Question about Jabra T610 Consumer Headset
My bt200 wont charge
Ive got a jabra bt200 that does not charge i dont get a continuous blue light it just flashes when i move the charger can anyone help
  • Anonymous Apr 18, 2009
    ive got a jabra bt200 that does not charge i dont get a continuous blue light it just flashes when i move the charger can anyone help
  • Simon Heasman
    Simon Heasman Apr 26, 2009
    I have the same problem, tried with different charging docks and AC adaptors, please help!
SOURCE: Jabra JX10 Bluetooth doesn't/won't charge
There is a way to fix this problem but i ain't easy...
The JX10 has a pretty dumb intelligent charger, it won't charge the battery when it's below a certen voltage so you have to temporarily "boost" the battery for the charger to pick up the charge process again...
You have to open the front cover of the JX10, peel out the battery and remove the tape from the battery to reveal the battery connectors.
When the silver foil plate connectors are visible you have to connect the charger and then connect 3 double A battery's (taped together or something) (total 3.5 volt) with the foil connectors for just 5 seconds. Mind the polarity! When you do this you will see after a couple of seconds the red charging light will lid! When the red light is on, disconnect your home-made "boost battery's" and the charger will charge the battery again!
It's a pretty hard job becouse of the tiny parts but is't worth the try...
And remeber to charge at least every month or you have to do this trick again!
Posted on May 19, 2011
SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
Posted on Jul 10, 2007
SOURCE: jabra bt160
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2)
For optimal performance, wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight. In general, you will get better performance when
there are no obstructions between your headset and your mobile phone. (See fig. 5)
Answer a call
Tap the answer/end button on your headset to answer a call
End a call
Tap the answer/end button to end an active call
Reject a call (Dependent on your phone supporting this feature)
Press the answer/end button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (subject to phone
settings) automatically transfer to your headset
Activate voice dialing (Dependent on your phone supporting this feature)
Tap the answer/end button. For best results, record the voice-dialing tag through
your headset. Please consult your phone’s user manual for more information about
using this feature
Redial last number (Dependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+ or –) to adjust the volume (See fig. 1)
5 How to...
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode
Make sure that the headset is on.
Press the answer/end button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT160
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’
‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’
or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 4)
3 Pair it with your phone
English
2 Turn on your headset
Press the answer/end button to turn on your headset
Press and hold the answer/end button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
Posted on Jun 16, 2008
gzuckier
  • 3 Answers
SOURCE: Jabra bt200 passcode
you mean the one you type in to get recognized? i don't know this model precisely, but all the jabras I've seen take 0000, four zeros.
Posted on Apr 23, 2009
Not sure if this is a solution or if it occurred by chance. Like many on here, I put my Jabra JX10 away for a few months while not using it. The time come for me to need it once again and found that it was dead. Made an attempt to charge the unit with negative results. The unit would only show a green "charged" LED indicator as if the unit was fully charged. I tried plugging the unit into the charger multiple times, and took the cradle out of the loop and just used the AC cord alone. Still with the same results. I pulled the outside cover off (slowly), to be sure not to break the small fragile tabs that hold it in place. The battery takes up majority of the space. Removed the battery but DID NOT disconnect from unit. Plugged the charge cord into the unit and immediately got a red LED charging indicator. While charging, placed the battery back inside and put the outside cover back on. The unit continued to charge for a little over an hour before the green LED "charged" indicator came on. I used the unit throughout the day to test it with no problems. Not sure what removing the battery from unit did, especially when it was not disconnected, but it worked. I hope to see similar results.
Posted on Jun 09, 2009
Loss of charger for Jabra BT 200
hello,buy travel charger BT200/BT250/BT250V and you will have your bluetooth headset charging back.
Take care.
Apr 10, 2010 | Jabra FreeSpeak BT200 Consumer Headset
My earpiece wont charge i just opened the box and the blue light flickers once and it wont charge
Your charger could be bad. Headsets do not usually show any sign they are charging. Leave it for 2 hours on charge then check the charge level as it shows in the owner's manual.
Mar 30, 2010 | Jabra BT250 Consumer Headset
An old headset I had would flash blue and orange when it was in discover mode, ( so the cell phone would find it to pair it up). This jabra I have will not go there. My cell phone just says cannot find...
Hello friend,
First, make sure that your headset is charged and then press and hold the "Answer/end" button until that the light becomes blue solid. at this time you can do a search on your phone to discover bluetooth devices.
Here is the link to download the user manual for more information:
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
if the device doesn't light on at all, you may need to try with another charger because in this the device is not charged at all.
Best Regards,
Oct 30, 2009 | Jabra BT350 Bluetooth Headset Headset
Charged earpiece doesn't communicate with cell phone
My advice would be to re-pair the two devices. In the Bluetooth menu on you phone find 'paired devices' and delete the headset from the list. Next you will need to put the Bluetooth headset into pairing mode. Make sure it is switched off and then press and hold the power button on the headset and keep pressing it ( some headsets need to also have the up volume button pressed at the same time). What should happen is either a solid blue light of alternate flashing of two colours. (pairing mode varies on different headsets and you made need instructions or call Jabra) At this point on the phone in the Bluetooth menu search new devices. It should find your headset and request pairing code. Code should be '0000' or some headsets use '1234'. This should now set up a fresh pairing and work again. Hope that helps.
Apr 23, 2009 | Cell Phones
Apr 23, 2009 | British Telecom Jabra BT200/BT250/BT250V...
My jabra bt250 headset wont turn on
check my post on solution 4 on this link, my headset still working 1 month after i boosted it.
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Aug 14, 2008 | Jabra BT250 Consumer Headset
Can't turn on ! no in structions w/ear peace. LG PHONE(chocolate) can't find ! BT150 Jabra ! I do'nt know wich buttons are what? how long it last, or when its charged ? H..E..L..P....!!!!
Go to the bleemin Jabra website! (http://www.jabra.com/Sites/Jabra/NA-US/Headsets/Pages/JabraBT150.aspx)
"When I put the charger on for the first time after purchasing and plugged it in there was just a quick blue flash but no lights came on ever."
This one is more fun. The charger that comes with the bluetooth WILL plug in 180 degrees from proper.
Symptom of reverse plug-in is usually a dull(VERY dim) blue glow and a high pitch whine. Depending on
the parts used in your production batch, one inverted plug-in could have popped something. Try rotating the plug 180 degrees, and seeing if the charging light doesn't come on(if it does, then you're good, if not, return for refund, or you're fubared)
Aug 11, 2008 | Jabra BT150 Wireless Headset
Jabra SP500 ssetup instructions
have the jabra sp500 charged up and turned on. hold down the button near where you plug in the charger until the phone on the big button becomes solid blue (no flashing), then have your bluetooth turned on ready and pair device thru phone, it should link with the phone and allow you to save the settings. The End
Jun 03, 2007 | Jabra SP500 Wireless Headset
Jabra BT150 No power
Make sure the charger is in right. If you put it on wrong you will get a faint blue light, when it is in right you will get a BRIGHT BLUE LIGHT. It WILL NOT charge if it is in wrong.
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT150/Documents/User%20manual/BT150_UM_NA_EN_496.pdf
Link for manual
Mar 22, 2007 | Jabra BT150 Wireless Headset
Jabra T610 Consumer Headset Logo
184 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
