Question about Poulan 1630 16" Chain Saw
Have a MAC 3818 chain saw it just stopped oiling.
This saw just stopped oiling the line is not stopped up blew air right through is there some kind of pump.
Yes there is an oil pump. Behind the flywheel is a gear driven oil pump on that saw.
Posted on Mar 07, 2010
  • 60 Answers
Same for me. Take chain off and ensure clean oil hole and channel. Clean hole if needed with fine wire or heavy nylon line. otherwise I think problem is interior, either oiler itself or oiler oil tube came loose. Since I have no excess oil coming out I suppose oiler iself is bad.Still working on it.
Posted on Apr 19, 2009
How do you get to the oil filter and how do you clean it and change it.
How to clean the chainsaw's air filter - YouTube
? 3:11
https://www.youtube.com/watch?v=wozSufvtbfE
May 30, 2012 - Uploaded by iScaper1
Tips for removing and cleaning the air filter on a Stihl MS250chainsaw. ... A very dirty air cleaner, a little maintenance can help them live longer ... Poulan Chainsaw Review- Should youbuy one? ... chainsawbars.co.uk - cleaning the air filter andchanging spark plug ... Get video URL at current time.
Mac 3200 chainsaw oil tank repair - YouTube
? 3:21
https://www.youtube.com/watch?v=XXlm-o8sD6A
Jul 17, 2012 - Uploaded by conan6868
Repairing oil tank. ... Could You Fix This Mini Mac Chain Saw! ...The chainsaw guy takes the McCulloch Mini Mac ChainsawChallenge 9 23.
Mucculloch 3516 chain saw assembly - YouTube? 49:25https://www.youtube.com/watch?v=Xm4YL3pDG8cJan 20, 2014 - Uploaded by Dragracer64In this video I take a box of dirty chain saw parts that has been sitting in my attic for about 12 ... Is there supposed to be a filteron the line in the chain oil tank? .... How to replace MCCULLOCH chainsaw MAC 3516 fuel line.How to replace MCCULLOCH chainsaw MAC 3516 fuel line ...? 1:32https://www.youtube.com/watch?v=GMjXYKza-NYJan 13, 2013 - Uploaded by Lambda ITCMCCULLOCH chain saw MAC 3516 chainsaw fuel line replacement. Three fuel lines. 1) First line in the tank ...
Dec 27, 2015 | McCulloch Garden
Need to know carb mixture
fuel mixture for 2 stroke' s is 20:1
100ml of oil in 5L of fuel
Mar 13, 2015 | Oregon McCulloch 12" Chain Saw Repl. Chain...
Ajust carb on mcculloch chain saw 3818
Turn in air/fuel adjustment all the way in and then
turn screw out 1 and a half turns out
Dec 03, 2014 | McCulloch Garden
Tightening the chain
Fuel ratio is 40:1 using modern chain saw oil--not any petroleum base oil like boat motor oil. Be sure to premix fuel and oil in it's own container and to shake vigorously just before filling the saw each time. To remove the chain, loosen the chain adjustment screw several turns CCW, release the chain brake, and remove the side nuts that hold the rear chain cover. The cover will just pull off, then the bar can be pulled rearward somewhat and the chain worked off of the bar. Remove the bar by pulling it outward. Clean the entire area where the bar and chain fit to the engine, then clean the bar oil ports that run from the larger holes out to the chain groove on each side of the bar. Start the engine with bar/chain removed--oil should ooze out of the side port where the bar fits to. If ok, and the chain appears to be relatively unworn, refit everything in the reverse order of removal, making sure that the chain teeth cut toward you on the bottom run, and the chain adjustment tang drops into one of the large oil holes when replacing the cover. Tighten the mounting nuts only finger tight, and adjust the chain screw CW until the chain ceases to droop from the lower side of the bar, yet not so tight that it can't be turned by hand. Tighten the mounting nuts firmly and recheck the chain tension. If ok, and the engine runs well, start the machine and hold the bar tip near some cardboard while running at speed for several moments--it should throw off a thin line of oil onto the cardboard. Use common chain/bar oil available from home centers, hardware stores and saw dealers. Make sure the chain is properly file sharpened. Hope this helps!
Jun 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
No bar oil is coming out. Emptied oil resevoir and blew air from compressor back through from oil outlet and still nothing. What could be the problem?
Normally, there are valves in the oil circuit that prevent oil/air movement in the reverse direction. There is usually an oil filter on the line inside the tank that occasionally will plug up. Remove same and check. An oil line can go bad as well as the oil pump. Some brands of saw use a plastic gear for the pump and the gear can strip it's teeth--check for same. When checking for oil flow, remove the bar and chain--look for oil to ooze out of a port on the engine case where the bar fits to. If ok, then clean the oil passages in the bar end, especially the two small passages that go to the chain groove on both sides of the bar. Finally, with everything together, run the saw at speed with the bar tip near a piece of cardboard for a few moments--it should throw off a thin line of oil on the cardboard. Hope this helps!
May 17, 2010 | Garden
How does the oil pump work? What drives it?
Most saws today have pumps that are driven by the chain sprocket/clutch. Some may operate from the crankshaft on the clutch side. Some older designed saws operate from vacuum/pressure from the crankcase, ie. Homelite XL, STIHL 009, McColluch Mini-Mac.
Dec 06, 2009 | Garden
Where can I find a new chain bar adj screw for WEN 3818 gas saw?
Most older chainsaw adjustments are visible when the saw is viewed from the end of the bar back to the saw. More modern ones are near the bar nuts (side). Lou
Aug 26, 2009 | Electric Chainsaw Sharpener
Mcculloch chainsaw 2014 Eager ****** Model 00032-14
a fix that sometimes works is to add kerosene to oil tank where the oil would go normally and rev saw several times with out load holding blade in down position over a piece of dry card board so you can see the oil spraying on the piece of cardboard careful of moving chain
Jan 02, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Poulan 1630 16" Chain Saw Logo
671 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
