Question about Vantec NexStar 3.5in External Hard Drive Enclosure, Model "NST-350U2" (840556060505) Drive Case
Vantec Nexstar 3 HD not being recognized on comp
It is plugged in....unplugged and replugged all connections.....the blue light on the machine just keeps flashing on and off
  • Anonymous May 08, 2009
    same as above
Hi, I had this same problem - blue light flashing and the drive not being recognised.
The problem was with the power cord, not the drive.
I solved the problem by unplugging the connection on the power cord between the outlet end and the power brick section, and re-plugging them after flipping one of the ends over.
The drive was now getting power correctly and spun up and was recognised as usual.
Posted on May 19, 2009
Windows 7 NexStar CX USB 2.0 3.5 inch SATA drive when connecting, windows 7 can't recognize the USB drive and shows a message "unknown device". The blue light of the the hard drive...
This is the usual reason:
USB port has 4 pins (connectors). The two at the ends supply 5 Volts to the hard drive (or any other appliance you connect. I don't think there's a problem with those two because you can see the power light on the hard drive.
The middle is for data transfer. If one gets damaged, although the device gets power, the OS cannot recognize the device.
Try changing the USB cable you are using. Connectors in the wire are damaged more easily than those in the device.
Jul 09, 2011 | Vantec NexStar-3 External 3.5inch...
Vantec Nexstar 3 driver download
Vantec Nexstar 3 drivers can be found at driverupdate us.Take a look, and enjoy
Apr 04, 2010 | Vantec NexStar-3 External 3.5inch...
I have a NexStar 3 external hard drive that is not being recognized by my computer. It used to work now it gives an unknown device message
remove the hard drive restart your computer the plug the hard drive back into your usb port this should come up with new hard ware found and install the driver If not try a different usb port or your sata drive
Mar 30, 2010 | Vantec NexStar-3 External 3.5inch...
Windows 7 NexStar drivers and installation needed
No device-drivers are needed. Just connect this USB device, and Windows will recognize it. If there is a "one-touch-backup" button, it won't work, but you can still use drag-and-drop to copy files from your internal disk-drive to this external disk-drive.
Jan 01, 2010 | Vantec NexStar-3 External 3.5inch...
Have installed ide hard drive but it isn't being recognized by the CPU and the light is strobing continually.
Did you install the IDE drive _inside_ the VANTEC external drive,
or did you install the IDE drive _inside_ your desktop computer?
Did you set the MA(ster) / SL(ave) / C(able)S(elect) drive to the correct position?
Sep 19, 2009 | Vantec NexStar-3 External 3.5inch...
Can my Vantec NexStar 3 Hard drive SAVE?
You might want to take the drive out of the case and use and external drive connector to see if the drive still works.
https://www.amazon.com/Drive-Adapter-Converter-Optical-External/dp/B002OV1VJW
Sep 02, 2017 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Hard Drive won't spin
I had this problem and I found out that plug & play wasn't enabled in the bios.
Dec 30, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Nexstar
Its normal, and is the signal showing the drive powering/spinning up and down. The drive spins at 7200 rpms, when you power it up or down, its switches onto the speed that best suits  what it's intended to do.
Oct 14, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Nexstar External drive
If neither computers detect it, which is a good form of process of elimination, I would test the cable with a known working. I would then extract the drive from the enclosure. And try mounting into a desktop machine as a slave, or find another enclosure.
Oct 04, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Computers & Internet Logo
3,005 people viewed this question
Top Vantec Computers & Internet Experts
Willem.
Willem.
Piyal Perera
Piyal Perera
David Payne
David Payne
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
