Question about Black & Decker D2030 Iron
Black decker D000C type 1
Hi I lost my instructions and got some dirt on the iron face so put the self cleaning on and it is still dirty and when I put the iron on it shows the up arrow and does not heat up WHY???????? I bought it last year.
  • 65 Answers
If it don't get warm , the thermostate is not working, or the internal resistance, is open. in either cases, you can check with a multimeter , but if you ask me, it's time to get anotheer one.
Posted on Sep 17, 2007
SOURCE:
How do I clean a not self clean ,quick press s506a , not self cleaning black and decker steam iron
Most steam irons can be cleaned deposits by emptying the water and replacing with white vinegar. Let it heat up and use the iron as normal - but on cloth rags instead of clothing. The vinegar breaks down and dissolves the mineral deposits inside that are responsible for sputtering and stains. You can reduce or even eliminate these deposits from forming by using distilled water instead of tap water in the iron - otherwise - run vinegar thru it when it starts acting up. The vinegar "trick" works great on coffee makers, too.
Dec 03, 2014 | Applica Black And Decker Steam Advantage...
The steam button is stuck on (pushed in) but there's no steam.
follow this steps. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Nov 15, 2012 | Black & Decker Irons
Instructions for steam clean on B&D iron
http://useandcaremanuals.com/pdf/D1200,D1500,D1600,D1650997.pdf
Or http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4
Hope this helps you.
Aug 01, 2010 | Black & Decker Irons
Soleplate is dirty and can't get it clean. Don't want to scratch it.
Purchase a tube of iron soleplate cleaner from your local fabric store or Bed Bath and Beyond.  Follow instructions.
You can also try a solution of vinegar and water applied to a cold iron with a clean 100% cotton towel.
Nov 08, 2008 | Black & Decker D2030 Iron
Black and Decker AS775 Iron won't reset to heat up.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 22, 2008 | Black & Decker AS775 Iron
Melted material on face of iron
Yes- I had the same problem and could not clean it off. It was a plastic sticker that melted on the iron plate- placed there by the manufacturer. I called Customer Service at Black and Decker, and after all their solutions failed- they sent me a new iron. But this one leaks water terribly to the point where the clothes are soaked after only 1 or 2 articles are ironed! I am beginning to lose faith in Black and Decker products.
Dec 24, 2007 | Black & Decker D2030 Iron
Self cleaning
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Dec 07, 2007 | Black & Decker AS175 Iron
Iron D2000C type 1 black decker
the folowing reason for not working 1. the connection may be lose 2. the heating coil is gone 3. inside connection may be lose.
Sep 17, 2007 | Black & Decker D2030 Iron
Black & Decker D2030 Iron Logo
112 people viewed this question
Top Black & Decker Irons Experts
Harvey Hyde
Steve Allison
Steve Allison
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
