Question about Kitchen Ranges
Hi, As you recommended two days ago, I obtained and replaced the temperature sensors in both ovens of my JTP56AOW1AA. The ones you recommended/linked were exact copies of the original. When I turn on the power there is initially nothing on the display, after a few minutes all digits/letters start flashing. Then it goes back to its old display "locked door." It won't respond to "bake," or "Broil." When I try to start a clean cycle, I get "err" flashing. (Same on bottom oven). Any ideas? Thanks, John
  • 19,396 Answers
That usually means that the door lock can also be damaged.
First ensure is not a setting problem, by tripping circuit breaker for five minutes , and using clear/cancel button.
The door lock can be tested using a multimeter.
Also control board and wiring to temp probe and element may have been damaged by the high temperatures produced on self cleaning cycle.
Unfortunately the oven does not return any error indicating the fault.
Door lock is tested by energizing , reading continuity to test solenoid and reading voltages.
Wires are tested by reading voltages.
Control board is tested by looking for blown capacitors or component, reading voltages, testing components for continuity.
If you DIY always observe strictly all safety rules., all repairs must be done by a competent repairer.
Posted on Apr 17, 2009
Hi i own a tappan tgf328 gas range and I'm trying to heat up the oven and its beeping and giving me an F31 code. Can you help me?
Tamppan Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Apr 07, 2011 | Tappan TGF320 Gas Kitchen Range
The fan that comes on when the oven reaces a certain temp will not turn off. The entire front panel was replaced about 1 year ago.
Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
OR
Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness
Dec 03, 2010 | Jenn-Air SVE47100 Slide-In Electric...
What the code f3 mean my stove model # is 911.9584991
This model ( Kenmore ) has been built by Roper ( 911 - First 3 digits tell you the manufacturer's name ).
F3 refers to Oven temperature sensor open.
You need to check the oven temperature sensor.The value of oven temperature sensor should be around 1100 ohms at room temperature. In case, it is too high or low, you need to replace that.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2010 | Kenmore Microwave Ovens
Flashing F2 warning
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 | Ovens
Jenn-air dbl oven WW30430B. Lower oven doesn't work anymore. Try to pre-heat - get F2 message. This started a year ago. Shortly after onset we had a hurricane and were without power for 2 days. When power...
HI. the oven control will interrupt normal actions if it senses an abnormal oven temperature. this can be caused by a faulty RTD(temp sensor), and, also, a faulty relay board if present.
Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness to make sure it is in good condition.
Aug 04, 2009 | Ovens
Receiving F3 Code
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Jul 16, 2009 | GE JRS04 Electric Single Oven
F-3 code on GE gas range
Hi, You may have a Open or shorted oven temperature sensor (RTD) that should be replaced.
Please rate and have a great day:)
May 18, 2009 | GE Kitchen Ranges
Dacor Oven F4 error message
Hi. I recommend Checking the sensor wiring harness and harness connection between the oven sensor and oven control. Replace the oven temperature sensor (RTD) if wiring is ok.
May 18, 2009 | Dacor ECS130 Epicure Electric Single Oven
I have a Jenn-air model # JGS8850ADS. An F3 - 1 came up. The temperature sensor was changed and it happened again on the same day that it was changed
hi there,
this is an overtemperature error that happens during self-clean. i would recommend ohming out the sensor and the harness and if they check out okay, replace the oven control itself.
Nov 07, 2008 | Jenn-Air Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
