Question about Car Audio & Video
I put a new motor in my 88 trooper. After the engine swap the cruise stopped working. I have power,and vacum. I see a loose blue wire coming from the black canister. Any ideas?
Audiovox cruise in my 88 trooper not working,what should I check first?
    Scholar:
  • 82 Answers
Check to make sure the tach sensor wire for the audiovox cruise control is connected, and also possibly speed sensor wire .... But I suspect the tach wire was left hanging after the motor replace
Posted on Apr 17, 2009
1994 olds 88
tune up time?, at least spsrk plugs, and filters.
misfire is just that. its misifiring and #1 top of list, 100 years is tuneup.
Jul 19, 2014 | 1994 Oldsmobile 88
Throttle position sensor problems
reduced engine power has to do with the electronic throttle control or drive by wire . All electronic wires under the dash on the gas pedal , electric motor on the throttle body . DTC'S - diagnostic trouble codes stored in the computer . Take it to the dealer .
Mar 04, 2017 | 2002 Chevrolet TrailBlazer
88 Isuzu Trooper 2 lost power to the pump. Installed a new pump, sock , filter and relay in the fuse panel. Still have no power! Can you help?
I would suspect either a bad plug- in at the pump or a bad power wire. Run a wire from the battery direct to the pump. If it runs, attach the wire under the hood to something that only has power with the key on and put an in-line fuse into it. Hope this helps.
Nov 08, 2011 | 1988 Isuzu Trooper 2 Door
I have a 2006 dodge grand caravan and i cant find but only one fuse box and it is the relay box under the hood. does anyone know if there is another one and where it is? My cruise control light comes on...
The circuit diagram that I have. Only shows the 1
fuse/relay block,under the hood on the left fender.
Fuse #24 a 20amp fuse is for the cruise ctl. But the way it appears to be wired. If the fuse is blown the
light should not be working. Try checking for vacum
at the servo unit. It's a diaphram with a small chain
that go's to the throttle assy. It's mounted on the rear
(drivers side)of the engine. Also check for vacum
leaks at the vacum chamber. The chamber is at the
bottom of the battery box. You can also check the
brake light switch, This can shut off the cruise cont.
if it sends a signal that the brake peddle is depressed
The switch is located at the top of the brake peddle.
Hope this helps.
Mar 26, 2010 | 2006 Dodge Grand Caravan
Cruise control doesn't work in 88 accord. The light works on the dash, but the buttons on the steering wheel won't work.
Hi!!
Let's start by checking the cruise control throttle linkage cable, just follow the cable coming from the cruise control servo to the throttle linkage, were it connects. The plastic clip at the end of the cable gets britle and over time, it brakes.
Check fuse
Check for loose conections and broken wires.
The cruise control system is operated by vacuum, check vacuum hoses for cracks, loose connections and obvious leaks.
Due to the complexity of the cruise control system, this is about all you can do to fix the problem.
If you can't detect the problem, take the vehicle to an authorized service shop for diagnostic and repair.
Good Luck!!!!
Mar 12, 2010 | 1988 Honda Accord 4 Door
I have a 1999 ford lightning with a cruise problem. the light will not come on, have tried the hold the off butten turn on diag, no blinking light. have pulled the plug on the cruise stepper motor and...
Just because the horn works doesnt mean the Clockspring is good, the cruise circuit part of it could be bad. Have you had the recall for the brake switch (switch on master cyl) done? The black/yellow and the light blue/pink wire on the servo (steper motor) should be hot (fuses 13 and 5) Brake light switch working OK? The Light blue/black wire coming out of servo should be hot , that wire goes to the column, through the clockspring, to the on/off switch. If that wire is hot coming out of the servo, but has no power at the on/off switch, the clockspring may be bad. You can always make a jumper from the servo to the switch with a wire, if it works, then that confirms the clockspring bad. Good Luck ; )
Nov 04, 2009 | 1999 Ford F150 Regular Cab
Cruise control on 98 chevy venture stops working
The Venture uses an electronic Cruise Control and doesnt require vacume. I would suspect the cruise module under the hood, or the lever on the steering colum to be bad.
Oct 08, 2009 | 1997 Chevrolet Venture
I was vacuming and it stopped running. will not
either you have a break inside the power cord or the wires have come loose on the motor.
Jul 31, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
87 ranger new motor bad truck
try to find an 1988======>93 ranger. the closer to 88 the better. the wiring harness is similar in 90-93, but you will have to adapt some parts on the newer.
Sep 10, 2008 | 1988 Ford Ranger
Car Audio & Video Logo
78 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
