Question about Xerox DocuColor 12 Printer
What is IBT belt cleaner blade retraction mechanism and how do i clean it?
    Problem Solver:
  • 4 Answers
I also had the same problem i just cleaned the ibt cleaning blade clutch if problems solves i will say you later or call me back on my phone 09860213726 mr augustine dass from Nanded Maharashtra
Posted on May 06, 2009
Que signifie le code 089-311 sur workcentre7232
The problem is the ibt belt sensor is not reading the silver patches on the edge of the ibt belt. They are either scratched or the sensor is dirty or faulty. Replace patches and clean or replace ibt belt sensor.
Feb 10, 2015 | Xerox WorkCentre 7232 VSE All-In-One Laser...
Xerox workcenter7346 has fault code 009-390
009-390= IBT belt home position sensor/patch. After examing ibt belt assembly and cleaning patch and sesor, noticed that the magenta developer unit was not in proper position, this was not allowing the ibt unit to turn. Re-positioned developer unit into proper position, installed ibt unit, this cleared up the problem and machine is running fine.
Dec 11, 2012 | Xerox WorkCentreR Pro 7346 Black Toner...
089-311 error code for xerox copier #7132
May 01, 2012 | Xerox Office Equipment & Supplies
How to replace the cleaning product of belt transfer (m24)? Thank you for your answer
1. Remove IBT Belt Assembly (REP 9.15).
2. Remove IBT Cleaner Assembly (REP 9.16).
3. Remove Stand Plate (Figure 1).
a. Remove screw (2).
b. Remove Stand Plate in direction of arrow. Stand Plate will be installed in new location
in step 7.
Jun 26, 2010 | Xerox WorkCentre M-24 Color Copier
Docucolor 242 code 042-326. What do we need to
arrwup.gifBSD On BSD 9.20 - Transfer Belt Position Monitoring arrwup.gifDescription Belt Home Position too long
arrwup.gifInitial Action NOTE:
If this fault is declared 3 times in succession, the print mode will be disabled. In order to clear this condition, reset NVM location 741-105 to 0.
  • Check the opening/closing of the Front Cover.
  • Turn the power OFF then ON.
arrwup.gifProcedure Check that the Transfer Belt is in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Center if required (see REP 9.3).
Perform ADJ 9.13 Belt Edge Learn Cycle.
The Belt Edge Learn Cycle ends abnormally. Yes No Unanswered
End
Check the reflective mark at the rear of the Transfer belt.
The reflective mark positioned correctly and reflects properly. Yes No Unanswered
Clean the reflective mark and reposition it properly, if the problem continues, replace the IBT belt ( PL 7.3).
Enter dC330 [042-200 Transfer Belt Home Sensor]. Rotate the belt manually for 1 turn.
The display changes. Yes No Unanswered
Go to OF 99-1 and troubleshoot the Transfer Belt Home Sensor ( PL 7.5).
Check the operation of the actuator of the Transfer Belt Edge Sensor Assembly.
The actuator moves smoothly. Yes No Unanswered
Replace the Transfer Belt Edge Sensor Assembly ( PL 7.4).
Select [042-016 IBT Steering Motor (CW) High Current] and [042-017 Steering Motor (CCW) High Current].
The IBT Steering Motor operate. Yes No Unanswered
Go to OF 99-9 and troubleshoot the IBT Steering Motor ( PL 7.4).
Check the installation position of the IBT Belt Module (the four legs of the IBT Belt Module are placed on the board springs of the Transfer Drawer and the fixing screws (M4: x2) of the IBT Drawer are tightened).
The IBT Belt Module is installed in the proper position. Yes No Unanswered
Adjust the installation position of the IBT Belt Module.
Set dC131 [741-105 Angle Data Initial Value (A0)] to 0.Install the IBT Belt in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Perform ADJ 9.13 Belt Edge Learn cycle.
End
Replace the Transfer Belt Home Sensor ( PL 7.5). If the problem continues, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem persists, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem is persistent, replace the IBT Belt Module ( PL 7.1).
Sep 08, 2009 | Xerox Office Equipment & Supplies
Xerox DC12 What does code 3-380 mean and how can I correct it
That error describes a number of things that can be foulty on your machine. First Did you recently replaced print cartridge (PC)? Couse if you did one thing that could be a problem is that you are using illegal or not original PC. Second thing that could make you some problem is IBT cleaner. IBT cleaner has two brushes on the each end of the assy. Their job is to clean silver patch on IBT. So maybe your IBT cleaner is worn out and those brushes doest do their job anymore or maybe the sensor that "reads" that patch is dirty
Aug 05, 2009 | Office Equipment & Supplies
9-345 occured what to do what is retract explain what to do
Your IBT cleaner blade retraction mechanism seems to have failed. Pull out the Paper Path Module totally (push the two clamps at either side of the module with a nail or something similar and pull). Pull out the CPC and the Dev. waste container. Now you can see two screws fastening the IBT assy to the chassis. Take out the screws and pull the IBT assy. It will come out. Now lift the IBT assy out of it's holder. and place carefully on a table. Inspect the right side, that is where the cleaner blade is located. Check it out.
May 06, 2009 | Xerox DocuColor 12 Printer
Error 9-345
This is a failure of The IBT belt cleaner blade retraction mechanism. 2-3 hour job for a trained tech. It may not even need parts, it's just hard to do
Jul 05, 2008 | Xerox DocuColor 12 Printer
XEROX DOCUCOLOR 12
Remove drum unit. check charge wire for contamination. clean or replace. Visually check fuser for an even glossy appearance. If it looks dry or damaged in any way a service is needed. IBT is a bit more difficult to check. If you have the know how to remove it. You should see a very shiny surface free from contamination of toner or paper dust, ect. clean if necessary and replace. If contamination reoccurs suspect cleaner. Last is the BTR check for proper operation and clean, repair or adjust if necessary.
May 26, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
871 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
