Question about Whirlpool 24 in. ADG7540 Built-in Dishwasher
The soap fails to disolve!
The soap fails to disolve - perhaps problem with dispenser door. I'm pretty sure it says ADG7560 but this product wasn't included in the list.
  • 423 Answers
Having the dishwasher powder failing to dissolve is a far more common problem recently with the filing economy.  People are trying to save money by buying generic dishwasher powder rather than brand name products.  The ultra-cheap products fail to dissolve because their ingredients include bulk fillers with minerals, etc.
It is possible that the dispenser is failing to open, but that is a generally rare problem except on very, very old dishwashers. Before deciding the dishwasher has failed, go buy a box of brand name (Electrosol or Cascade) dishwasher detergent powder and only use it.
Please report back your results here, OK?  Good Luck!
Posted on Apr 17, 2009
Soap dispenser opens, but detergent doesn't disolve and runs down front of door. Have tried several different detergents with no result.
You may have a hot water problem. The water when hot will disolve
the soap or detergent. The dishwasher hasits own heater to heat
the water entering the dishwasher. Check the electrical connections
below the dishwasher to make sure your heater is working. It may be just
a loose connection.
If this is not the case, then a service repait man will need to be called,
to determine why it is not heating the water.
Feb 25, 2011 | Maytag Dishwasher
Our dishwasher is not dispensing the soap. I have tried using the cubes (stays in wells), tried powder (it turns to a cake of soap) and I have tried liquid but you could see it ran down the door. Some...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Dishes are not clean if water is hard or when more detergent is used than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results. You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine. Hope this helps...
Please post back if more information is required.
Daniel
Jan 10, 2011 | Maytag Dishwashers
Soap does not disolve and residue left on all
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 17, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Soap dispenser is not releasing and the water is not disolving the soap; thus the dishes are not getting clean
if you are using tablets as opposed to liquid then just put them in cutlery basket at beginning of cycle wash result will still be the same, probably wax valve has failed these do go often and will need new dispenser or wax valve service engineer will need to change
Oct 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My Maytag neptune washer has a bad odor that seems to be transfering to the clothes. What can cause this and how do I correct it.
on the front load machines there is a large rubber door boot which gets built up with soap scum. always leave the door open a little bit when the wash day is done. there is a product available called "Afresh". it comes in a pkg with 3 tablets. if the odor is strong follow the directions and use all three tablets. then for maintenance use one tablet a month in an empty machine. what also helps is to make sure you do at least one hot water only wash per month, this helps to disolve all the soap that gets built up in the dispenser tubes and drain hoses etc. hope this helps.
Oct 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Detergent does not dissolve.
Make sure that the water supply going to the dishwasher is HOT. Detergent will not disolve in cold water.
Sep 15, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Soap dispenser drops soap out and tablet does not disolve.
use liquid soap ...those tablets are less messy but they don't work very well ....and make sure to use a dry agent like "jet dry"
Jul 25, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Tablet falls to the bottom of tub but wont disolve
The newer Whirlpool dishwashers have little slots in the top of the soap dispenser to allow water to seep in during the first water fill. This design allows the tablet to begin to dissolve during the first fill then be usefull when the soap door opens. In your case, I would check to see if the soap dish is opening at all. Perhaps one of the racks are not allowing clearance or the soap door itself is sticking closed.
Let the dishwasher fill, drain, and then fill again. Open the door of the dishwasher and see if the soap door is still closed and if so, there is your problem. Also, at this time, check the water temperature. It should be at least 120 degrees F for the soap to be effective.
Hope this helps, Ken
Jul 17, 2009 | Frigidaire Dishwashers
Dispenser door
Remove the outer door panel and check the actuator for the soap dispenser door it is probably broken. You might also check and make sure you don't have an old soap build up inside the soap dispenser. Sometimes old soap builds up and dries inside the dispenser and causes the door to stick. It should be free. Good luck.
Dec 21, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Soap not dispensed and dishes not washed
water is getting past the gasket during the start up cycle. by the time the door opens, the water has caked up the soap. also, its not clear when in the cycle the door is opening.
try using liquid soap.
also, take a peek just after the machine has finished filling and starts washing to see if the door is opened on the soap disp.
good luck
mark
Dec 19, 2007 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
331 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
