Question about E-Machines T6414 (RBT6414) PC Desktop
When starting the machine it goes into 'high rev mode' (my term).
It stays in this mode and does not boot up. I have to turn it off and on until it finally will NOT start in high rev mode and actually boots.
    Problem Solver:
  • 10 Answers
REPLACE CMOS BATTERY.
BOOT TO BIOS SET TO DEFAULT.
RESTART IN SAFE F8 AND SET TO,
RIGHT CLICK DESKTOP,PROPERTIES,DISPLAY SETTINGS,SCREENSAVER,POWER SETTING
MINAMAL SETTING IN PERFORMANCE TAB.
FOR POWER SETTINGS REBOOT SHOULD SETUP THE FIRST TIME....
Posted on Apr 19, 2009
    Problem Solver:
  • 19 Answers
Whats high reving is it the fan power supply or motherboard it could be a lot i cant help till i get this info thanx rate me
Hp slimline s3000 goes immediately into sleep mode
Try booting into Safe Mode then go into the Control Panel and change the Power Options.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.Once safe mode is up click Start/Control Panel and look for Power Options.
Apr 08, 2012 | Computers & Internet
I have a Poulan (18"
IN SOME MODELS THERE IS 2 SCREWS NEAR THE CARB.THE SMALL ONE IS FOR LOW REVS AND THE BIGGER IS FOR HIGH.START THE MACHINE AND PLAY AROUND WITH THE SMALL ONE UNTIL YOU GET THE RIGHT LOW REVS,LEAVE THE HIGH AS IT.
I ALSO SUGGEST TO DO A TUNE UP.
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 08, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hi, i have a 1999 husqvarna 254xp... its abit hard to start and never idles more than 3secs.....from doing some looking into , i think maybe the L screw needs adj? if so could u explain in simple terms how...
In simple terms here we go, turn both L screw and H screw fully in until they stop ( clock wise ) now turn the L scew out one and a half turns out, and the H screw one and a quarter turns out, start the saw ans warm up the engine, allow the saw to idle, if need be turn the idle screw in to gain a slightly fast idle, start to turn the L screw in, the revs will start to increse as the mixture leans off, thet will reach a point where the engine then starts to die because it is too len, at this point unscrew the screw quarter turn, check the machine revs up clean, if there is a hesitation unscrew the jet a smaal bit at a time until it revs clean, now adjust the idle screw so the engine idles without the cutting chain rotating around the bar, the H screw should be about right however if it sounds too rich at full throttle srew the jet in a small amount until it sounds right, the maximum rpm should not exceed 13500, this should realy be check with a rev counter, if the engine revs too high there is a fear that it will over heat and seize.
Apr 13, 2011 | Husqvarna Forest & Garden No.967012396 345...
My Dell D610 in boot screen appear : '' MANUFACTURING MODE: LEVEL '67''' ''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL MODE'
When the machines are put together at the factory they stay in factory mode until the tech presses the FN key and X key together.
Go ahead and do this so your machine goes into user mode and it should reboot then the message should go away.
Nov 30, 2009 | Dell Computers & Internet
I have two screw settings on my echo hedge trimmer on the carb for the mixture, at the moment it does go but does not idle and feels as if starved of fuel when reving up,a bit tricky to start when warm.
On an otherwise healthy machine, the carb tuning procedure goes like this:
1) With the engine off, turn both mixture screws clockwise until they lightly "seat". Then turn them back counter clockwise two (2) full turns each.
2) Turn idle screw CCW and observe the throttle shaft movement. When it stops moving, the throttle plate is completely closed. From here, turn idle screw back clockwise two (2) full turns.
These initial settings should be sufficient to get a healthy machine to start up and stay running for the carb-tune procedure.
START THE ENGINE AND ALLOW ONE MINUTE TO WARMUP.
3) Turn the mixture screw closest to the engine (marked "L" ) clockwise in small increments (1/4 turn at a time) until the engine smooths out. Then back CCW until you have a slightly rough idle.
4) Accellerate to full throttle and turn the mixture screw closest to the air filter (marked "H" ) clockwise until the engine revs get higher and eventually begin to fall off again. Turn back CCW beyond ultimate top speed . . . until a very slight flutter is heard at top speed.
5) Release the trigger and adjust base idle speed until the blades barely crawl, then lower it one more touch.
6) Repeat steps 3, 4, and 5 once more and then check throttle response on quick rev-ups. VERY VERY small adjustments to the "L" screw in a CCW direction will give better response but larger adjustments will affect "H" settings.
That's it.
Special note for step 5: When you make the FINAL base idle adjustment, set it as high as possible without allowing the blades to move. This facilitates easier starts when warm.
Hope this helps,
Dolf-
Oct 14, 2009 | Garden
Screen goes black. the power light is on, but the picture goes out. if i turn the power off, then on again it comes back for about 5 seconds, then goes black again.
Check to see if this problem follows in safe mode. Reboot and when the Dell splash screen comes up tap F8 until you see the multiboot options. Scroll to "safe Mode with Networking" let the machine boot up and see if you have a screen. If you do, right click on the desktop and set the resolution to 800 X600 and reboot normally. Usually when a screen goes blank in normal mode but shows up in safe mode means you have an incompatible resolution for the monitor or graphics adapter. This may be a driver issue or hardware. If the screen boots up in normal mode at the lower resolution, then try and go to properties again and bump the resolution up a bit, if it blanks again, try to go online and update the driver for the graphics chip.
Sep 08, 2009 | Dell Dimension E510 PC Desktop
The screen turns black and stays like that
Normally it's because the resolution is set too high for the monitor. This has happened to me when I switch a computer from a flat screen to a old "biggy-size" monitor.
try rebooting the computer and BEFORE you see the windows splash screen, start pushing the F8 key...this should bring up a menu...select VGA Mode...it won't be pretty, but once you're in..right click on the desktop and change the solution (try 800x600). restart the machine...that should work.
-SuperDale
May 05, 2009 | Apple Computers & Internet
E-Machines T6414 (RBT6414) PC Desktop Logo
71 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
