Question about HP Compaq Presario Media Center SR1750NX (EL445AA) PC Desktop
Compaq SR2041X does not read SDHC card
Compaq desktop machine running Windows XP Media Center, the built in card reader will read the ScanDisk Ultra II 2 GB card just fine. But when I insert a Scandisk SDHC 4 GB card the computer hangs and finally pops the message "please insert card". It takes a long time to even cancel the operation and close the pop up window. The cards both work fine in my cameras.
  • Anonymous May 24, 2009
    Same problem here.
  • Anonymous Mar 22, 2014
    Not recognizing a card when inserted into the reader on the front of the computer
Possibly a band Reader.. one thing you can do is test to see if it reads other types of memory cards such as panasonic or kingston. If those do not work then it may be a bad card reader..
Posted on Apr 17, 2009
Sd card reader sdhc slot sandisk
Older Card readers do not read SDHC memory cards. If the card reader is built in then you probably cannot do anything about it, but you can buy a new USB Card reader to read the card.
Jan 09, 2014 | Dell OPTIPLEX 745 PC Desktop
Scandisk miro sdhc works in phone, but not in card reader for windows xp
Are you sure that your card reader can handle that type of card? Have you tried a different card reader? It is quite possibly the card reader or an incompatibility. What is the make/model of the card reader? Once I have more information I can assist you further.
Thanks,
Lee
Sep 22, 2008 | Cell Phones
How can I get the card reader to recognize sdhc cards
It's not your card reader, the SDHC mini firmware is dead that's why your reader cannot detect it. Warranty, return it to SanDisk for a new one. Every hardware you plug or attach to a PC or Laptop has what is called a firmware, a mini program that communicates with your PC and Laptop that's how they syst
Dec 30, 2012 | Gateway GT5082 PC Desktop
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Emachines w 3507 desktop isnt recognizing sdhc card
This PC was made before SDHC was finalized so the built-in media reader will not read SDHC. You will need to purchase an SDHC compatible media card reader device. I've seen them for as little as $3.99 and they just plug in via USB.
Mar 15, 2010 | eMachines W3507 PC Desktop
Gateway windows XP media edition will not recognize sd card
Tell me if it recognizes the USB drive ?
If it does, Try plugging card reader and see if that helps !!
Please let me know the status.
Thanks
Mar 28, 2009 | Computers & Internet
Garmin does not read scandisk 2 gb.
it might be due to the fact that you garmin cannot read AAC music format(the format itunes uses). try using windows media player to rip the CD then put the music on the card using windows media player. this should take care of your issue.
hope this helped.
please rate good.
Nov 12, 2008 | Computers & Internet
Will Sandisk yltra II 4gb card work with Nikon D40?
I assume you mean Sandisk Ultra..and the answer is Yes it will work fine.
A good choice card also..
Just beware that some computers will need the SDHC reader.
For example my SDHC cards can be read in XP without the reader but my Vista machines need the reader.
Good luck and happy shooting :-)
Nov 04, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
HP Compaq Presario Media Center SR1750NX (EL445AA) PC Desktop Logo
620 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
