq v3000 driver, and
no sound device
pls heeeeeelp
i don't know wich mother board in my pc my system sound not working i want download sound driver.
i installed new windows and sound doesnt work. i,ve lost my motherboard installation tv.
