Question about AOC 917Sw 19" LCD Monitor
19" aoc lcd monitor flashes pink constantly and turns black
My AOC 19" flat screen lcd monitor constantly flashes an annoying pink shade and darker and lighter shades. and will turn black when switching from accounts. this is constant and sometimes it will just stop. and start again a few mins later. i have tried shocking it "unplug and plug in while turned on" and ive checked the plugs are tight. it says that everything is working properly, but i cant figure out anything else to do.
THIS COMPUTER THAT I AM ON ALSO DOES THE SAME THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GRR...................=.="""""
Posted on Aug 16, 2009
Aoc monitor shows error message while connecting with i ball tv tuner
What resolution is the AOC monitor capable of using?
What is default resolution of the device you are connecting?
If the default is 1080P and the monitor is not 1080P capable then that would be your problem. You could attach to another monitor or HDTV and possibly turn down the resolution then try again.
Feb 05, 2016 | AOC 917Sw 19" LCD Monitor
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
AOC monitor black screen how do I fix it?
I have a couple AOC i2353ph monitors. One day, one of them booted up with a single vertical white line moving slowly back and forth across the screen that kind of looked like a scan or radar. Once I reset the monitor from the OSD it went way. Use "Extra > Reset" from the monitor menu.
Oct 22, 2013 | AOC 917Sw 19" LCD Monitor
Resolution problem with AOC TFT 185W80PF
Monitors don't need drivers to function. Either you need to configure it or it's dead.
Mar 16, 2010 | AOC 19" LCD HDTV Monitor
AOC 917Sw picture at the start then black screen. Tried hooking it up to another computer and have the same problem.
Your backlight in the monitor is failing.
You can repair it but depending on where you are it may be cheaper to just buy a replacement. Parts cost can be $60-$150 plus labor.
Nov 03, 2009 | AOC 917Sw 19" LCD Monitor
AOC 1" - Monitor Says "no signal"
Sounds like a connection problem. Make sure BOTH plugs are securely located. Ian.
Sep 20, 2009 | AOC LM729 17" LCD Monitor
AOC LM725 Monitor Problem
Change the monitor and check if the PC works. If it works then the problem is with the monitor, you will have to send it to repair. If not then, the problem should be with the power supply, check whether all the cables is kept intact.
Mar 21, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
AOC LCD LM725 monitor - Black Screen
OK WELL DID YOU UNPLUG IT FOR A LIL WHILE? IF NOT DO SO. IF PROBLEM STILL THERE HOOK IT TO A DIFFERENT CPU AFTER ALL IS DONE HIT ME BACK
Aoc 19mvwk black screen
For your AOC here is a link that may help you:
http://www.nam.aocdisplay.com/aoc/index.html
and here is the other link they refer to on the first:
The following link from HP may help both of you:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01295035&lc=en&cc=us&dlc=en&product=447382&lang=en
Aug 23, 2008 | Gateway FPD2275W LCD Monitor
AOC 917Sw 19" LCD Monitor Logo
647 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
