Question about Samsung CLP 300 Laser Printer
Samsung Color Laser CLP-300
I grabbed GLOSSY inkjet paper by mistake at the store around X-mas. And the facing of the paper melted on the printer rollers. I finally got the right paper. But the color seems to be bubbling up and then streaking.
I am not certain but I seem to think it is related to the inkjet paper and I need to clean something. But I cannot figure out how or what to clean.
Any suggestions?
    Champion:
  • 220 Answers
Change paper,nothing to clean on printer.
Posted on Jul 03, 2009
Smearing of printed image in color printing mode
many times this problem is caused by the type of paper being used, especially with photos, try a different paper, or change the type of paper in the print box when you try to print. the amount of toner used is determined by the paper type. if you are printing on glossy paper you might get the smearing if you didn't tell the printer to print on "glossy" Anyway, this is most likely where to problem can be solved. good luck
Mar 24, 2011 | Samsung CLP 300 Laser Printer
What type of glossy paper should be used for Samsung CL315W Color Laser Printer?
Really there are no 'photo papers' for color laser. As the toner 'sits' on the surface of the page it makes little difference what paper type you use. Ink on the other hand is absorbed into photo paper and the gloss finish gives it a nice look and feel.
You may get a perceived effect with different brightness of paper. I have found the the high bright copy paper is best.
The inkjet papers will not work as it has a coating for inks not toners. From experience and trying various glossy laser papers, I have found that different ones work differently with each laser and its only trial and error. When you print try and scratch the surface as we have found that on alot of the papers the toners scratch off pretty easily.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 10, 2011 | Samsung CLP-315W Laser Color Printer
I have a Samsung CLP-315 laser color printer. I'm trying to find out if there's a *.icc or *.icm color profile for it to use with Adobe Photoshop. Couldn't find anything yet via google or others. Would you...
I have just purchased a CLP 325 and have set it up to get excellent colour pictures using Adobe Photoshop and the icc profiles readily available.
Your current working icc profile could be either Adobe RGB (1998), sRGB, Profoto or another. I would suggest that for everyday work use sRGB, if you are a specialist use Adobe RGB (1998).
Firstly make these changes in Photoshop:
Edit / Assign Profile / ColourMatch RGB.
To print:
File / Print / printer profile should be Adobe RGB (1998)
Illustration attached
Aug 24, 2010 | Samsung CLP-315W Laser Color Printer
My Samsung CLP-300 Laser jet is "burning" the ink when printing mostly dark colors which causes it to bubble and flake off the paper.
What kind of paper are you using? This printer does not work well with glossy paper and will do the things that you have described. Try using ordinary 20 lb copy paper and see if this makes a difference. If you are already using copy paper, then the problem is with the fuser, getting too hot.
Aug 02, 2010 | Samsung CLP 300 Laser Printer
Samsung 315 Color laser printer acts like it's going to print, but doesn't feed paper. No paper jam...
Sounds like you have a roller turned glossy.
Open your paper feeder drawer and locate the pickup roller. It's rubber, or like rubber and will either be glossy or a little dirty. Now take a light bristle toothbrush and clean the roller with alcohol, remembering to roll it as you clean. Allow to set dry for 20 minutes and try again.
Mar 07, 2010 | Samsung CLP 315 Laser Printer
How do you print Glossy Photos on a Samsung Color Laser CLX-3160FN printer without the laser buring off the gloss?
Do you have the right type of paper? I suspect the glossy paper you have is for an inkjet and is melting/buring when it is going through the fuser of your laser printer. The same thing for sticky back labels. Unless they say they are rated or compatible with a laser printer, don't use them.
Jun 20, 2009 | Konica Minolta magicolor 2500W Laser...
I cannot get the Samsung CLP-310 color laser printer to print on glossy card stock (business cards). I have tried putting just one page in the paper tray. The printer starts to take it and then I get paper...
Printers are only able to use paper that is within their thickness threshhold. Simply put, the stock you are using is too think for your printer. Try getting some thinner paper and see if that works
Jun 16, 2009 | Samsung CLP-315W Laser Color Printer
Samsung CLP-300 dark prints and smears
For starters remember this is not meant to be a PHOTO Printer, I am guessing the Spearing is because Glossy paper does not hold the toner like Regular paper or at least until it is fused. I am a technitiian and i also own this printer.
Jul 14, 2008 | Samsung CLP 300 Laser Printer
Printer Jam
Its probably stuck wrapped around the fuser.
It WAS glossy Laser paper and NOT glossy Inkjet paper wasn't it ??
Glossy Inkjet paper could cause a proplem like this, as inkjet paper just isnt made to stand the temperature of a fuser (the fuser cover reaches a temp of just under 180 Celcius) and it melts !!!
Dec 12, 2007 | Samsung CLP-510 Laser Printer
Samsung CLP 300 Laser Printer Logo
124 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
